CedB Posted September 23, 2019 Author Share Posted September 23, 2019 For those of you thinking (like me) 'This is page 3*, get on with something for goodness sake', some small progress this morning: * Edit: Page 4! Black bits. Big deal. But wait… Thank you #9 blade and little vacuum. You may know that I'm spending time as a 'Group Skills Instructor' with the local Scout Shooting sessions. Shooting Scouts? Nah, Scouts who are Shooting. One of the small benefits (apart from the feeling of 'doing some good') is that you get to keep some tins: Handy to have on the bench with some water and a little Micro Set. Having lined up the transfer with the bits I had chopped off I checked that the PE lined up as well: Nice. When that's dry I'll stick the PE on with something that comes through the holes to represent the glass. 17 Link to comment Share on other sites More sharing options...
giemme Posted September 23, 2019 Share Posted September 23, 2019 Very nice IP! Ciao 1 Link to comment Share on other sites More sharing options...
perdu Posted September 23, 2019 Share Posted September 23, 2019 Nice, no lovely work already already I suppose this means I gotta do a Monday update too 😕. 😦. 😩 3 Link to comment Share on other sites More sharing options...
CedB Posted September 23, 2019 Author Share Posted September 23, 2019 4 hours ago, giemme said: Very nice IP! Ciao Thanks Giorgio - it is isn't it? Hopefully better when the GG Thin dries: and it's had some blobs on. 3 hours ago, perdu said: Nice, no lovely work already already I suppose this means I gotta do a Monday update too 😕. 😦. 😩 Of course Bill - posts always welcome for your engineering Remember Tony posted this: Saying "We think that Italeri got their surface detail inspiration from Waters/Gilmour/Mason/Wright"? Look what I found: And you thought the outside was bad! Tempted to write some of my favourite graffiti on that: I think it's a ceiling anyway. Care needed when removing the stairs: …so that's been held in place and glued with some other painted bits: I've also finished (almost) my little pot of H78 Cockpit Green so I'll be using some Hataka and Xtracrylic as well to use that up. I don't need it now that I have my Colourcoats 'perfect match'. 12 Link to comment Share on other sites More sharing options...
Brandy Posted September 23, 2019 Share Posted September 23, 2019 Aah, so it's not supposed to be bent then! Titter ye not! Lovely panel though! Ian 1 1 Link to comment Share on other sites More sharing options...
Stew Dapple Posted September 23, 2019 Share Posted September 23, 2019 Ah yes, 1970s polystyrene ceiling tiles, very big in the 1940s Won't be visible once it's closed up, I trust... Good work so far Ced, Cheers, Stew 1 4 Link to comment Share on other sites More sharing options...
tomprobert Posted September 23, 2019 Share Posted September 23, 2019 On 9/22/2019 at 11:55 AM, CedB said: Thanks Bill I've found your S61N just before and after spraying with the filler and @tomprobert's advice on one build here. Looks like the filling primer might be the way to go (if my tin still works). Plenty to be getting on with on the internals I guess… The filler-primer might just to the trick, but I reckon it'll need a good few applications and sanding back. Maybe under a coat or two of paint the panel lines won't look too bad - not as bad as the current fad of putting dark washes into panel lines to produce a surface that resembles a mad-man has been at work with a permanent marker Thinking out loud - would a liberal coating of Mr Surfacer have the desired effect..? 1 2 Link to comment Share on other sites More sharing options...
perdu Posted September 23, 2019 Share Posted September 23, 2019 Mr Surfacer might but I havent had any experience using it, it does however have many fans so could be good Ced I promise you that door isnt on a bent wall inside Keith's old plaything, I walked through it on Saturday I took another looky at the ceiling(?) Wouldn't a copy of the record sleeve wording look good up there with you knowing just what's what, a simple crop and print on white sheet is all you need would you like a sheet of clear? No point losing the skills gained with the wabbit (was the wabbit wasnt it?) 2 Link to comment Share on other sites More sharing options...
hendie Posted September 23, 2019 Share Posted September 23, 2019 1 hour ago, CedB said: I hear Italeri's CAD chisel bloke studied at the Inca school of architecture 7 Link to comment Share on other sites More sharing options...
CedB Posted September 23, 2019 Author Share Posted September 23, 2019 1 hour ago, limeypilot said: Aah, so it's not supposed to be bent then! Titter ye not! Lovely panel though! Ian No, not bent - now straightened. Yes I am clumsy 1 hour ago, Stew Dapple said: Ah yes, 1970s polystyrene ceiling tiles, very big in the 1940s Won't be visible once it's closed up, I trust... Good work so far Ced, Cheers, Stew Thanks Stew! 1 hour ago, tomprobert said: The filler-primer might just to the trick, but I reckon it'll need a good few applications and sanding back. Maybe under a coat or two of paint the panel lines won't look too bad - not as bad as the current fad of putting dark washes into panel lines to produce a surface that resembles a mad-man has been at work with a permanent marker Thinking out loud - would a liberal coating of Mr Surfacer have the desired effect..? Thanks Tom If I decide to fill the panel lines (rather than paint them, a lot) I'll try the Mr Surfacer. 43 minutes ago, perdu said: Mr Surfacer might but I havent had any experience using it, it does however have many fans so could be good Ced I promise you that door isnt on a bent wall inside Keith's old plaything, I walked through it on Saturday I took another looky at the ceiling(?) Wouldn't a copy of the record sleeve wording look good up there with you knowing just what's what, a simple crop and print on white sheet is all you need would you like a sheet of clear? No point losing the skills gained with the wabbit (was the wabbit wasnt it?) Thanks Bill The record sleeve… now that's an idea. 8 minutes ago, hendie said: I hear Italeri's CAD chisel bloke studied at the Inca school of architecture Thanks hendie Well I've just spent a while looking for suitable graffiti and found, to my horror, that the funny stuff we grew up with has been replaced by, er, loads of people spraying their 'tags'. Couldn't find a funny one amongst them! Apart from the fantastic Banksy stuff it's all "me, me, me'! I've bought the Kindle version of Nigel Rees' book to save for prosperity. I did find a couple of images that will go in: The famous 'Mr Chad'. Maybe just a version with a cleaner background and 'Wot, no…' and a suitable modelling term - suggestions welcome. This, of course, has to be there: If you're not a 'Life of Brian' fan you must watch the video of the bit where Brian has to graffiti the town square - one of my favourite clips Some more candidates… I couldn't care less about apathy. "Make love not war." --- I'm married. I do both. Be Alert - Britain needs Lerts I’d give my right arm to be Ambidextrous Bill Stickers is innocent! Humpty Dumpty was pushed Feel free to suggest your (clean) favourite - I need ten or eleven. 1 6 Link to comment Share on other sites More sharing options...
Brandy Posted September 23, 2019 Share Posted September 23, 2019 (edited) "Ronald Reagan should be bloody well hung!" "He is, my dear, he is". Signed Nancy. Or the old classic: "Here I sit, broken hearted, paid my penny and only f**ted!" Ian Edited September 23, 2019 by limeypilot 1 5 Link to comment Share on other sites More sharing options...
bhouse Posted September 23, 2019 Share Posted September 23, 2019 11 minutes ago, CedB said: suggestions welcome. "Wot? No filler?" 5 Link to comment Share on other sites More sharing options...
stever219 Posted September 23, 2019 Share Posted September 23, 2019 2 hours ago, tomprobert said: Maybe under a coat or two of paint the panel lines won't look too bad - not as bad as the current fad of putting dark washes into panel lines to produce a surface that resembles a mad-man has been at work with a permanent marker Heretic, You could wind up being boiled in a vat of MiG Panel Line Wash if the “Spanish School” Police catch you, and nobody expects the Spanish School Police. (With apologies to Messrs Palin, Cleese et al)👺🤪😖 7 Link to comment Share on other sites More sharing options...
Martian Posted September 23, 2019 Share Posted September 23, 2019 Huzzah! We have lift off! Did somebody resurrect the Matchbox trench digger or what? I'm glad I passed this kit up but you will no doubt make another silk purse out of a sow's ear. As for graffiti, how about "Ced was here, fnar, fnar". Martian 👽 6 Link to comment Share on other sites More sharing options...
CedB Posted September 23, 2019 Author Share Posted September 23, 2019 3 hours ago, limeypilot said: "Ronald Reagan should be bloody well hung!" "He is, my dear, he is". Signed Nancy. Or the old classic: "Here I sit, broken hearted, paid my penny and only f**ted!" Ian Thanks Ian - I said clean! Asterisks don't count 2 hours ago, bhouse said: "Wot? No filler?" Good one Brian 2 hours ago, stever219 said: Heretic, You could wind up being boiled in a vat of MiG Panel Line Wash if the “Spanish School” Police catch you, and nobody expects the Spanish School Police. (With apologies to Messrs Palin, Cleese et al)👺🤪😖 Thanks Steve. Never got the hang of washes myself. What's that smell? 🧥 1 hour ago, Martian Hale said: Huzzah! We have lift off! Did somebody resurrect the Matchbox trench digger or what? I'm glad I passed this kit up but you will no doubt make another silk purse out of a sow's ear. As for graffiti, how about "Ced was here, fnar, fnar". Martian 👽 Thanks Martian- another good one! Some messing about while I'm waiting for the tube to arrive for the windows. There's some nice PE in the kit for the seat supports but it's thicker than usual and defeated my little bender so the pliers had to come out: Nice though in the end: … and they'll go well with the seats: Front and back view. No they're not ejector marks, they're 'detail'. Nice little arms rests. Control columns, pedals and i/p are in with some blobs: Some nonsense on the other panels: 14 Link to comment Share on other sites More sharing options...
giemme Posted September 23, 2019 Share Posted September 23, 2019 Nice interiors, Ced Ciao 1 1 Link to comment Share on other sites More sharing options...
CedB Posted September 23, 2019 Author Share Posted September 23, 2019 Thanks Giorgio I've been thinking about this after some wine this evening. Why not build 'Keith's Sunderland' as she was 'in my theme days', that is as a Mk III? Basically the Italeri kit with amended serial and Sqdn code - ML824, NS-Z? What do we think? It feels right to me… There's a full history of her here and, of course, we have lots of pictures. 3 Link to comment Share on other sites More sharing options...
Biggles87 Posted September 24, 2019 Share Posted September 24, 2019 Wow! Went out to lunch yesterday ( followed by a snooze ) and look how much I missed. John 1 Link to comment Share on other sites More sharing options...
perdu Posted September 24, 2019 Share Posted September 24, 2019 Your plan Ced, sounds like a plan Go for it, she will look great 10/10 for planning 1 Link to comment Share on other sites More sharing options...
CedB Posted September 24, 2019 Author Share Posted September 24, 2019 3 hours ago, Biggles87 said: Wow! Went out to lunch yesterday ( followed by a snooze ) and look how much I missed. John Thanks John I hope you enjoyed the lunch! 49 minutes ago, perdu said: Your plan Ced, sounds like a plan Go for it, she will look great 10/10 for planning Thanks Bill Of course now I'm thinking I should spray the markings (except the serials, I'm not completely mad) Some late night assembly, always dangerous. Cabin bulkhead glued in the floor and clamped dry into the fuselage to make sure it's upright: In that photo it looks as though the wing stub / locator will knock the radio off but I've checked and it looks as though it might just miss? Some shots of the internals this morning: I've also assembled this: Just, really, to get it off the trees. It won't be used on the ceiling so has gone in the cupboard. I've also started on the wings, mainly to get the part trees cleared (first one empty). Still waiting for the tube - might be here today? 9 Link to comment Share on other sites More sharing options...
perdu Posted September 24, 2019 Share Posted September 24, 2019 Would the undersides of the arms be padded? That looks like decent interior though, nice one 1 Link to comment Share on other sites More sharing options...
CedB Posted September 24, 2019 Author Share Posted September 24, 2019 Yes Thanks Bill. Might do a sepia wash later and, of course, install the crew. 1 Link to comment Share on other sites More sharing options...
Andwil Posted September 24, 2019 Share Posted September 24, 2019 Nice work on the bridge, I mean cockpit, Ced. AW 3 Link to comment Share on other sites More sharing options...
CedB Posted September 24, 2019 Author Share Posted September 24, 2019 Thanks AW Wings. Before we start, I found another of these lurking on the bench this morning: Where are they coming from? Ah, the 'extra bit' on the E trees: I've separated those extra bits from the main tree now and put them safely in the box. I've also separated the parts (aerial masts?) that were dropping off and put those with the others. Thankfully no losses but I'd suggest others look out for them! Wings. Big: One aileron sits a bit proud (the lower one): …because this lump was left over from the gate when I sawed it off: Now that's been removed, and some other flash in the aileron slots, they fit much better: So the wings can be glued and clamped for later: I've also gathered 'other bits for IG': The part bottom right has the graffiti wall (actually the ceiling) on its reverse so I might paint these up sooner rather than wait for the fuselage (and its windows) to be finished. I really need to do some DIY decorating today. What's to do? Sanding. I hate sanding… 9 Link to comment Share on other sites More sharing options...
keefr22 Posted September 24, 2019 Share Posted September 24, 2019 10 hours ago, CedB said: There's a full history of her here That's really interesting Ced, thanks for the link! I didn't realise she wasn't actually still on RAF charge when I was allowed to play with her, or that she was open to the public - I always had her to myself - but maybe that was because it was always around 6am....!! 37 minutes ago, CedB said: I really need to do some DIY decorating today. What's to do? Sanding. I hate sanding… You and me both! But my sanding is now restricted to plastic stuff. After 40 years of doing all DIY myself, I've rebelled and told 'er indoors (who always claimed ' i can't paint)if she wants decorating done it's 'do it yourself) or get a man (or woman) in! It's worked so far.....!! Good progress on the Sunderland, you've done more on yours in a few days than I managed in a few months on mine! Keith 1 1 Link to comment Share on other sites More sharing options...
