Legendary Blackbird - Part 0: Genesis... (3D Printing)
Couple of months ago I have launched an A-12 Oxcart build based on 1:72  Italeri/Testors kit. Although I did significant progress on the kitbash I was not quite happy with never ending sanding/filling process which you can follow in below thread:
After getting my 3D resin printer as birthday gift from my wife and daughters I have decided to print first the kit replacement  parts. But of course I need to have the digital models to print out. Therefore I have started to search best reference drawings to be used in 3D modelling. Also I have imported my own 3 view drawings to CAD.
This will be very challenging project and at the end I hope the result will worth all the efforts 🤔
By the way, I did not give up A-12 kitbash. It continues in parallel 😁
I hope you will enjoy this adventure and share your comments about the progress.
Serkan
  • Like 25
I will be watching this with much anticipation!!! Considering the level of detail in your previous project, i expect this will be one of the most accurate blackbird models out there!
What software are you using @Serkan Sen? In terms of generating 3d geometry, have you considered Onshape or Fusion 360? both are free to use and quite powerful tools.  Ive used Onshape to create a large 3D Printed Flying Wing model a few years back, went together great
Some 1/4 and 1/2 scale models to refine the shape
Full size version main battery/equipment bay
May do something similar (but not a flying version this time) for my Baynes Carrier Wing
On 11/22/2019 at 1:52 PM, Kushan_Farsight said:
What software are you using? In terms of generating 3d geometry, have you considered Onshape or Fusion 360?
At home I use FreeCad for hobby projects, at work CatiaV5. Onshape and Fusion 360 look very powerful and it is great to get free such a tool for hobby projects .
Serkan
The front fuselage surface patches were generated from sections:
The port side was created by mirroring starboard side. There  are some areas to be improved but in overall the shape looks correct.
I have some doubts on windshield and front canopy side views. I will be appreciated if you share your opinion about the correctness of my above drawing.
Serkan
  • Like 9
On 11/23/2019 at 7:37 PM, Nikolay Polyakov said:
Same here, maybe the top portion of the canopy is too forward.
On 11/23/2019 at 9:23 PM, billn53 said:
Maybe this can help:
Bill, Nikolay,
Thanks for your precious feedback. Although there are dozens of side view images on flicker and web it is very hard to find a good reference image without perspective effect and shot parallel to chine line. To me the below one is one of the best reference photo and it was used for comparison with my current drawing:
And here is the comparison with early A-12 drawing from Lockheed blueprint (sincerely thanks to Martin from Part 1 thread)
Serkan
I have realised that I made a fundamental mistake when I started to draw model. I was only focused on the sectional drawings rather than examining the airframe structure from reference pictures and drawings carefully. What I was trying to do was a kind of “reverse engineering” approach.
I had already drawn the side view upper and lower surface curves as well as centreline of circular sections. Therefore it was very easy to generate entire fuselage circular sections as well as cockpit area sections:
The chine circular blend starts approximately at 45 degrees. The intersection line was generated using inclined plane and created circular fuselage:
The blended circular chine was created very quickly using this intersection:
The new surface is now very smooth compared to first attempt. The section contour variation along fuselage shows the improvement in modelling.
Serkan
Edited by Serkan Sen
  • Like 9
1 hour ago, Neffan said:
Hi Serkan, really interesting… :) I think, soon you will be able to make alot of parts with 3D CAD ... ? Maybe some aircrafts  model-kits....? Congratulations for your work    👍
Thanks Neffan,
Yes I am planning to create RF-8 and TF-8 Crusader front fuselage models to print them out. Many years ago I had started to modify Academy kit to convert but was not able to finish...
Serkan
Before detailing inlet I have decided to model the wing. Also rear fuselage was added to assembly. It was not easy to find wing profile and give correct shape to the outer leading edge but finally it has been completed:
I have also reshaped the engine fairing because the first attempt was not looking right.
Serkan
  • Like 9
Good progress so far Serkan! how much detail are you going to put into the engine nacelles? i saw a picture on the net of a nacelle 'hinged' open to allow access to the engine. This was for the SR-71, but was a similar method used on all variants? It would be pretty neat and i dont think ANY of the kits of the blackbird do this at the moment.
PdbBmUDz5dgIADhdA9mDXm5iruTZpWTH2qRusx-I
Of course, it is piling on the extra workload, but could be neat!
The showstopper is the J-58 engine. The inlet duct and afterburner&nozzle parts are relatively easy.  The internal structure can be modelled upto some acceptable level. But building such model is too much even for my patience limits...
Serkan
Serkan
There is more plumbing on that engine than i think i have in my entire house! I dont blame you!
If you were going the kitbashing route, there was a 1/72 kit that came with J-58s, but what i can see on the sprue/boxart looks nothing like the actual engine
http://modelstories.free.fr/histokits/SR71_P/SR71_WSN/index.html
Will look forwards to the next update!
During the last few days I was busy with the air intakes. Although there are some inlet sketches on internet they are mainly intended to show the principles how the Blackbird inlet works. But none of them has the real shape of the inlet duct. The most realistic sketch I have found was from A-12 Flight Manual Book:
Mainly based on this sketch I made the 3D intake model as given below:
There are few photos of real inlet duct from front without spike and also from engine side that shows rear end. Here is the front view comparison of 3D model I generated and the real one:
The next will be the spike.
Serkan
Maybe this:
https://www.shapeways.com/product/JQLZJXHSV/sr-71-blackbird-engine-spike-1-72?optionId=60722282&li=marketplace
and this:
https://www.shapeways.com/product/GDH3ANEJN/sr-71-blackbird-engine-inlet-1-72-testors?optionId=60804741&li=marketplace
will help you.
Here are some more nice detail pics. They show an YF-12A, but many sections like air intakes, exhaust, gear bays are the same on most versions anyway.
http://www.primeportal.net/hangar/howard_mason3/yf-12a/
Ramon
Edited by Sting67
9 minutes ago, Sting67 said:
Maybe this and this will help you.
Ramon
Thanks for the links Ramon. I have also seen them when I was looking for replacements. But I am afraid neither the duct nor the spike&inlet have the correct shape.
Serkan
