Reini78
Lend-Lease...1/48 Supermarine Spitfire LF.IXe Soviet Airforce/PVO
Very nice choice - a PVO (Air Defence) Mk.IX. That's one I want to do myself, in 1/72nd scale.
Regards,
Jason
Looks good to me, must get around to building a VVS one sometime in the future.
Dennis
We´ve seen there´s some discussion about the lightning machine on the web, clipped or no clipped wing tips, e wing or c wing...you see all sorts of versions as models, profiles and decals.
My dad now reconsidered and will do this scheme from the AML sheet
48870612966_491153e8ea_b.jpgAMLD72018D by grimreaper110, auf Flickr
Your dad seems to have a Soviet theme running lately. No bad thing in my opinion :D
Wasn´t intended, but often one model leads to another and suddenly there´s an ongoing theme 😀
The Spit will be the last Soviet/Russian model this year.
But most probably the IIAF and FAR theme will continue...not sure yet.
Again, no bad thing :thumbsup:
On 8/10/2019 at 16:34, Reini78 said:
gonna be "white lightning"
48865606601_d662abb6da_b.jpgDSC_0002 by grimreaper110, auf Flickr
again...don't trust the profile...  AFAIK the there is not a decent photo.
But, most likely just post war,    as it seems that a lot of VVS types got repainted in in summer 45 (keep the ground crews busy?)  including Lend Lease types,  with mono coloured uppers....
see
But,  the VVS repaints post war are confirmed, and this maybe of interest, buried in the Sovietwarplanes site
http://massimotessitori.altervista.org/sovietwarplanes/board/index.php?topic=1031.msg17703#msg17703
VVS Spitfire IXe red 2 1948
Note this was 1948, the VVS carried on using Spitfires for sometime post war!
by this stage Green AMT-4 over AMT-7 blue undersides I'd suggest.  Note the coloured rudder trim tab
HTH
T
see
HTH
T
Already stumbled across this BM thread, one of the reasons my dad turned now to a different scheme.
Thanks for the info 😉
some detail painting in the cockpit
48884224047_d601ebcde0_h.jpgDSC_0001 by grimreaper110, auf Flickr
48883509348_c22f957868_h.jpgDSC_0002 by grimreaper110, auf Flickr
48884043671_10af365b1d_h.jpgDSC_0003 by grimreaper110, auf Flickr
The instruments have no detail and there is no decal provided in the kit, therefore my dad did some drybrushing to simulate some detail. Good enough, won´t see much with the closed fuselage.
48884043501_20f89a72d1_h.jpgDSC_0004 by grimreaper110, auf Flickr
fuselage glued together
48896837442_d40abaec84_b.jpgDSC_0001 by grimreaper110, auf Flickr
the ICM Spits need some more work...
48896837117_ef2cc16861_b.jpgDSC_0002 by grimreaper110, auf Flickr
removed the bulkhead and some parts of the engine again to make the fuselage halves fit better
48896112288_c24532be22_b.jpgDSC_0003 by grimreaper110, auf Flickr
already tested it, the cockpit "tub" fits into the fuselage without major problems
48896647916_25fe520b31_b.jpgDSC_0004 by grimreaper110, auf Flickr
48896647581_80b4341dfd_b.jpgDSC_0005 by grimreaper110, auf Flickr
and on to the wing
48896110863_96391a042d_b.jpgDSC_0007 by grimreaper110, auf Flickr
cockpit inserted, also inserted the engine firewall bulkhead again so that the lower fuselage has the correct width to fit the wing
48903438031_c52f9b3629_b.jpgDSC_0001 by grimreaper110, auf Flickr
seatbelt arrangement original style
48903646422_e47361cb5b_b.jpgDSC_0002 by grimreaper110, auf Flickr
filling and sanding orgy
48903437146_2f7e7a6b36_b.jpgDSC_0003 by grimreaper110, auf Flickr
48903436671_de98cf8b76_b.jpgDSC_0004 by grimreaper110, auf Flickr
DA CAPO!
My dad wasn´t satisfied anymore how the kit turned out so far. So it went into the trash and he started again with a Hasegawa kit, less problems and work.
48966538353_0213cc07f0_b.jpgDSC_0005 by grimreaper110, auf Flickr
48967085656_6b9f6dece1_b.jpgDSC_0006 by grimreaper110, auf Flickr
48967264502_a8db30e574_b.jpgDSC_0007 by grimreaper110, auf Flickr
48966537553_8cd0d71d9e_b.jpgDSC_0008 by grimreaper110, auf Flickr
