12 hours ago, Serkan Sen said:
Compared to your ongoing Westland Wasp project mine is very basic one
Not true of course, but as it's your thread Serkan that can be overlooked. 😁
Your approach to support structures alone is but one example of how much more advanced and insightful your command of the printing process is than my own, and a reminder of how much I still have to learn.
They are both First Class projects that normal modelers with out the equipment or design skills could only dream of .
Pete
  • Thanks 2
Seconded
  • Thanks 2
Many Thanks Tony. I think the biggest issue in your 3D model is that you are detailing everything in quantum scale which is impossible to print them with today's technology.
Serkan
Few more photos for the close views:
And finally all three sisters together:
There are few areas to be fine tuned. Also I have some plans to add the details of engine bay. But I can say that the model is ready to build for standard display.
Serkan
  • Like 12
That is truly one of the most magnificent processes l have seen from start to finish of a completed model. What you have created us model makers can only dream of, a true masterpiece of your skills and engineering.
Regards
Robert
Serkan
Great job Serkan, magnifique !
  • 2 months later...
Hello mates,
Although I am still on vacation (four out of five weeks are over) here is some significant progress in 3D modelling especially for YF-12A. Last year I had already done some prelimary studies for YF-12A front fuselage shape as given below:
Unfortunately I had a very painful gout attack during vacation and it took about two weeks to recover. But fortunately my laptop was with me (as always despite my wife's objections) and I had plenty of time to work on new YF-12A model. Yesterday I have finally finished the basic modelling including the ventral fins and nacelle pods:
I haven't done any progress on cockpit and instrument panel modelling and most probably this will be done after the vacation. Now my left big toe gets better and I can go to beach to enjoy the sun and sea!.. 🏊‍♂️😎🍸🏄‍♂️
More images will follow after the swim break 🙂
Serkan
  • Like 9
Enjoy the rest of your vacation, and take good care of that toe!
Great to see you are back at work on the YF-12A, that one is definitely on my 'must do' list!
- Bill
- Bill
Many thanks Bill.
Here are some more pictures of the YF-12A model from different angles:
Some close up images will follow.
Serkan
  • Thanks 2
11 minutes ago, David H said:
Truly amazing stuff. You are a master at this.
Many thanks David. After the vacation the first thing I will do is to make a test print in 1:72 scale to see the result in reality.
Serkan
Yesterday just for my curiosity I have created a rough model of AIM-47 Falcon (GAR-9?) to check how good the missile bay sizes are:
And more images from different view angles:
In overall both missile shape and bay door sizes look fine. Now the biggest problem is to find some reference photos that show the bay details...
Serkan
Wow....
Miles removed from the 2 YF-12s i built when i was a kid. The first one was the AHM kit built in 1981, the second being the Italeri kit i built in 1987 or thereabouts.
-d-
Agreed. Masterpiece is a word best used sparingly; but my gosh it applies here.
Sounds nasty; hope you’re over it now Serkan.
Gorgeous.  Still have no idea how you’ve blended in all of those complex curves so perfectly.  Complete mastery.
Here is the little update after the long vacation. The chine fairing has been modified where IRST will be placed:
The below image contains all chine variant that YF-12A had. With blended fairing, with IRST balls and with canard:
The IRST "balls" have been embedded in the cut-back chines to the left and right of the radome. It seems that they are a bit oversized and the straigth chine leading edge is slightly short but in overall the entire model looks fine:
Next step is to launch a test print to see how the model looks in reality.
Serkan
Totally jaw dropping! This is astounding to scroll through, I don't think there is a proper word to describe what you have done here! YF-12 is a gem, looking forward to seeing more of that!
Marc
Marc
Many thanks Marc. Although most of the external modelling of YF-12A was done, there are still much to do with cockpit and missile bays. The biggest problem is the lack of sufficient reference pictures.
Serkan
The models have been converted into STL format and a print file was submitted to the printer:
It will take around 10 hours to complete the print work. The canopies and windshield have not been modeled separately because this is only a test print to check the overall shape and part fit physically. Also the nacelle ventral fins are missing in this print job.
Serkan
Here are the printed YF-12A parts. There are some areas to be improved/corrected but in overall the general shape looks fine.
  • Like 15
The  forebody chine has mainly three shapes: cover fairing, IRST and small canard vane mounted on the forebody chines. The USAF/NASA YF-12A in display at the National Museum of the United States Air Force has still this canard mount installed.
The method I found to simulate all these versions is to create forward fuselage and forebody chine parts separately. Here is the modified front fuselage:
And here are with all  chine plugins:
In overall all these plugins look fine. The next step is to create print files and do the test prints.
Serkan
  • Like 13
Exceptionally fine work Serkan - I've said it before but your control over surface detailing is exquisite. :thumbsup2:
