Thomas V. 266 Posted November 26, 2019 Share Posted November 26, 2019 (edited) Hi all, I still did not make new Eduard's Mustang, but have few in the stash, and plan on adding more. There is one thing that to me seems odd, on all models that can be found on internet tailwheel position is far too back and far too low, question for those who tackled the model, is it an inherent flaw or can be rectified? Big thank you. Tom Edited November 26, 2019 by Thomas V. Link to post Share on other sites
HistnScale 0 Posted November 26, 2019 Share Posted November 26, 2019 On my last one, I added a .015 shim to the top of the tail gear leg and added the assembly after everything else was complete. This improved the sit of the model and eliminated breading off the tail wheel during construction. HTH, Dave. Link to post Share on other sites
gingerbob 3,048 Posted November 30, 2019 Share Posted November 30, 2019 Here's a good thread discussing this question: https://www.tapatalk.com/groups/hyperscale/eduard-p51-tail-wheel-t509698.html 1 2 Link to post Share on other sites
SteveBrooking 13 Posted December 7, 2019 Share Posted December 7, 2019 I am not a modeller but I am interested The problem with the sit of the Eduard P-51 might be partly to do with the tailwheel but the main problem is to do with the length of the main undercarriage legs. The design of the main undercarriage leg is based on a lightly loaded aircraft. If measurements were taken from museum exhibits then the aircraft studied would not have had any fuel on board and most likely no guns or ammunition. If you look at photos of fully loaded war time P-51s then the bottom edge of the undercarriage cover is usually to be seen level with the centre of the wheel hub. On the Eduard model the large gap between the centre of the wheel hub and the bottom of the undercarriage cover would normally only be seen on a lightly loaded aircraft. In the “Info Eduard” for December 2019 there is a feature on a model of a Pacific VLR Mustang with the main undercarriage barely compressed. Fully loaded with full wing tanks, full overload tanks and a full fuselage tank that aircraft would be carrying almost 3000lbs of gas plus 6 x .50s plus ammunition… I don’t know how you would fix it!! Steve Link to post Share on other sites
NorthBayKid 119 Posted December 7, 2019 Share Posted December 7, 2019 I agree - when I saw the completed kit the first time, the very first thing that jumped out at me was that the model appeared to be standing on its tiptoes. The too-short tail wheel leg increases the effect. Amazing they could make such a basic mistake. Link to post Share on other sites
Work In Progress 3,521 Posted December 7, 2019 Share Posted December 7, 2019 2 hours ago, SteveBrooking said: I am not a modeller but I am interested The problem with the sit of the Eduard P-51 might be partly to do with the tailwheel but the main problem is to do with the length of the main undercarriage legs. The design of the main undercarriage leg is based on a lightly loaded aircraft. If measurements were taken from museum exhibits then the aircraft studied would not have had any fuel on board and most likely no guns or ammunition. If you look at photos of fully loaded war time P-51s then the bottom edge of the undercarriage cover is usually to be seen level with the centre of the wheel hub. On the Eduard model the large gap between the centre of the wheel hub and the bottom of the undercarriage cover would normally only be seen on a lightly loaded aircraft. In the “Info Eduard” for December 2019 there is a feature on a model of a Pacific VLR Mustang with the main undercarriage barely compressed. Fully loaded with full wing tanks, full overload tanks and a full fuselage tank that aircraft would be carrying almost 3000lbs of gas plus 6 x .50s plus ammunition… I don’t know how you would fix it!! Steve That accounts for some of the deck angle issue, but the ride height of the Eduard tailwheel is wrong straight out of the box regardless of loading Link to post Share on other sites
