B-26B-50 Invader (48281) 1:48
So if the armour's fitted, it should be flush at the upper edge of the fairing? Effectively you have a set of raised scabbed-on armor panels highlighted by the blue areas on the diagram above, protecting the cockpit and other key areas, that are 0.2mm/8 thou thick in 1/48 with a fairing blending them back to the regular skin surface?
best,
M.
Yes the fairings are flush at the armor. That's what I have been trying to say. Look at the photos I posted. The fairing is supposed to be angled. Not how they did it. They also left off the added armor all together. I don't think they had an actual example to study.
Again look at the Monogram kit. It is correct.
Alan
  • 1 month later...
Alan
Hello Alan,
i took a look at the monogram kit and you are right about those details..
I have both kits and when you compare them the fuselage of the Monogram is a little more on the fat side compared to the ICM one but i still have to measure both to see wich is correct!
the engine nacelles on the other hand are a little more fatter on the ICM than on the Monogram....the shape of the nose on the ICM is at least correct in shape but is shorter than the Monogram.
As i said i have to look into it which i am going to do ...though i surely think that both kits wil look fine when build!
cheers, Jan
did some further research on the nacelles and those from ICM look more correct in shape as those from monogram as these are a little to shallow at the rear...
  • 3 weeks later...
On 12/30/2019 at 12:55 PM, janneman36 said:
Hello Alan,
cheers, Jan
Yes it is (fat) among other things. Quickboost makes corrected nacelles for the Monogram kit.
Also it looks like the MG kits props are better than ICM's. ICM's are too pointy.
Mind you. I am not bashing ICM's. Their faults are minor.
Also I should have mentioned earlier that there is/ has been 3 A-26's at my local airport.
One belongs to the air museum, that I have taken part with helping in it's restoration off and on since 1992. The other 2 are owned by local owners or at least were. One went away years ago and the 3rd was a very recent restoration and was in last January's Air Classics magazine. I just found out it too was sold recently.
I went out there recently and got photos of the museum's Invader. A lot of the armor is missing. But I heard they have sourced some from somewhere for it.
Alan
City of Santa Rosa was a Korean war A-26. This one is just painted up as it.
You can see the step of the remaining armor from the windscreen forward.
In this shot, you can see the difference in the nose to fuselage step because of the missing armor.
Right front forward. Armor missing closest to camera. See the remaining armor.
This is how it should be on the ICM kit. The right side armor steps up to the lower front of the wing fairing. Not all the way to the rear of the wing like on the port side.
Lower right front. Beveled edge no wood strip where armor ends.
Right front. The cutout is where the round cover would be.
@sinistervampire319 they both have their faults  though i think at the moment that the ICM is more correct..
I do find it a pitty that they had made these mistakes with the armor on the sides, this is the biggest issue to overcome as this is for a pretty prominent feature!
Great pics Alan thanks.
Cheers, Jan
