Well, after a lot of flip flopping between ideas as to what my next Canberra build should be I've finally settled on the B(I)6, I feel quite enthusiastic about this, so all being well I should see it through to the end! I've yet to decide what weapon fit to go for, the gun pack or a Bucket of Sunshine in the shape of a Red Beard bomb. either way, I plan on doing a full job on the Bomb bay. The subject will be, WT316, but in an earlier time than this photo of her, but it will look similar.
This is a photo of the resin extras I've earmarked for the build. The black items on the right are 3D printed bomb beam and controle runs. These were done by a friend in the USA.
Well that didn't take long! A change of plan, I've ditched the resin wheels and gon back to the kit ones, the reason? To build 316 as I'm intending to I needed to use the early mod 'Big wheel' which has a slightly diferant hub to the later style, not a big job thankfully, but I thought I'd be better off using the kit parts rather than the resin ones.
As you will see in the following photo the only difference between the early and late wheel is four extra holes, these were later deleted by Dunlop as it was found they were prone to stress fractures.
Next step, all the usual re engraving and corrections.
John
Edited by canberra kid
Typo
Always good to see an RAF Canberra, in any guise. Particularly 1/48!
I have two in my stash, I want to do one as a 100 sqn TT18 (if I can find decals!) and one as an early one like this. I'll be watching with interest ...
Thanks, good to have your company! It's good to be back in the saddle again, I've been suffering from a mojo loss. So,on we go, the next job, the first of many additions, for some reason the tail planes are devoid of any detail, which would have been fine had the rest of the kit been the same but alas it isn't, so we have two choices, fill all the other detail on the kit, which I've done a few times or add what's missing, which is the way I go now.
The tail plains as they come
after marking out
and after scribing the detail, this process doesn't take too long thankfully.
The next phase will be doing the same with the wings.
John
I've managed to grab a bit of time to do some more corrections and additions, I've marked out the missing panel detail, and scribbled out the fictitious ones, I'm hoping to scribe them tomorrow.
John
Good to see you back at work John. Looking forward -as ever - to watching and learning.
Your scribing always looks so damn neat - do you mind me asking what process you follow to get such high class results?
John
Just a quick point,  If I recall correctly was the only squadron to fly the Canberra B(I).6 variant was 213 based in Germany.  The German based interdictors were only armed with the US Mk 7 Nuclear weapon, the Red Beards were only used By the RAF in the middle and far east on Canberra.
Selwyn
Edited by Selwyn
Selwyn
Good spot Selwyn thanks, I probably would have got to that conclusion eventually, I'll need to do the bomb door mod's if I do fit the Mk.7, though I've not decided yet what fit she'll have.
John
Hi Tony, it's good to be back too, thanks for the compliment, I can't really think I do anything special, I use a Tamiya scriber, which I think is actually made by P-cutter? I recently got another make to try out but I'm finding it very scratchy. I always mark out the lines in pencil, then use a the Scale Models steel ruler as the guide, I use it with the graduations facing down if I do it with them facing up I find the etched marks make the blade run a bit jaded, I hope that helps?
John
Talking of scribing, the wings are done, the gold areas are local skin strengthening where the wing pylons are mounted.
John
I've had a stab at doing a simpleler fix for the tail plain issue, what I've done is field away the flat area on the top side of the tail plain stub, more to follow line of the top of the tail plains, this has the benefit of creating more fuselage between the bottom of the fin and the tail plains. The sketch below hopefully illustrates what I've done, the hatched area is what I've removed.
I don't know how well it shows on these photos. I've highlighted the before and after.
Before.
After
John
Excellent. Another masterclass in Canberra modelling :)
Definitely... Im ashamed I've only just discovered this.
I'll try by best! :)
No problem, you've not missed much yet, glad you fund it in the end! :)
John
I've done more work on the tail end, not only the work on the top, but as you can see I've also moved the tail plain's back a touch so I can correct the line of the leading edge,
I've also opened up the gap under the tail plains the allows them to move up and down on the real aircraft, the molded on part of the elevator on the rear fuselage. fairing has gone too. I've added the rear downward identification light.
The next job moving forward will be the ident lights in front of the bomb bay and the secondary bomb aimers window under the nose.
John
Very nice work.
Mine's residing on the shelf of doom, and I can already see some more fettling on it, to introduce some of the fixes you are sharing!
cheers
I've just been checking through my B.6/B(I)6 AP and it turns out the B(I)6 didn't have the downward ident lights in between the front of the bomb bay and nose wheel well, so that's saved me a big job! The secondary bomb aimers window is now added.
I've also managed a bit more work on the wing, I've drilled all the various intakes in the leading edge on both wings. The wings have also had all the filling rubbed down and scribing re doing where necessary. They are at a point now where they can be closed up.
John
16 minutes ago, Jinxman said:
Very nice work.
cheers
Sorry to hear that Jinxman, the shelf of doom is no place for a Canberra! I hope my effort relights the fire and gets her back on the production line.
John
I've done the filling on the fuselage, when that's rubbed down I can move the tail bumper forward, and do some scribing. The fun never ends!
John
John
Dragged the fuselage out to have a look - I think I stalled before with the nose glazing, as I was trying to mate an Alley Cat part to the kit part, and the contours didn't match very well.
She's now sat there awaiting my attention - couple of KUTAs to get out the way and she might make a re-appearance. 😀
More delightful increments John. :clap2:
Had the pleasure of crawling around a PR.9 up at the Ulster Aviation Society last weekend and astonished at the sheer number of surface details all around the airframe that I simply hadn't noticed in photos!
Nice work!
And project!!
That's more like it! Good to hear, I've never bothered with the Ally Cat glassing, it always seamed a lot of trouble for not much return. What are you building it as?
John
