Silenoz 1,463 Posted October 2, 2019 Share Posted October 2, 2019 Mine will be armoured revovery vehicle based on the T-55 chassis. haven't decided yet on a camo version (green) or a forest fire fighting vehicle (bright red) Boxart: and the parts: And should hopefully build into: 5 Link to post Share on other sites
Hewy 9,301 Posted October 2, 2019 Share Posted October 2, 2019 I like that.looks a fine model kit 1 Link to post Share on other sites
PlaStix 21,754 Posted October 2, 2019 Share Posted October 2, 2019 Hi Silenoz and welcome to the T-55 STGB! As Glynn says above - that is a fine looking kit. It also looks like a lot of work and I'm really looking forward to seeing it in progress. Kind regards, Stix 1 Link to post Share on other sites
Silenoz 1,463 Posted October 5, 2019 Author Share Posted October 5, 2019 (edited) Thx, started cleaning up and identifying parts... Not an easy task because the instructions are minimal (not throwing a Stone, but for a 45€ kit...): And most parts resemble the drawing to the bare minimum. Also checking how to display this one with the dozer lowered or the crane up... All are cast fixed, so... To be continued Edited October 5, 2019 by Silenoz 2 Link to post Share on other sites
PlaStix 21,754 Posted October 5, 2019 Share Posted October 5, 2019 Yes those instructions do leave a lot to be desired! Looks like it could be fun! Kind regards, Stix Link to post Share on other sites
Silenoz 1,463 Posted October 14, 2019 Author Share Posted October 14, 2019 thx.. so after a lot of part cleaning, I am ready to start assembling the main parts: After mating the hull parts, the fender on this side looks ok. The other side is pretty thick in comparison: and after some scraping... and also the torsion bars. next up is checking the ground level, when all the wheels touch the ground, and starting to think about how to lower the dozerblade... It either that or the spade at the back and the arm of the crane in a raised position... 3 Link to post Share on other sites
PlaStix 21,754 Posted October 14, 2019 Share Posted October 14, 2019 Hi Silenoz. Great to see this is underway. It is going to be an incredible model but it is going to take some serious work! Kind regards, Stix 1 Link to post Share on other sites
Silenoz 1,463 Posted October 14, 2019 Author Share Posted October 14, 2019 I know, the fenders are a bit warped in all directions, so I'll try to heat them and straighten them up a bit. First getting the base allright, then ... 1 Link to post Share on other sites
Jabba 4,704 Posted October 15, 2019 Share Posted October 15, 2019 A good start. Those instructions do look the bare minimum. 1 Link to post Share on other sites
Silenoz 1,463 Posted October 16, 2019 Author Share Posted October 16, 2019 As stated above, the fenders were a bit warped. I tried to give an indication: Luckily we use this heatgun at work for electronics... pure gold result: the rear left fender got another treatment... but that became visible on the picture. so the warping shown there has been corrected... Next up, primer to check the filling of the seams and cleaning the casting membranes on the wheels 3 Link to post Share on other sites
PlaStix 21,754 Posted October 16, 2019 Share Posted October 16, 2019 Great that you have the heatgun to help with issues like the warped fenders. Very useful. And good luck with the wheel clean up! Kind regards, Stix 1 Link to post Share on other sites
Silenoz 1,463 Posted October 21, 2019 Author Share Posted October 21, 2019 (edited) Some more progress, albeit small... driving wheels cleaned up, had to enlarge some of the openings a lot as you can see (reworked + original, in that order): also still busy cleaning up the other openings in the wheels (over halfway, some of the small holes are cast shut, that makes it harder) to have some relieve from this, I started soldering the baseparts: The working platform. The threaded plate consists of a lower and and upper half, that need to be aligned carefully. also added some solder to the protruding parts, just in case not to lose these. the sidewalls. These have a rather ingenious construction, but I was a bit to fast. Thought I had to protrude the detail that was lowered to the other side with a needle, but it's a foldable box with an iner part with lowered detail, and an outer part with raised detail that fits as a glove... kuddos to Armada Hobby for this system, to bad their instructions are ... euhmm ... basic. The part with the bars needs some straightening, the PE was very hard to fold due to lack of material, hence the deformations, will try to correct it some more. And the the material boxes: So far so good, now I need to add a ton of these: to obtain this: these parts can hardly be picked up by tweezers, let alone being glued or soldered to a surface... after a half an our I ruined one, and attached one to... Looking at that last picture, I notice the wrong kind of tracks are included in this kit... The OMSH-kind are included: and in the picture they show the RMSH-kind Edited October 21, 2019 by Silenoz 2 Link to post Share on other sites
PlaStix 21,754 Posted October 21, 2019 Share Posted October 21, 2019 Wow! I do not know how you are able to work with such small parts in 1/72 - let alone it being PE parts! Impressive modelling! Kind regards, Stix Link to post Share on other sites
Silenoz 1,463 Posted October 21, 2019 Author Share Posted October 21, 2019 neh, just basic modeling. I'm coming from 1/144 aircraft... so this is "large"... From when I still had a lot of modelling time... https://www.scalemates.com/profiles/mate.php?id=11032&p=albums&album=11594&view=list 2 Link to post Share on other sites
Hewy 9,301 Posted October 21, 2019 Share Posted October 21, 2019 Good job on the tidying up of the moldings,a brave man too with solder on such small pe parts ,so far so good 1 Link to post Share on other sites
PlaStix 21,754 Posted October 28, 2019 Share Posted October 28, 2019 Hi Silenoz. Just checking if you have made any more progress with this project? Kind regards, Stix Link to post Share on other sites
Jabba 4,704 Posted October 30, 2019 Share Posted October 30, 2019 I thought that the slightly larger plastic parts on my build were troublesome, but these I think I would not have bothered. Hope all goes well in getting them fitted. Link to post Share on other sites
Silenoz 1,463 Posted October 30, 2019 Author Share Posted October 30, 2019 unfortunately not... traffic has upped it's amount of cars and last weeks travel time from work to home increased from 50min to 2h's daily... I don't know what's so hard to drive on a straight line on a freeway, but a lot people do have problems with that with regards to the increase in accidents lately. Just hope for myself I don't have to find it out... but that's what's limiting my modelling time... the job ( those little pieces at the moment) at hand is not something to rush... @Jabba: you can only try... If it doesn't work out, you can always say you tried... Link to post Share on other sites
Silenoz 1,463 Posted November 3, 2019 Author Share Posted November 3, 2019 (edited) just finished soldering the boxes... relieved, now only time to clean these up... tomorrow the whole story Edited November 4, 2019 by Silenoz 2 Link to post Share on other sites
Silenoz 1,463 Posted November 4, 2019 Author Share Posted November 4, 2019 (edited) so at least some progress: the platform received it's sidewalls and handles to lower these, sorry to disappoint the hardliners, nothing functional here: further some progress with the boxes: handles, latches and other stuff added: I start by cleaning the surface of the PE-parts with a glass fibre pen, solder adheres better that way. then I apply some (a tiny amount) flux (S39 from Griffon, but it's aggressive, need to look for a better solution) to the contact surface of the detail parts to have some tin there. It's better to do this now, because with these small parts, it won't be aesy after cutting them from the fret. On the box the same process, but bit really tiny amounts, so I squashed a tin-wire as flat as I could and then cut off some parts. The reason for this is to have control over the amount applied, but also, the lesser tin you use, the less easy they will move when soldering close to another part: then a tiny amount of flux on the right position of the box that makes the solder flow better, but also keeps it at it's place then some heat from the soldering iron: then it's time to release the parts from the fret, don't bother sneezing now... (did I mention these were tiny?) then it's time to pick these up (slightly wet toothpick) and position them (a tiny amount of flux aids a lot here) and heat them with the soldering iron. Here they aren't completely flat, so another heating session was necessary, and when they really don want to sit down, you can aid them a bit. first box ready: and when you get the hang of it, it goes really fast after that, so here's the rest of the family...: Edited November 4, 2019 by Silenoz 3 Link to post Share on other sites
diases 413 Posted November 4, 2019 Share Posted November 4, 2019 Nice work Silenoz. Always thought about soldering PE, as I'm never happy with the super glue finish I get (may just be me of course) What sort of solder iron do you use? I'm guessing its a adjustable temp level sort with a very fine tip. After seeing your results I may have to add one to my Christmas List. (might still go to Telford yet, still in two minds) Looking forward to seeing what the boxes look like after final fettling, and some paint. Cheers Paul 1 Link to post Share on other sites
Bullbasket 11,390 Posted November 4, 2019 Share Posted November 4, 2019 Well done with the soldered etched brass. It's not the easiest job in the world. John. 1 Link to post Share on other sites
Silenoz 1,463 Posted November 4, 2019 Author Share Posted November 4, 2019 19 minutes ago, diases said: Nice work Silenoz. Always thought about soldering PE, as I'm never happy with the super glue finish I get (may just be me of course) What sort of solder iron do you use? I'm guessing its a adjustable temp level sort with a very fine tip. After seeing your results I may have to add one to my Christmas List. (might still go to Telford yet, still in two minds) Looking forward to seeing what the boxes look like after final fettling, and some paint. Cheers Paul the sodering station I use is this one: https://www.velleman.eu/products/view/?id=349590 pretty basic, at 50-60€, but it does the job and doesn't cost a fortune... 6 minutes ago, Bullbasket said: Well done with the soldered etched brass. It's not the easiest job in the world. John. that depends, after some practice you'll think otherwise, but a lot of people are more scared then they should to do this. Time flies however when you'r busy, so keep an alarm close to keep track of time.. 1 Link to post Share on other sites
modelling minion 12,975 Posted November 4, 2019 Share Posted November 4, 2019 That is seriously good soldering, those boxes look excellent. 1 Link to post Share on other sites
diases 413 Posted November 4, 2019 Share Posted November 4, 2019 Cheers for the Info, silenoz. I'll have to invest in one, or try to steal one from work 1 Link to post Share on other sites
