bhouse Posted September 25, 2019 Share Posted September 25, 2019 9 hours ago, LDSModeller said: so very little if any chipping etc. would be on/around anchor I am sure the airmen pulled in the anchor and cable and placed it on the floor with great delicacy so as to avoid any possible scratching to the floor paint. In fact they probably protected it with their jackets to avoid any damage. (Edited to add) I should have added a smiley to this but I posted from my phone and almost lost the will to live waiting for them to load. I think you could moor a Sunderland faster... 1 8 Link to comment Share on other sites More sharing options...
Hamden Posted September 25, 2019 Share Posted September 25, 2019 Nice work on the interior Ced it's coming to life now Roger 1 Link to comment Share on other sites More sharing options...
Brandy Posted September 25, 2019 Share Posted September 25, 2019 I'll have a word with Officer Crabtree and have him work on his pronunciation. Ian 1 Link to comment Share on other sites More sharing options...
CedB Posted September 25, 2019 Author Share Posted September 25, 2019 5 hours ago, keefr22 said: I do love all the discussion about the details that would be invisible if you displayed it on the ground, let alone on the ceiling!! Thanks Keith - keeps my idle hands busy though eh? I enjoy it too… especially as it gets covered up! 5 hours ago, bhouse said: Looking great. Would some floor paint chipping under or around the anchor be appropriate? Thanks Brian… 5 hours ago, Heather Kay said: Let’s go the whole hog. Some seaweed and a dead fish should do it. … and Heather… 5 hours ago, Andwil said: Nah, just needs re-grouting. AW Thanks AW 4 hours ago, LDSModeller said: Except the anchor was only used at away bases (where normal mooring was not available), so very little if any chipping etc. would be on/around anchor Normal mooring was by way chain/rope through the mooring bollard to the mooring buoy in the Buoy Trot as in below [snip pic] Regards Alan Thanks Alan - very useful 3 hours ago, bhouse said: I am sure the airmen pulled in the anchor and cable and placed it on the floor with great delicacy so as to avoid any possible scratching to the floor paint. In fact they probably protected it with their jackets to avoid any damage. 2 hours ago, Hamden said: Nice work on the interior Ced it's coming to life now Roger Thanks Roger 1 hour ago, limeypilot said: I'll have a word with Officer Crabtree and have him work on his pronunciation. Ian Who? What?! The tube has arrived! "Aha!" I thought, "I can finally use the Dremel Workstation! If I turn it through 90o I can use a cutting disc to chop little bits off the tube!" Ah. If you rotate the holder the handle goes with it and the tool goes side to side… Rats. At least I can use it to drill out the window holes… Nope. Maximum diameter for the chuck is (check 'net for specs - nothing) er, less. Double rats. At least the tube fits in my mitre block: So the Workstation can go back to its usual role: A hanging place for the flexible shaft and somewhere to hang my magnifier. 3 1 1 1 Link to comment Share on other sites More sharing options...
CedB Posted September 25, 2019 Author Share Posted September 25, 2019 OK, 14 opening windows I count in Alan's post. I had said that the tube would fit in the mitre block but actually it sits a bit proud and it's easy to get things out of line: Rats. Luckily I have spare blades. I found it easier to tilt the blade at about 45o on the edge of the bench and gradually rotate it level. Soon done: I don't have a 5.2mm drill ( or a 7/32" one) but a 5.5mm drill still gives a tight fit. Two done: I can see there that I need to tidy up the edges a bit more and will do so on the others. I've also dobbed some Klear in the panel lines / rivets around there; can you see? 12 Link to comment Share on other sites More sharing options...
Biggles87 Posted September 25, 2019 Share Posted September 25, 2019 Great razor saws but very brittle blades, I have one that looks exactly like that. I’m greatly impressed by your Dremel equipment, it makes mine look like something you would take to the antiques roadshow so is probably worth a lot of money. Toodle pip mi old mucker John 2 Link to comment Share on other sites More sharing options...
hendie Posted September 25, 2019 Share Posted September 25, 2019 2 hours ago, CedB said: "Aha!" I thought, "I can finally use the Dremel Workstation! If I turn it through 90o I can use a cutting disc to chop little bits off the tube!" Ced. Ced... Ced.... wot's gotten into you ? Are you ill ? Don't you know there's a tool for that? 1 4 Link to comment Share on other sites More sharing options...
Brandy Posted September 25, 2019 Share Posted September 25, 2019 Sorry, Officer Crabtree was the "French" policeman in 'Allo 'Allo. What was a mistype (thongs for things) was perfect to blame on him. But if I have to explain it..... Carry on that man. Ian 4 Link to comment Share on other sites More sharing options...
Navy Bird Posted September 25, 2019 Share Posted September 25, 2019 Nice work, Ced. That must be a monster. I seem to recall having a nice Nescafe with you in the shadow of a Sutherland's wing. Or is that just another LSD flashback? Cheers, Bill 6 Link to comment Share on other sites More sharing options...
keefr22 Posted September 25, 2019 Share Posted September 25, 2019 1 hour ago, limeypilot said: Sorry, Officer Crabtree was the "French" policeman in 'Allo 'Allo. Ah of course! That's why I didn't get it either - for some reason I had it in my head that he was the cop in 'Top Cat'....(who of course was Officer Dibble!) 1 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted September 26, 2019 Share Posted September 26, 2019 Or even the one from West Side Story ( Officer Krupke ) 1 Link to comment Share on other sites More sharing options...
CedB Posted September 26, 2019 Author Share Posted September 26, 2019 16 hours ago, Biggles87 said: Great razor saws but very brittle blades, I have one that looks exactly like that. I’m greatly impressed by your Dremel equipment, it makes mine look like something you would take to the antiques roadshow so is probably worth a lot of money. Toodle pip mi old mucker John Thanks John - always good to hear that my equipment has impressed someone (fnaar!) 15 hours ago, hendie said: Ced. Ced... Ced.... wot's gotten into you ? Are you ill ? Don't you know there's a tool for that? Alan you tempter! I did have a look at the link (of course) and had a flash back to the 'finger sander' I bought for the Concorde. Bit big innit? Phew… 13 hours ago, limeypilot said: Sorry, Officer Crabtree was the "French" policeman in 'Allo 'Allo. What was a mistype (thongs for things) was perfect to blame on him. But if I have to explain it..... Carry on that man. Ian Ah, "Gud moaning" Ian Sorry, forgot his name… 12 hours ago, Navy Bird said: Nice work, Ced. That must be a monster. I seem to recall having a nice Nescafe with you in the shadow of a Sutherland's wing. Or is that just another LSD flashback? Cheers, Bill We did Bill, we did! LSD? Is that some kind of filler (ahem…) 12 hours ago, keefr22 said: Ah of course! That's why I didn't get it either - for some reason I had it in my head that he was the cop in 'Top Cat'....(who of course was Officer Dibble!) 2 hours ago, Biggles87 said: Or even the one from West Side Story ( Officer Krupke ) Thanks Keith and John I must point out, of course, that for copyright reasons it was supposed to be 'Boss Cat' in the UK… didn't work did it? Just for you… oh OK then, for me really but I like to share: Which is Bill's photo of the real thing? Oh, OK, it's pretty obvious but you get the idea. Worth the effort? We shall see… Certainly needs a tidy up. In other news I've been thinking about the 'glass' for the windows. Remember this? I bought it for the… er…(quick search)… Nimrod to 'make a template' for the intakes. Didn't work. I think it will work for 14 bits of glass cut using the Silhouette Portrait and I can use the same design to cut the masks. I knew it would 'come in'… 9 1 Link to comment Share on other sites More sharing options...
keefr22 Posted September 26, 2019 Share Posted September 26, 2019 42 minutes ago, CedB said: I must point out, of course, that for copyright reasons it was supposed to be 'Boss Cat' in the UK… didn't work did it? Nope, he was always Top Cat to me! 😼 2 Link to comment Share on other sites More sharing options...
giemme Posted September 26, 2019 Share Posted September 26, 2019 3 hours ago, CedB said: Worth the effort? We shall see… Certainly needs a tidy up. I agree it needs a tidy up, still it looks very promising Smart idea for the windows Ciao 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted September 26, 2019 Share Posted September 26, 2019 Ooomph! Lovely work so far Ced. I would have suggested Mr Surfacer air brushed on as a primer to fill those panels, no sanding required either. Your solution seems to be working well though.😇 it’s been yet another busy week at work so not a lot of BM action. Glad to have caught up with the boat however. Oh sorry, ☺️ Aeroplane. 🥰😅😇 lovely internals. Happy you painted the other side of that curtain too. 🤓 johnny 1 1 Link to comment Share on other sites More sharing options...
CedB Posted September 27, 2019 Author Share Posted September 27, 2019 On 26/09/2019 at 09:54, keefr22 said: Nope, he was always Top Cat to me! 😼 Quite right Keith 21 hours ago, giemme said: I agree it needs a tidy up, still it looks very promising Smart idea for the windows Ciao Thanks Giorgio Idea thanks to Alan's (LDSModeller) build 11 hours ago, The Spadgent said: Ooomph! Lovely work so far Ced. I would have suggested Mr Surfacer air brushed on as a primer to fill those panels, no sanding required either. Your solution seems to be working well though.😇 it’s been yet another busy week at work so not a lot of BM action. Glad to have caught up with the boat however. Oh sorry, ☺️ Aeroplane. 🥰😅😇 lovely internals. Happy you painted the other side of that curtain too. 🤓 johnny Thanks Johnny I'm still flooding the lines with Klear: … as a 'therapeutic job'. Having done all the opening ports I'm going to do: … I was finally able to blast some Hataka Interior grey-green on: Not as dark as it looks in the picture, honest. 16 Link to comment Share on other sites More sharing options...
keefr22 Posted September 27, 2019 Share Posted September 27, 2019 Coming along nicely Sir Ced...!! K 1 Link to comment Share on other sites More sharing options...
Navy Bird Posted September 27, 2019 Share Posted September 27, 2019 2 hours ago, keefr22 said: Coming along nicely Sir Ced...!! When was Ced knighted? Man, I miss a day or two and look what happens. Cheers, Bill PS. By the way, those are massive panel lines. Yikes! I'm curious to see what flooding them with Klear will do. 3 Link to comment Share on other sites More sharing options...
TheBaron Posted September 27, 2019 Share Posted September 27, 2019 Yon trench(ant) beast. It grows ever larger at your hands Ced. Vivacious anchorage and industry over them last few pages. One phrase to haunt you though: 'plate racks'. How are you going to build the plate racks? 1 9 Link to comment Share on other sites More sharing options...
keefr22 Posted September 27, 2019 Share Posted September 27, 2019 4 minutes ago, TheBaron said: How are you going to build the plate racks? I'm sure you can show him how to solder 1/72 versions Tony....!! K 1 2 Link to comment Share on other sites More sharing options...
TheBaron Posted September 27, 2019 Share Posted September 27, 2019 Just now, keefr22 said: I'm sure you can show him how to solder 1/72 versions Tony....!! It would be an evil duty Keith! 4 Link to comment Share on other sites More sharing options...
perdu Posted September 27, 2019 Share Posted September 27, 2019 1 hour ago, TheBaron said: Yon trench(ant) beast. It grows ever larger at your hands Ced. Vivacious anchorage and industry over them last few pages. One phrase to haunt you though: 'plate racks'. How are you going to build the plate racks? Now I have a problem... My dad always told me his job was working in the galley "making the tea" etc.* What is that stranger doing the washing up for? * the etc included reloading bombs or depth charges and firing machine guns at potential unfriendly Germans, dad's trade was armourer and air gunner at later stages of the war 5 Link to comment Share on other sites More sharing options...
CedB Posted September 27, 2019 Author Share Posted September 27, 2019 8 hours ago, keefr22 said: Coming along nicely Sir Ced...!! K Thanks Keith 6 hours ago, Navy Bird said: When was Ced knighted? Man, I miss a day or two and look what happens. Cheers, Bill PS. By the way, those are massive panel lines. Yikes! I'm curious to see what flooding them with Klear will do. Thanks Bill No knighthood (yet). I'm waiting to see what the Klear does too, fingers crossed. 2 hours ago, TheBaron said: Yon trench(ant) beast. It grows ever larger at your hands Ced. Vivacious anchorage and industry over them last few pages. One phrase to haunt you though: 'plate racks'. How are you going to build the plate racks? [snip pic] Thanks Tony I shall ask a friend of mine to knock them up in brass - just kidding! 2 hours ago, keefr22 said: I'm sure you can show him how to solder 1/72 versions Tony....!! K There, see, everyone knows who I'm talking about 2 hours ago, TheBaron said: It would be an evil duty Keith! One day matey, one day 17 minutes ago, perdu said: Now I have a problem... My dad always told me his job was working in the galley "making the tea" etc.* What is that stranger doing the washing up for? * the etc included reloading bombs or depth charges and firing machine guns at potential unfriendly Germans, dad's trade was armourer and air gunner at later stages of the war Great story Bill - I bet Dad had some too eh? Progress has been slow, I know. I've mentioned that I'm distracted by 1:1 DIY decorating a bedroom but I haven't shared the full horror with you before. This is the current state: Never let teenagers choose colours by Ced Bufton, on Flickr Unggghh. I have some 'No more Cracks for Ceilings' and some 'One Coat' for the walls and the tins promise the earth. We shall see. I have cut some OHP film for the new windows: For you Silhouette fans, settings were 8/2/25/1. I'll need to test some glues… but not until I've sanded the new surrounds. I'll use the same design for the masks and, judging by this: … I'd better cut a few more as the Eduard masks seem a little small for the kit windows 9 Link to comment Share on other sites More sharing options...
Biggles87 Posted September 28, 2019 Share Posted September 28, 2019 That’s going to be a difficult (bedroom wall ) colour to cover. Might I suggest black? 1 6 Link to comment Share on other sites More sharing options...
Learstang Posted September 28, 2019 Share Posted September 28, 2019 Isn't that blue the colour the Soviets used on the interiors of some of their post-war aircraft? Regards, Jason 7 Link to comment Share on other sites More sharing options...
