ivan-o
AA Stalwart Mk 2
Ok here we go then,both sides are the same. This is stage 1&2 done and the only thing to comment on is the resin on the wishbones is a bit brittle!
progress will not be to rapid so bear with me please 😀
Edited by ivan-o
As this obviously is all resin it will need primed I am toying with going with a black primer to use as a preshade coat.
Good idea or should I stick with grey?
I've found black to work really well. Allows for a slightly lighter coverage of the green without worrying about going into all the corners and recesses, giving good depth and shadow effect. (Imo)
Great subject btw!
Great subject btw!
Me too for the same reason. I use Mr Finishing Surfacer 1500 Black, not sure how it adheres to resin though.
Roger.
I'll be interested just to see how an AA kit goes together as I've always fancied one of their Bedford RL's.
John.
Interesting project I'll follow along as well if you don't mind
          Roger
On 9/29/2019 at 5:41 PM, ivan-o said:
Thanks for all the interest 👍 just to expand a bit on the work I’ve done all the bits needed a bit of a clean up for flash and a bit of filing to get the wishbone blocks to fit the hull.TBH i forgot to actually take photos of the first bit 🤫 I’ll try to remember I am doing a WIP.
I will go with the black primer,I think the fun will come in the cab as there are lots of little bits the carpet monster will love.
More over the weekend,thanks
Ivan
Edited by ivan-o
Nice start ivan-o I have an AA K2 ambulance in the stash so will follow with interest.
I'm from Clare but moved to Nottingham 30 years ago, is the Royal Oak still going?
Hi guys,a bit more progress today. Slow going as all parts have to be cleaned and trimmed to fit.
Edited by ivan-o
One kit I really fancy getting hold of, looks like your typical AA offering, make sure you de grease the resin
before paint fella.
Dan
Cheers Dan it certainly is a kit not to hurry but as you I fancied this kit for years.AA did say only a few left so I took the plunge !😀
A bit more done, Torsion bars and rear hubs on. Front and middle hubs and steering gear next.
A fairly straightforward build today. The rear torsion bars were to long (cue the knife) but cut down ok!
I may have a problem coming with the steering bar pivot! It was fitted to the hull where the markings on the hull said but they fouled the torsion bar,minor surgery needed there,but they might be to high. Won’t know till I start the steering gear.
Ivan
Edited by ivan-o
Looks good so far, is there a lot of clean up to be done?
Hi guys a bit more done today,steering gear and wheels again very fiddly but strangely satisfying when the parts are fitted!
Cheers Ivan
Edited by ivan-o
Yes there is flash on all the parts but they do clean up well.
Starting to take shape Ivan, the AA kits are quite fun to pop together ;) they do keep you on your toes and help hone the build skills
I must be due an AA build soon :hmmm:
Cheers Dan, it certainly focuses the mind when you know when it’s stuck it really is stuck 😀
I can now do stuff the right way up now,not upside down 😉
Looking good, Ivan. Getting all those wheels to touch the ground is a challenge on this one!
I already like yours a lot better than my own Stalwart built from the AB kit in 1/76th...  😄
