cocky05d Posted November 17, 2019 Share Posted November 17, 2019 Hi ,in the middle of the Italeri 1/48 A36 Apache ,glued the wings together last night ,found i am missing a Bomb Shackle ,one already in place ,don't know what to do . Should i take the one already in place off and fill the holes in ? Finding this model making lark a bit stressful to be honest .😩😩 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 17, 2019 Share Posted November 17, 2019 You could ask down in the wanted section someone might have them going in their spares ? Link to comment Share on other sites More sharing options...
Selwyn Posted November 17, 2019 Share Posted November 17, 2019 4 hours ago, cocky05d said: Hi ,in the middle of the Italeri 1/48 A36 Apache ,glued the wings together last night ,found i am missing a Bomb Shackle ,one already in place ,don't know what to do . Should i take the one already in place off and fill the holes in ? Finding this model making lark a bit stressful to be honest .😩😩 Do you mean a shackle? You would not be able to see this on any kit with a bomb on. Do you mean the swaybraces on each side of the bomb?  Selwyn 1 Link to comment Share on other sites More sharing options...
cocky05d Posted November 18, 2019 Author Share Posted November 18, 2019 Hi ,the thing you stick on the bottom of the wing then attach the bomb to it . Link to comment Share on other sites More sharing options...
Rob G Posted November 18, 2019 Share Posted November 18, 2019 44 minutes ago, cocky05d said: Hi ,the thing you stick on the bottom of the wing then attach the bomb to it . Â Pylon? Sort of like a short, sideways wing? Link to comment Share on other sites More sharing options...
Graham Boak Posted November 18, 2019 Share Posted November 18, 2019 Get a piece of the runner and attack it with a knife and file until it looks like the one on the other wing? Link to comment Share on other sites More sharing options...
cocky05d Posted November 18, 2019 Author Share Posted November 18, 2019 3 hours ago, Graham Boak said: Get a piece of the runner and attack it with a knife and file until it looks like the one on the other wing? Runner ? Like wot seb cole is 😂.I have got some ICM Spitfire ones in the spares might have a look at them ,thanks for the advice though . Link to comment Share on other sites More sharing options...
72modeler Posted November 18, 2019 Share Posted November 18, 2019 If Italeri has a customer service contact, you could see if they could supply you with a pair of shackles. You might also post a query in the "wanted" section here on BM to see if someone might have a set from another 1/48 Mustang kit, but that's probably not likely, as Mustangs almost always kept the pylons attached, even when not carrying fuel/bombs, so usually always fitted by modelers. You could also try popping the one you do have off of the wing, making a master using  silicone bath/auto caulk, and then casting a duplicate in resin. Mike Link to comment Share on other sites More sharing options...
Graham Boak Posted November 18, 2019 Share Posted November 18, 2019 The runner is what we used to call the sprue, the bits that hold the pieces of the model together. Â Apparently the sprue is what connects the plastic supply to the tool. Link to comment Share on other sites More sharing options...
cocky05d Posted November 20, 2019 Author Share Posted November 20, 2019 On 11/18/2019 at 9:05 PM, Graham Boak said: The runner is what we used to call the sprue, the bits that hold the pieces of the model together. Â Apparently the sprue is what connects the plastic supply to the tool. I know that ,just joking .Anyway found some in the spares box that will do ,they might have come from the Revell P51D i posted a few weeks ago . Just got to cut the bomb holding arm things off and good to go . Link to comment Share on other sites More sharing options...
