A small part I know, but I’m struggling to paint the exhaust system to look rusty. The instructions suggest silver, but I don’t think that’s right. So I need to create rusty steel.
Any help will be most appreciated.
Exhausts really did start out as bright steel.  So if you are doing a model in an immaculate scheme, fresh from the factory, then there should be little heat staining.  On the other hand, iof you are doing a subject that has been well used, then look to the recent thread on the Beaufighter Mk.I for guidance.
20 minutes ago, dogsbody said:
Rusty or heat-stained?
Chris
Hadn’t thought of that. So, rusty for the whole system, but with perhaps heat staining on the ends of the silencer where the exhaust gas enters.
Def not factory fresh. Thanks will have a look.
Spitfires don't have silencers.  The exhausts coming from each cylinder is either combined with its neighbour into six pipes (Mk.V) or taken individually to the exterior.
Sorry, my mistake, but I’m building a WW1 MK V tank.
I knew that.
Chris
43 minutes ago, dogsbody said:
I knew that.
Chris
Chris.
I knew you did, but.......
Jon
2 hours ago, Graham Boak said:
OOps.  I didn't...  Sorry.  Still, I think most of the answer was still sensible - or at least I hope so.
They are, indeed. I’m still struggling with the finish, lots of experiments.
The top run of the exhaust pipe across the hull top might have been wrapped with asbestos "bandage". Some Mk IVs certainly had this. I used thin masking tape on one of my Mk IVs.
It is plausible that the exhaust pipes might have been galvanised, one of the few corrosion protection techniques then available. A dull metallic grey rather than bright.
My thoughts are the same. Dull grey and then dry brushed dull red.
Bovington's MkV does not currently have a wrapped exhaust, but the pipe looks a little too new and bright to be 101/2 years old and is possibly not original bearing in mind that it was parked outside for many years.  What is there now is dull silver and potentially galvanised.  Unlike the Mk IV there are no factory variations for the Mk V as they were all built by BRCW, by then under Metroplitan control.
  • 3 weeks later...
