Linescriber Posted November 3, 2019 Share Posted November 3, 2019 Guys wanted to check with the Soviet aircraft experts here if a Tu 134 can be converted to a Tu 124 by lopping of the rear nacelle engines and high tail (basically use the fuselage of the 134) and add wing root engines and a classict ail at the back of the fuselage?? Link to comment Share on other sites More sharing options...
Graham Boak Posted November 3, 2019 Share Posted November 3, 2019 Methinks that if you move the heavy engines from the middle of the plane to the rear, you are going to have to move the wing as well. Other changes will have to be left to the better informed in the particular case. Link to comment Share on other sites More sharing options...
