mirage Posted December 30, 2019 Author Share Posted December 30, 2019 thanks, at the time I did not find many photos about it but only screenshots on restorations taken from "you tube" and I interpreted a little and I trusted, wrongly, in the shape of that of the kit. But now the omelette is done ... 1 Link to comment Share on other sites More sharing options...
Stickframe Posted December 31, 2019 Share Posted December 31, 2019 Hi Mirage - nice build all around. The exhaust reminds me of my dad’s ‘64 Riviera - turns out he had a built 426 nail head with dual 4 barrel Carters in it - but it looked dead stock. He had dual exhaust with two in line Flow Masters and Cherry Bombs - the sound effect was great - rolling up to an intersection or in a parking lot it had a clear, nasty rumble, accelerating it had a brutal scream, but once cruising back to the nice rumble - what a car with great sounds. Sorry for the trip down memory lane, I really like your build. Cheers Nick Link to comment Share on other sites More sharing options...
mirage Posted December 31, 2019 Author Share Posted December 31, 2019 Thanks a lot, it's one of my favorite cars ever. And I enjoy customizing it ... Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 ... I am almost finishing all the part relating to the floor, I miss the caps and the welds between the various pieces. Here I made by modifying a hairpin the front brackets of the fuel pipe, missing to insert the one for the brake pipe which will be made in the same way ... 1 Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 ... I have detailed the part relating to the front arms Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 ... to simulate the rivets of the crossbows, impossible to pierce being of a very hard metal, which cost me 4 tips without even scratching it, I poured a drop of vinyl glue with a toothpick, for physical reasons it forms a perfect circle, once dry I painted. The result is even better than photoengraves that are too flat ... 1 Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 I finished all the part relating to the floor, I simulated the caps by modifying the bigots by closing the three holes Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 .. for the welding of the various parts of the floor I have always adopted the technique of cyan + bicarbonate ... Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 correct pedal handbrake system. Link to comment Share on other sites More sharing options...
mirage Posted January 5, 2020 Author Share Posted January 5, 2020 flatbed almost complete. 2 Link to comment Share on other sites More sharing options...
mirage Posted January 7, 2020 Author Share Posted January 7, 2020 I started the engine part, here pulleys, belts and radiator hose ... Link to comment Share on other sites More sharing options...
mirage Posted January 7, 2020 Author Share Posted January 7, 2020 ... I threw it all away and took some pulleys from the discard box, and the game begins ... Link to comment Share on other sites More sharing options...
mirage Posted January 7, 2020 Author Share Posted January 7, 2020 ... for this I modified a press button ... Link to comment Share on other sites More sharing options...
mirage Posted January 7, 2020 Author Share Posted January 7, 2020 .. modification of connections and painting of pulleys ... Link to comment Share on other sites More sharing options...
mirage Posted January 7, 2020 Author Share Posted January 7, 2020 .. insertion of glitter for nails and assembly ... 2 Link to comment Share on other sites More sharing options...
mirage Posted January 7, 2020 Author Share Posted January 7, 2020 belt assembly... 3 Link to comment Share on other sites More sharing options...
JeroenS Posted January 7, 2020 Share Posted January 7, 2020 I like your creative use of different materials. 1 Link to comment Share on other sites More sharing options...
Cooper645 Posted January 12, 2020 Share Posted January 12, 2020 On 1/7/2020 at 2:53 PM, JeroenS said: I like your creative use of different materials. I fully concur. A fantastic result achieved. So much better than the kit supplied parts. Ingenious use of items I would never have thought about using in my lifetime. 1 Link to comment Share on other sites More sharing options...
mirage Posted January 16, 2020 Author Share Posted January 16, 2020 here I made the vapor recirculation filter, that of the kit I threw it away. Link to comment Share on other sites More sharing options...
mirage Posted January 16, 2020 Author Share Posted January 16, 2020 ... first I created the body of the filter starting from two plugs which are the connectors of the loudspeakers that are removed to insert the banana connections of the cables. Instead for the actual filter I folded the 320 sandpaper organ ... Link to comment Share on other sites More sharing options...
mirage Posted January 16, 2020 Author Share Posted January 16, 2020 ... for the rest I have modified a distributor and connected to the filter through the lighter refill connections ... Link to comment Share on other sites More sharing options...
mirage Posted January 16, 2020 Author Share Posted January 16, 2020 ... I modified the attachment with plasticard strips and used four glitter for nails that simulate the bolts ... Link to comment Share on other sites More sharing options...
mirage Posted January 16, 2020 Author Share Posted January 16, 2020 ... vapor recirculation filter finished. 1 Link to comment Share on other sites More sharing options...
mirage Posted January 18, 2020 Author Share Posted January 18, 2020 sleeve detail ... Link to comment Share on other sites More sharing options...
mirage Posted January 18, 2020 Author Share Posted January 18, 2020 ..distribution detail and ignition coil .. 2 Link to comment Share on other sites More sharing options...
