F-22A Upgrades (for Hasegawa) 1:48
1:48 Eduard
Hasegawa released their Raptor just after the Academy released theirs, both having their pluses and minuses in the shape and detail department, but I'm guessing you went for the Hasegawa one if you're reading this. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.
The two sets are to be used inside the cockpit, and if you get the cockpit set it would be churlish to omit the seatbelts, so we'll review them together.
F-22A Interior (491014)
This set includes a nickel-plated pre-printed sheet and a slightly larger fret of bare brass, plus a small slip of acetate with the HUD glazing shapes printed upon it.  It contains a complete re-vamp of the main instrument panel in two layers, additional layers for the side consoles and their smaller panel sections, plus a new HUD into which the acetate is fitted.  The seat is overhauled with new detail where there was none previously, crew controls, more delicate side parts, and ejection ramp parts, all of which require a little modification/removal of existing details.  The cockpit sills and the turtle-deck behind the pilot is also detailed, as is the lip and interior of the canopy frame, all of which will be visible whether you leave the canopy open or not, but more so if open.
Seatbelts STEEL (FE1015)
This set on the thinner steel etch contains a full set of pre-printed crew belts with the new simulated "depth" achieved with shading, plus a set of yellow handles on the seat sides and between the pilot's knees for a quick getaway in an emergency.  If you've got the cockpit set above, you should probably put all the seat details together at the same time.
Review sample courtesy of
