Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 Just now, Hornet said: Absolutely stunning work Serkan! Thanks mate! I am impatient to seeĀ the print results... Serkan 3
Hornet Posted December 25, 2020 Posted December 25, 2020 CanĀ all these parts be used with Italeri kit? 1 2
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 To be honest I don't know yet. My 3D model especially the fuselage is based on overlapped circular sections and I haven't compared the dimensions with Italeri kit. I will do this check when the parts are ready... Serkan 1 2
Hornet Posted December 25, 2020 Posted December 25, 2020 Maybe you can check the nozzle and inlet parts if they fit the Italeri kit. š¤ 2 1
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 not a bad idea. I will do this check soon. 2 1
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 The print has been completed. Here are the fresh parts: Ā More pictures will be available soon . But first the parts has to be washed with IPA and cured under UV light... Ā Serkan Ā Ā 6
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 All parts were cleaned and fully cured: Ā Ā The printed parts weigh only 43gr in total including base&supports. Ā There are some areas to be improved but I am really happy what I got even after first print. Ā Serkan 16
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 Here are the parts to build three versions: Ā I have generated the support structure both in CAD model and chitubox tool to see which one is more effective: Ā I didn't notice any advantage one to another for printing these parts. What I would conclude that if the support structure is parallel to z axis then chitubox is very quick and efficient. Otherwise adding the support structure in CAD model is more convenient. Ā Serkan 11
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 Some issues to be improved: Ā The scaled pitot tube was too thin to print. The diameterĀ should be resized to print it reasonably. Ā Also the chine edges are too sharp to print. I will round the edges with a diameter of 0.2mm: Ā Here are the all parts printed till now: Ā Serkan Ā 13
Serkan Sen Posted December 25, 2020 Author Posted December 25, 2020 Thanks Bill, Tomorrow I will make some fit tests with Italeri kit. Serkan 3
Space Ranger Posted December 26, 2020 Posted December 26, 2020 Is this a commercial endeavor? I'm sure I'm not the only one who would like to acquire copies of these exquisite items! 3 1
billn53 Posted December 26, 2020 Posted December 26, 2020 1 hour ago, Space Ranger said: Is this a commercial endeavor? I'm sure I'm not the only one who would like to acquire copies of these exquisite items! Ditto. I have an A-12 and interceptor version on my wish list.Ā 2 1
neil5208 Posted December 26, 2020 Posted December 26, 2020 +1 for the A12 parts. I'm interested in the hardness of the cured resin, would it be able to scribe panel lines into? 2 1
(ex)Sgtrafman Posted December 26, 2020 Posted December 26, 2020 Fascinating stuff and the end result looks great too. Ā Iain 1 1
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 7 hours ago, Space Ranger said: Is this a commercial endeavor? I'm sure I'm not the only one who would like to acquire copies of these exquisite items! At the beginning was not. But now I see that there is a potential of selling the parts to finance my other fancy future projects (like RF-8 Crusader, TF-102 etc...) š Ā But I will first complete Blackbird family by adding YF-12 and SR-71 variants including different nose options... Ā Serkan Ā 7
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 5 hours ago, billn53 said: Ditto. I have an A-12 and interceptor version on my wish list.Ā As I promised (remember my A-12 Oxcart build) you and Nikolay will get a complete set when all parts are completed. Serkan 2 1 1
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 3 hours ago, (ex)Sgtrafman said: Fascinating stuff and the end result looks great too. Ā Iain Thanks Iain. I hope the completed model will look good too. Serkan 4
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 3 hours ago, neil5208 said: +1 for the A12 parts. I'm interested in the hardness of the cured resin, would it be able to scribe panel lines into? Thanks Neil. I will post some images about the scribed and modelled panel lines soon. (I have to prepare them first š) Serkan 4
Robert Posted December 26, 2020 Posted December 26, 2020 (edited) Hi Serkan, would like to see how the seats print out. Have you plans for the undercarriage bays or will you use what you have done before with the kit parts ? Ā Regards Robert Edited December 26, 2020 by Robert Predictive text problems 1 1
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 19 minutes ago, Robert said: Hi Serkan, would like to see how the seats print out. Have gorillas for the undercarriage bays or will you use what you have done before with the kit parts ? Ā Regards Robert Hi Robert, Based on my experience (which I gained during last few days) I need to thicken many areas of ejection seat. That means it won't be fully scaled but in any case better than the kit seat. Also I will print a pair with more realistic part thicknesses for my Testors 1:48 Blackbird. Regarding to landing gear bays and assemblies I haven't done anything yet. Maybe I can start with doors but the rest will be done next year (oops next week will be already next year šĀ ) Serkan 3
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 To remove the support structure and base plateĀ I useĀ two types of razor saw instead of flush side cutter which easily leadsĀ to break resin at undesired location (as the resin is very brittle) Ā ForĀ support structure I usedĀ Hasegawa Modeling Scriber Scribe Saw which is extremely thin (0.1mm I assume): Ā For base plate I use Xacto Precision Razor Saw with 0.5mm thickness: Ā Here all parts were processed and assembled together: Ā As you may have noticed the A-12B Mother Goose's aft wind shield is missing because somehow I lost this tiny pieceĀ š„“ Ā Serkan 4 3
Serkan Sen Posted December 26, 2020 Author Posted December 26, 2020 Here are some pictures to compare printed parts with my ongoing (and never ending šĀ ) Oxcart: Ā Note that how perfectly fits the canopy parts to their frames: Ā Serkan 8
