Hamden Posted January 18, 2020 Share Posted January 18, 2020 Looks very good look forward to see it in paint Roger 1 Link to comment Share on other sites More sharing options...
ivan-o Posted January 18, 2020 Author Share Posted January 18, 2020 Thanks Roger just a matter of fixing the resin bits that were so fragile there was no chance of them surviving any handling of the kit at all 1 Link to comment Share on other sites More sharing options...
mbthejester Posted January 18, 2020 Share Posted January 18, 2020 Your Stolly looks brilliant good sir, I remember when they were still in use, the backfires were horrendous, saw one get flooded once, forgot to put splashboard out and drove into the Wasser, cab half filled lol and had to be towed out 1 Link to comment Share on other sites More sharing options...
Vaastav Posted January 19, 2020 Share Posted January 19, 2020 Lovely work. Resin must be a harder medium than injection I suppose. 1 Link to comment Share on other sites More sharing options...
ivan-o Posted January 19, 2020 Author Share Posted January 19, 2020 3 hours ago, Vaastav said: Lovely work. Resin must be a harder medium than injection I suppose. Thanks Vaastav, resin is certainly a different stuff to work with. There is no room for error glueing parts in place once it’s on its on! Small parts are very brittle so careful cutting off the block is needed. Saying all that the problems I have had with this kit have been mostly of my own making! so we live and learn. Ivan 1 Link to comment Share on other sites More sharing options...
ivan-o Posted January 19, 2020 Author Share Posted January 19, 2020 Primer on, just a few details to go now,mud flaps,headlights etc. Ivan 6 Link to comment Share on other sites More sharing options...
ivan-o Posted February 9, 2020 Author Share Posted February 9, 2020 Hi there, just a bit more done at last! Swim board on,the supports have yet to go on but they are a bit fragile so they will go on towards the end. The mud flap stays were replaced with wire as again first knock they would have been off! The exhaust is a bit fiddly,should have gone on before the wheels in hindsight. thanks for now, Ivan 4 Link to comment Share on other sites More sharing options...
ivan-o Posted March 1, 2020 Author Share Posted March 1, 2020 Just another small update! This kit is now starting to fight me every step off the wayfor every bit that’s put on another breaks. At the risk of repeating myself this kit is VERY brittle. not particularly happy with this but this side headlight is on. That’s it for now I’m going to have a beer Ivan 5 Link to comment Share on other sites More sharing options...
ivan-o Posted March 14, 2020 Author Share Posted March 14, 2020 Hi guys, another small update,the fight continues swim board supports had to be scratched. Mirror arms home made too,coming along slowly. Ivan 6 Link to comment Share on other sites More sharing options...
viper-30 Posted March 14, 2020 Share Posted March 14, 2020 Coming together mate.. well done with the perseverance.. 1 Link to comment Share on other sites More sharing options...
Bullbasket Posted March 15, 2020 Share Posted March 15, 2020 Nice work with the replacement parts Ivan. Some of those resin parts can be a real pain. John. Link to comment Share on other sites More sharing options...
ivan-o Posted March 15, 2020 Author Share Posted March 15, 2020 27 minutes ago, Bullbasket said: Nice work with the replacement parts Ivan. Some of those resin parts can be a real pain. John. Thanks John, It just seems the resin is old and brittle and in some cases if you look at it wrong it breaks! I have noticed that AA are now producing this kit on a order only basis perhaps that will help with the resin being new! Ivan 1 Link to comment Share on other sites More sharing options...
rayprit Posted March 15, 2020 Share Posted March 15, 2020 2 hours ago, ivan-o said: in some cases if you look at it wrong it breaks! You will find all Accurate Armour kits like this, old and new......I have built about 20-30 of them. When first produced all the small and delicate parts were cast in white metal...…...but Derek in his wisdom decided to go 100% resin and dispense with white metal, since then there has always been problems with the smaller, delicate parts...…..When I built the Centurion Bridgelayer with bridge there were so many broken parts that I ended up recasting a lot of the parts in White Metal. The Antar Mk3 with Sankey semi-Trailer was no different......just about everything around the front axle was so delicate and unbuildable so most was scratch built. Scammell Recovery was the same, warped chassis and lots of broken parts, Bedford RL Cargo, plus Bedford RL REME Recovery, Ferrets, Saladin, Champ, Humber 1 Ton......….all the same, ended up recasting a lot of parts in white metal. The only thing is, who else builds the Antar, Scammell Explorer, Centurion Bridgelayer, etc, etc? If you want these types of kits one has to persevere. They turned out great in the end, but a lot of work to get the desired results. 1 Link to comment Share on other sites More sharing options...
Hamden Posted March 15, 2020 Share Posted March 15, 2020 6 minutes ago, rayprit said: You will find all Accurate Armour kits like this, old and new......I have built about 20-30 of them. When first produced all the small and delicate parts were cast in white metal...…...but Derek in his wisdom decided to go 100% resin and dispense with white metal, since then there has always been problems with the smaller, delicate parts...…..When I built the Centurion Bridgelayer with bridge there were so many broken parts that I ended up recasting a lot of the parts in White Metal. The Antar Mk3 with Sankey semi-Trailer was no different......just about everything around the front axle was so delicate and unbuildable so most was scratch built. Scammell Recovery was the same, warped chassis and lots of broken parts, Bedford RL Cargo, plus Bedford RL REME Recovery, Ferrets, Saladin, Champ, Humber 1 Ton......….all the same, ended up recasting a lot of parts in white metal. The only thing is, who else builds the Antar, Scammell Explorer, Centurion Bridgelayer, etc, etc? If you want these types of kits one has to persevere. They turned out great in the end, but a lot of work to get the desired results. The AA CRARRV that I'm attempting is the same but as you say who else does these? Roger 2 Link to comment Share on other sites More sharing options...
Bullbasket Posted March 15, 2020 Share Posted March 15, 2020 1 hour ago, rayprit said: Bedford RL Cargo, plus Bedford RL REME Recovery Damn! I was thinking about getting one of these and turning it into a signals body, the one with a coffin over the cab. John. Link to comment Share on other sites More sharing options...
rayprit Posted March 15, 2020 Share Posted March 15, 2020 1 hour ago, Bullbasket said: Damn! I was thinking about getting one of these and turning it into a signals body, the one with a coffin over the cab. When I got around to building the RL Cargo, the chassis was really twisted - nothing that hot water didn't sort out, but the cab was completely buckled, impossible to straighten out window frames and door pillars from warpage...….possibly from storage at Accurate Armour...………….I contacted Derek at AA and he replaced it immediately...……….but, if you persist you will get there...…….after all, this is what we all call fun - isn't it? Sorry Ivan for the thread hijack...…... 1 Link to comment Share on other sites More sharing options...
ivan-o Posted March 15, 2020 Author Share Posted March 15, 2020 2 hours ago, rayprit said: When I got around to building the RL Cargo, the chassis was really twisted - nothing that hot water didn't sort out, but the cab was completely buckled, impossible to straighten out window frames and door pillars from warpage...….possibly from storage at Accurate Armour...………….I contacted Derek at AA and he replaced it immediately...……….but, if you persist you will get there...…….after all, this is what we all call fun - isn't it? Sorry Ivan for the thread hijack...…... Not to worry good to see I am not the only one having fun. 1 Link to comment Share on other sites More sharing options...
Dads203 Posted March 15, 2020 Share Posted March 15, 2020 It will be worth it in the end mate, the one thing with the AA kits is that they do take a lot more effort to get together over a normal IM kit. Scratching up bits are par for course which I think adds to their charm 1 Link to comment Share on other sites More sharing options...
ivan-o Posted March 28, 2020 Author Share Posted March 28, 2020 Hi guys, hope everyone is feeling fine! Bit of an update headlight guards on,the kit one is on the right and I wasn’t happy with the first effort to make the other one so had another go and I think that one has come out ok. That’s it for now,keep your distance! Ivan 4 Link to comment Share on other sites More sharing options...
ivan-o Posted March 28, 2020 Author Share Posted March 28, 2020 (edited) Oh NO!! just when you thing your winning I touched the kit guard and it shattered Edited March 28, 2020 by ivan-o Link to comment Share on other sites More sharing options...
Hamden Posted March 28, 2020 Share Posted March 28, 2020 Coming together slow but sure, Don't you just love AA's resin? Roger 1 Link to comment Share on other sites More sharing options...
ivan-o Posted March 29, 2020 Author Share Posted March 29, 2020 (edited) 11 hours ago, Hamden said: Coming together slow but sure, Don't you just love AA's resin? Roger It’s coming along one step forward two back! Calmed down now but looking at the photo the AA guard was already broken! What they are made off I don’t know but it’s like a crispy paper if that makes sense. And my missus said modelling is supposed to be relaxing Edited March 29, 2020 by ivan-o 1 Link to comment Share on other sites More sharing options...
Hamden Posted March 29, 2020 Share Posted March 29, 2020 1 hour ago, ivan-o said: What they are made off I don’t know but it’s like a crispy paper if that makes sense. Know what you mean I have the same trouble with a lot of the parts on the CRARRV I'm doing at the moment. Roger 1 Link to comment Share on other sites More sharing options...
ivan-o Posted March 29, 2020 Author Share Posted March 29, 2020 A bit of paint on the beast, The front light guards are not quite the same but that will be sorted at a later date! I just felt I had to move on a bit, the black will go on in an hour or so when the green is dry. Ivan 3 Link to comment Share on other sites More sharing options...
Dads203 Posted March 29, 2020 Share Posted March 29, 2020 The green looks bang on mate, looking forward to seeing it in the two tone 1 Link to comment Share on other sites More sharing options...
