mirage Posted November 11, 2019 Share Posted November 11, 2019 (edited) Hi i'm a italian modeller end i decided to modify a Pocher F40 model and imagine how it could be today. The main muse is a revisitation of the F40 designed by designer Samir Sadikhov. My intention is to maintain almost all of the pocher kit, modifying it to make it similar to the designer's project, similar because I will also use mine. Edited November 11, 2019 by mirage 4 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 (edited) ok,this is the scrap, given to me, from where I started. Spoiler Edited November 11, 2019 by mirage 2 Link to comment Share on other sites More sharing options...
bzn20 Posted November 11, 2019 Share Posted November 11, 2019 That looks good ,really good . Look forward to this . Takes a whole workmate to hold it . That's going to be a new body isn't it ? Strewth . Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 no, no modification of the original. cutting work begins ... 3 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 (edited) the works on the front proceed, the shapes become more and more similar to those of the drawing, however, I decided to leave the two air intakes on the hood instead of one as proposed by the designer ... Edited November 11, 2019 by mirage 2 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I continue to give the new shapes on the upper part of the front hood, I gave the first coat of putty and sanded. 4 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I cut across the highlighted points 2 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 once the general lines are obtained, the crowning works begin. As a method I adopt the system of applying brass rods to have the curvature guidelines, by doing so sanding I will have the curve line as a reference . in the fenders I remove the excess from the inside ... 3 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 to be continued... 1 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I continue to model... 3 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 (edited) I started to rebuild the lower part of the front, again with the brass rod technique I found the right curve by welding the two ends (with cyan and bicarbonate) in the same point ... Edited November 11, 2019 by mirage 2 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 here I dedicated myself to the wheel arch radius considering the new wheel footprint and also calculating the new ground clearance. 4 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I gave the first draft on the front, at the end I will mount the carbon splitter that I will realize once I finish modeling the whole body ... 6 Link to comment Share on other sites More sharing options...
PROPELLER Posted November 11, 2019 Share Posted November 11, 2019 What a challenge! Very good start too! Good luck sir.... Dan. Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I made the small central ribs. The procedure is always that of the rough coat with reference brass rod and final application of plasticard from 0.3. it's just sketched 3 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 5 minutes ago, PROPELLER said: What a challenge! Very good start too! Good luck sir.... Dan. thank you very much... Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I continue to sketch the sides.. ... I welded the bonnet because of the shapes the gas filler will be on the top so only the inner part will open. Then the usual technique with the brass rod to recreate the shapes. 2 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I continue to form side lines ... ... plasticard on guide rod ... 2 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 ... to finish I recreated the side of the wing with cyan + bicarbonate. ... resistance test of the compound. 4 Link to comment Share on other sites More sharing options...
Sabrejet Posted November 11, 2019 Share Posted November 11, 2019 Fast work! Some brave cutting and shutting here and so far it looks impressive! Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 5 minutes ago, Sabrejet said: Fast work! Some brave cutting and shutting here and so far it looks impressive! thanks, actually with the jobs I'm ahead, I'll try to post the work done so far to catch up ... Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I sketched the new lines of the hood ... ... and the left door ... 2 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I continue to give the shapes, today's work has consisted of giving harmony, with the right ribs, to the roof and the bonnet ... 1 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 I started to shape the back 1 Link to comment Share on other sites More sharing options...
mirage Posted November 11, 2019 Author Share Posted November 11, 2019 ... I continue to form the back, for this part I used a profile for pvc tiles that has the right camber that I needed, and then adapt it to the model ... 6 Link to comment Share on other sites More sharing options...
