MarkSH Posted November 15, 2019 Share Posted November 15, 2019 Hi all, Seeing as I have embarked on a build of the Bandai Interceptor from Gerry Anderson's UFO over on the ongoing Film, Fictional and Speculative Group Build, I felt that I needed to have the adversary vehicle from the show to display along side it. Additionally I wanted it to be in the same scale which is approximately 1/48. I have already modeled the UFO in Rhino 3D to scale, its going to be about 270mm in diameter. My initial thought was to get single instances of the components printed and then mold and cast them, however the printing costs are prohibitive to say the least and I really don't want to buy my own printer. So I have begun fabricating the singular instances in preparation for the aforementioned molding and casting. The discs at top (9 in all, but I ran out of the right thickness plastic) will form the profile of the central core cone, will be infilled with Styrofoam (on order) which will be cut and sanded to the discs, sealed with PVA and then painted possibly with a self levelling resin, not sure yet. The main base cone will be constructed in the same way. I have created one petal and one vane , although the other side of the vane requires the corrugations to be added, again I ran out of the appropriate size half rod...more on order. The profile for both vane and petal was extracted from the 3d modeller complete with dimensions, printed out at 1:1 and spray mounted to the appropriate sized plastic card and cut out. The upper and lower 'domes' which are clear will be shaped from Styrofoam and then vacuum-formed. I wasn't intending on doing a WIP for this but as it will involve me learning some new skills, I thought it might be of interest to others to see....when it all goes horribly wrong. More later, Mark. 10 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 15, 2019 Share Posted November 15, 2019 (edited) 5 hours ago, MarkSH said: have created one petal and one vane The Petal looks like a Guitar pick ? Could you save time and stress by using them ? Edited November 15, 2019 by Corsairfoxfouruncle 1 Link to comment Share on other sites More sharing options...
Gorby Posted November 16, 2019 Share Posted November 16, 2019 10 hours ago, Corsairfoxfouruncle said: The Petal looks like a Guitar pick ? Could you save time and stress by using them ? Yes I thought they looked like plectrums, but I suppose the size of them is dependant on the scale of this build. Looks like a very interesting project. 1 Link to comment Share on other sites More sharing options...
MarkSH Posted November 16, 2019 Author Share Posted November 16, 2019 Yes the petal is just a little bit too large at 40x35mm to be an effective plectrum, certainly at 3mm thick you'd probably break a few strings. 1 1 Link to comment Share on other sites More sharing options...
Gimme Shelter Posted November 20, 2019 Share Posted November 20, 2019 looking forward to seeing your progress on this project Link to comment Share on other sites More sharing options...
MarkSH Posted November 21, 2019 Author Share Posted November 21, 2019 Evening all, A very small update on the UFO; more styrene sheet arrived yesterday so I could finish cutting out the central cone discs and started the same for the base cone, the key part is what I'm calling the reference disc which will have all the slots for locating the vanes, a quick test fit below: The disc is 2mm plastic so cutting out the slots is tiresome to say the least and is making my hand go numb with the pressure - 4 down 12 to go!. The vane and petal are individually complete so after some tidying and smoothing out I can have a go at molding and casting each of them. A tray mold will work for the petal but the vane has detail on both sides so will probably have to be a two piece job. Another quick test run with all the discs for the central cone offered up, seems to fit quite well, although a couple of the discs need adjusting as the steps seem a little out. Also I'll need to use the 3d model to generate some templates to ensure I get the draft angles for both cones right. The Styrofoam arrived today so I can also start filling in the gaps and shaping, but first its a trip to the LMS tomorrow to get some brass tube as a more substantial central support and some UHU to bond it all. Cheers, Mark. 8 Link to comment Share on other sites More sharing options...
DalekCheese Posted November 22, 2019 Share Posted November 22, 2019 Looking good! Link to comment Share on other sites More sharing options...
MarkSH Posted November 23, 2019 Author Share Posted November 23, 2019 Afternoon all, I have finished cutting the slots in the base cone ref disc and have stuck the plastic and foam discs together with epoxy, using a piece of brass tube as a core (now removed). Once the epoxy had set I could begin with a first trim of the foam before starting the rough sanding with some coarse sand paper: First trim. Rough sanding pass. More sanding yet required but quite happy so far... Cheers, Mark. 6 Link to comment Share on other sites More sharing options...
Yorkshire man Posted November 23, 2019 Share Posted November 23, 2019 (edited) Is this a new episode of The Great British Bake Off? Nice sponge cake.🎂 Edited November 25, 2019 by Yorkshire man correction Link to comment Share on other sites More sharing options...
MarkSH Posted November 25, 2019 Author Share Posted November 25, 2019 Hi all, So my entry into the great British bake-off (thanks @Yorkshire man) is now glazed PVA'd and ready for a few coats of brushed on slow cure resin. I have now moved on to the central cone which I am calling a Coner Kebab: The same process will be followed as for the sponge cake except for the addition of some chili sauce. I have also completed the mold for the 'petals' ….. ...so a bit of casting can be gotten on with now. Cheers, Mark. 4 Link to comment Share on other sites More sharing options...
MarkSH Posted November 25, 2019 Author Share Posted November 25, 2019 Small update, I have carried out the first sanding pass on the 'coner kebab', not too bad, but I got the diameter or the height position of disc 7 wrong and I'll have to address the issue when it's covered in resin and can be filled, generally the draft angle is pretty good: Cheers, Mark. 7 Link to comment Share on other sites More sharing options...
Yorkshire man Posted November 25, 2019 Share Posted November 25, 2019 (edited) Mmmmmm nice multi-layered Martian sponge and Clangers pink merangue, deeeeeelicious ! Edited November 28, 2019 by Yorkshire man Link to comment Share on other sites More sharing options...
Tzulscha Posted January 17, 2020 Share Posted January 17, 2020 On 25/11/2019 at 16:48, Yorkshire man said: Mmmmmm nice multi-layered Martian sponge and Clangers pink merangue, deeeeeelicious ! The Meringue looks a bit.. um.. chewy... The UFO is lookin' good though. I'll be interested in seeing how this all comes out! Link to comment Share on other sites More sharing options...
