Jabba
Type 69-II
Looks like impressive progress to me Jabba and great idea about getting the metal tracks! They will really add to the appearance. :thumbsup:
Kind regards,
Stix
A small update of my progress. The turret is mainly build and what a pain. Too many small parts that are attached to the sprue with too large a gate. I have also made up the bar amour that goes around the turret, but I have not photo'd these at the moment as they are sitting on a piece of paper with their code letter next to them.  These will be added soon. I also do not like the brown dust cover at the front around the gun barrel as it does not go where it is meant to go, although I think I have got in the right place now and will be glued there.
resized_a21020a4-6a32-46b6-9f3a-5ef97ddc
resized_584ae95d-d53d-4af7-ab87-df1c418e
Hi Jabba. Great to see you are still making progress - despite the issues. I must admit I do find the choice of location and size of sprue gates annoying/surprising at times. Even in the Tamiya kit I'm building for this GB there's been a couple of parts I've struggled not to break cutting them off the sprues - and in fact did break on eof the finer ones.
Good luck with the rest! 🤞
Kind regards,
Stix
Thank you very much.
Now the turret with the bar armour fitted. Some parts do not fit correctly fully even with a little adjustment here and there, but that is the way the cookie crumbles as they are staying that way.
resized_caee334f-89ea-4620-8f48-b119a6ff
resized_e92a14b4-d4ce-4230-80b7-d38465e8
resized_3ace2ba2-f2e7-454b-a4b6-2b763afb
Wow! Very impressive detailing!  Once again it's looking excellent despite the fit issues.
Kind regards,
Stix
Thanks Craig, yes it is a lot busier than I am normally used to.
A small update in that I have got some paint on the model, and added the wheels. On good point about the kit is that the tyres are separate from the wheel making painting a whole lot easier. I have also started on the tracks, and I am a little worried about fitting them around the sprocket at one end as it is close to the wheel cover. I think a little persuasion will do the trick. The kit comes with two styles of machine guns, one being a Chinese Type-54 MG, but I am not sure which one I should actually use. Anyone have any idea? A little weathering is to be done, I am thinking about the grills on the top, and is the square slot on one side an exhaust?
More later.
resized_27ac26f9-8540-489f-a07e-31ac0df9
resized_345b1eee-f800-4467-8bfd-cc62257d
resized_5483de07-7c64-4ac9-97f4-f0c910c4
resized_0c76e33e-5d92-4b78-866b-2979600b
resized_1ec89708-c37b-48df-9a25-7becf4be
resized_76fcc340-2bab-4b1b-abbb-030e33b8
Looking good with a coat of paint on Jabba, very nice indeed.
I'm no expert but I would have thought that the Chinese Type 54 MG was the one most likely used on a Type-69 tank.
That is what I was thinking using the equipment that they were provided with (if it was by the Chinese), something akin to RAF Chinooks using the guns given by Boeing rather than using GPMGs.
Hi Jabba. Great to see it with the paint going on - it really brings it all together. And that turret looks really fantastic. I love all the extra detail. :thumbsup:
Kind regards,
Stix
A slight update, but with no pictures as my camera ran out of battery just as I started to take them. I have applied the decals, a wash (hopefully not too much as I never done this before) and have made up the tracks. I may have made the tracks a bit too long at the moment, but I think that I can adjust them. I am now putting the camera battery on charge and hopefully there will be some pictures in the next day or so.
Now with the camera battery charged up some pictures.
The Hull.
resized_07eacd9e-d76b-4eed-81cc-e0b14450
resized_0a1f61ba-773b-4b70-9db2-77cc3579
resized_14606b83-6c46-4990-a50e-fba70df0
resized_c1c7716f-11e4-4478-8436-9d40c721
The Turret.
resized_35300e72-b8f5-4dad-8c8f-dc2879b0
resized_61712f19-940e-4d02-8842-9f6948c3
The Tracks.
resized_cde0f0df-5d50-4be8-bd74-2b668f21
The wash looks to have pulled the detail out beautiflly! :thumbsup:
Kind regards,
Stix
2 hours ago, Silenoz said:
 hopefully some dull clear on the shiny decal on the barrel.
Thanks for pointing that out as I had not noticed it. I will be doing some dry brushing this evening, so hopefully that get that sorted.
Thanks Craig.
Almost there. I was hoping to get this finished this weekend, but a few things did not really go to plan. I fitted the metal tracks fine on Sat afternoon, and thought that I would be able to fit the side skirts and such like in the evening. On one side where the skirt fits around the exhaust, the cut out was not big enough so I made the gap a bit bigger. Then the pegs that would help it have a better hold to the rest of the wheel cover at the rear were either too big or the new tracks were too wide. After cutting this down to size it fitted in a reasonable fashion, so I stuck this skirt on or so I thought. On the other side the same thing happened with the peg at the rear so this again was adjusted. This was then stuck on, but as the fit on both side was bulging slightly in several places on both sides I decided that some clamping was required. Four clamps were fitted and it was left over night to dry. In the morning the clamps were removed only to find that there were still some gaps, so more glue and clamps fitted again. Later in the evening I removed the clamps only to find that one side at the front did not match up with the edge of the upper part. So this was de-stuck, re-positioned, re-glued and clamped again. the clamp was removed that this morning and all was good. Also whilst having a general look about the hull, I noticed that one of the covers over the driver windows was missing and the other was just about hanging on. So a new one was made, and the other was re-stuck on. I still want to add to add some weathering powder to the tracks which I will do tonight. Sorry tha the photos are not as good as I hoped that they should be.
resized_4401e71d-464c-478f-8f51-470157c7
resized_9f3c699e-66ee-4607-b354-e3059ff6
resized_519f896e-a0b9-49b1-ba66-fdf3e944
resized_4b8faf2d-942a-4d00-9a76-e7953a03
resized_3fb78d96-37b8-499b-aae4-d2672c75
resized_b9c5154f-a92b-4031-89b0-1f952bd3
resized_469ab80a-6bd4-4f0a-9d77-1a23ed0b
resized_1894a69d-c8cd-4c27-ab9a-c94b67bf
Hi Jabba. Sounds like you have been having a bit of your kit fighting back but I'm glad you managed to get it sorted. Looks like it's coming together really well now. Hope you manage to get it finished in the near future.
Kind regards,
Stix
Fantastic news Jabba. I'm really looking forward to seeing the photos of the finished tank!
Kind regards,
Stix
Altogether now. Putting the turret on was a slight problem in itself. It fitted in the hole provided, but would not turn, and the sound of cracking of the bar armour made me stop moving it more. So I scraped off the paint on the inside of the hull, still no turning, then the turret with the same story. So I sliced some plastic from the tab on the turret so that there was clearance between the turret and the hull, and this worked. Apart from the final fitting of the last few parts this has been an enjoyable build and I would like the thank all that gave advise during the build.
resized_f474b53c-baba-4a4e-9697-0a8f6728
resized_eeba6e40-ac20-41dc-83cb-df0f9657
resized_0f38cb02-b4e7-4ac6-95e9-8fac31c4
resized_fdcdc1bc-9a98-4298-88fb-98020b77
resized_dd0fcfff-dcfe-4ea8-841d-729f84d1
resized_1204d941-e7c8-4293-8b43-cd06df1e
resized_80711ee6-4bfb-4066-a9c6-2176b146
resized_51eece98-d46f-4c00-a839-fa3a044c
resized_7ab5abb3-7f46-4227-9bac-3998abe7
