Paulaero
RAF 100th Tucano 1/72
So, with the new Airfix Bucc on hold due to my 'mate', I decided to raid the stash to apply some newly released markings.
P1540493
 This was along way down in the said stash.... I think this was the original release dated 1990 which is about right with them entering service in 89.
(Where did that 30 years go ???
P1540504
Brand new release at Telford, I had difficulty in getting a picture of these as the gloss carrier film is so reflective, which is more than can be said for the kit ones !!
P1540499
As Baldrick might have said, flatter than a flat thing on a flat day. Still they are nearly 30 years old and all I need is to coax the IP's off.
P1540503
Art work for said subject, having searched out ZF293 it looked to be quite a well worked A/C by the time it had these markings applied.
P1540509
Having opened the lid the nostalgia came flooding back just like the cracking builds of the classic US Navy kits, particularly as this was also moulded in white, well it was once !!
P1540513
I guess cream is more appropriate but the surface detailing is so fine,(open can of worms) but I guess this was one of the first mouldings. I think these are currently in the standard grey plastic if any one can confirm ?
Now the Tucano has always been a tail sitter and the instructions state 7grms, but whilst removing parts from the box look what I found.
P1540518
Bonus, Now where did they appear from......
P1540520
These are obviously the same vintage and are probably some of the first out but that means some where in the stash I have a kit with these and the U/C and prop set in....
P1540511
So cockpit tub assembled rear stick appears to have gone AWOL - will rectify that but this is a build to show off the colour scheme
P1540515
One piece lower wing, again look at how fine those panel lines are
P1540517
Upper wings attached the plastic has almost a resin feel to it, not some thing I have come across before but then again haven't built many 30 year old kits …..
P1540512
Canopy is nice and clear, just a dip in some Klear should do, cockpit tub off to the paint shop just aiming to get it the same shade as the IP on the Kits decal sheet
More to follow
Edited by Paulaero
Duplicate
I'll be following your build with interest. I still have one of these in my stash.
And yes! it is a tail seater, so be careful and put as much weight as you can fit on it.
One thing that will need correcting if you're of a mind to do so, the aileron lines inboard do not align on the top and bottom surfaces of the wings by quite a substantial margin but given some of the other challenges that this kit offers that's probably the least of your worries..
Clive
I love it when you buy an old kit and discover some unexpected bonus! Looks like this kit is in the "vintage but worthy" category, good to know and will follow.
So with cockpit painted a suitable 'shade of grey' work commenced on making seats fit. Now the one problem with making scale accurate seats is they often don't fit straight in the cockpit as the kit makers cant make the tub's to scale. .
Added to that over thickness canopy's and these seats have had to go on a severe bottom reducing diet...
Thank fully I have one of those large file's that we all loved the name of in metal work and that made short work of sorting the seats.
As you can see there's not a lot left of the seat pan, particularly the rear one .
P1540526
But they do fit now and so does the canopy
P1540523
And the visible parts of the detail look good
P1540525
Off to the paint shop for the seats
Edited by Paulaero
Duplicate
 Looking good Paul, as the owner if a couple of these, I'll be following to find out any traps for the unwary. :)
Steve.
Steve.
Hi Steve,
so far the only trap has been down to the age of the plastic , its so brittle while assembling the two fuselage half's one side broke behind the cockpit, hopefully the repair wont show...….
Paul
While the seats are drying I added the IP decals which actually performed better than I expected and added the Coamings
P1540528
Still doubt much of this will be visible through the closed canopy
P1540529
Some extra lead added, just in case
P1540530
Wings fitted very tight as did the tail planes, they were a push fit again may be down to this being a very early shot.
So main construction complete, I know the seats and canopy fit so time for a little appointment with the sanding sticks when the glue dry's
Looking nice. I see yoou found out the hard way re the white metal seats I had the same problem when I did my retro schemed one in light grey and dayglo.  Look forward to seeing this with those new Model art decals.
Now that's spooky as I thought the  design of the A/C would suit some day glo, must have missed it have you a pic you can post ?
Have spent a looooong time fitting these seats and these needed the most material removing. Have just dropped a Mk 4 into a new Airfix Lightning and it fitted perfectly ...
4 minutes ago, Paul J said:
Here you go:.....
That's very nice just look so right and your spot on with the thinking about not changing training colour schemes.
Thanks. I may go back to it soon to add some dayglo to the tail planes as it looks a bit unfinished  to me.
