Frah2o
1/8 VW GOLF GTI MK2 stance project
Hi, to everybody.
I’m italian and a big vw fan (i have a couple of mk3)
I started 2 years ago the collection of this 1/8 golf GTI (100 issues) only for italian market and the collection is now terminated......my model not (some stop due to work on a couple of 1/8 Delta WRC)
I’ve started a tuned/stanced project but i decided to remade it with extra details to add more realism to my model.
I work on this model when I'll made some work pause on Mclarem
Here the status (i've stated to rework in July)
The engine kit i think is a PB engine
Here i started to work on block.
I made hole for engine lift
I scribed the head that was absent
I now repainted the block in iron mica, the head will be painted in allumium block.
If you want and if is it possible i want to share with you my building
I repainted the head with a silfer leaf paint, and whole gearbox and differential in gloss alluminium
I added the wire from distributur to ignition coil and i full remade the plug wire in with red cable.
I reapinted in green the gearbox cap, in the future i'll put a vw logo waterslide decal
I dediced to fill the inside wheel arch with putty to give more deep and realism.
I started the work on engne bay. The kit give engine bay separeted from chassis and the junction with chassis is really worst
I "welded" the engine bay and i started to rebuilt the spar that was all wrong in the model (just notched the chassis)
To fit the absorber, i opned the top mount sunspesion to have right access on ammo screw
FInally i try a first check for the inside clearence between chassis and and engine.
Very cool, I’ll be watching this. I had a mk2 a while back, I’ll try and dig a pic out. It was a nightmare as I couldn’t go over speed bumps, pot holes or even a hump back bridge by where I lived 😂
had to drive miles out of my way to get home from work 😂
and forget about multi-story carparks
😂 I'm in your same condition with my mk3 (with chassis notched)....but low is a way of life (specially on a vw) 🥰
In the past week I continued the work on engine bay. With fiber bond iI filled the self made side pods
I self made a new water tank bracket with alu stripe and I filled the hole on side strut
With the help of Lego bricks I made the missed servobrake and i made a new fitting sistem on engine firewall
I started to selfmade (just finish the final shape) a new clutch lever on gearbox to replicate the future clutch cable (totally missed in the kit)
Not anymore, I’ve a MK7 estate family car, mk6 tai family car and my mk1 is going to be 100% original when finished
These are my sisters GTI 93 and Tdi 94. The white is for treffen, the black isa dalily. I bought a Fujimi kit 1/24 to replicate my 1:1 daily....the hardest part of project will be to find the Lorinser rims.
Frah - Keep posting!  Following with great interest.  I wish I had the luxury of looking directly at the real thing.  Great work both model and full scale.
Edited by JCH
😁 Yes JCH i continued in posting.....i don't post in one shoot all progress because i s too much, but i'm very glad to share with you my work
I coated in primer the engine bay to highlight the faults.
I decided to eliminate the wiper tank. I'll fitted an extra engine oil cooling radiator. I remade a modified radiator and i self made a first version of cooling duct.
I checked the clearence between bonnet and radiator duct...It's too near. I decided to remade a new shape of duct.
I added joint to radiator for future braided hose
I start to modified the inside high beam projector to create a Venturi duct for cooling the extra radiator. I removed the fluted glass and i fitted a metal mesh. Before to finish this work I need to rework in the future the headlight for fit the mesh properly.
Before to proceed with other engine or gearbox details, i remade whole engine mount system.
The kit has only 1 (the gearbox side and also is not completed) of 3 engine mount.
I remade my best for my skills, the 3 engine mount.
I reinforced the front struts and i used a modified lego brick to match the right angle for front mount
The rear (timing belt side) was totally missing.
I self made an alu bracket.
The two rear engine mount are fixed on subframe to make easier the future fitting of subframe and arms.
