Pascal 319 Posted October 10, 2019 Share Posted October 10, 2019 I've checked my references, had to go thru my 288 GTO and 288 Evoluzione photos to find the answer. The tube is not attached to the gearbox, but runs straight down (as you mentioned earlier). Took me some time to find what the tube does (I don't know a lot about engines / gearboxes). The tube is part of the gearbox breather system. A breather prevents pressure from building up inside the gearbox. Without a breather the pressure can cause oil leaks. The breather allows hot air to escape and fresh cooler air to come in. The breather is the part that looks like a hexagonal bolt (attached to the top of the gearbox housing). These photos are from a 288 GTO, but they show the breather and the tube : Sincerely Pascal 2 Link to post Share on other sites
terrible4130 60 Posted October 12, 2019 Author Share Posted October 12, 2019 (edited) Big update today. I have completed the front suspension and brakes. Its nice to be able to tidy up the workbench with these assemblies. Getting all the nuts and bolts to cooperate when assembling the front suspension required some small paint touch-ups. You will see some notable scratch-built details on the brake calipers. I also received my next project. I will be building a Pocher 993. The plan is to build a GT2 clubsport, new front splitter, rear wing, widebody fenders and roll cage. Not to mention custom built wheels. But for now, the F40. Edited October 12, 2019 by terrible4130 4 Link to post Share on other sites
Pouln 692 Posted October 14, 2019 Share Posted October 14, 2019 Looking very nice. I see you opted for a guard for your next project. Guess nobody dares to touch it Link to post Share on other sites
FunkyChiken 128 Posted October 18, 2019 Share Posted October 18, 2019 It is a joy too see expertly built kits in progress, thanks for sharing! Link to post Share on other sites
terrible4130 60 Posted October 23, 2019 Author Share Posted October 23, 2019 Hello, I have been on a steady push to complete the front end. I found the kevlar decals to be very enjoyable to apply. I ended up covering all monocoque and bucket seat shells. I tried to capture as much detail as possible on the pedal assembly. This required a bit of additional scratch building. It took me two tries for the hoses that come off the radiator. My second solution ive shown turned out to be very successful. 4mm bent brass tube soldered together as a sub assembly then inserted into the radiator PE with small polystyrene plugs. This allowed me to add the finicky hose clamps mush easier. Still a bit of clean up work also some more decals and some detail hardware and the front end should be done done... Thanks for looking. More updates soon! 4 Link to post Share on other sites
PROPELLER 2,589 Posted October 23, 2019 Share Posted October 23, 2019 Simply amazing! May be some weathering? Dan. Link to post Share on other sites
rjfk2002 189 Posted October 24, 2019 Share Posted October 24, 2019 The Kevlar decals look great! You applied them flawlessly. Are they water slide? Is the green edge also a decal or paint? Rich Link to post Share on other sites
larchiefeng 913 Posted October 24, 2019 Share Posted October 24, 2019 The decals look great and they settled down nicely on the seat backs! Rich, the green stripes are also decals. Exceptionally clean work! Link to post Share on other sites
terrible4130 60 Posted October 24, 2019 Author Share Posted October 24, 2019 Dan, It is tempting to weather, but my plan for this was to build a showroom version. There will be a bit of weathering on the exhaust. My plan is to build another LM version of this build in the Pilot Pen livery. That one I would like to do substantial weathering. Yea, the green strips are just vinyl decals. I did have to do a fair bit of touchups on the decals. Just by cutting patches with the leftover decal material. Luckly as long as you match the pattern it is almost indistinguishable. Thanks for all the positive comments. Now I have to decide where to build next. I have been avoiding the turbos and exhaust. Im thinking about perhaps building the dash, or even the wheels next. Stay tuned. 1 Link to post Share on other sites
larchiefeng 913 Posted October 24, 2019 Share Posted October 24, 2019 Ah, yes the turbos and exhaust! I have spent more than a couple of hours over the past few weeks figuring out how to make and attach the eye bolts to the hoses and turbos. I have finally done it after about 4-5 different failed scenarios. I just need to do some repaint on one of the turbos and one header and paint the WM fittings and then I’ll be ready for that assembly. I also decided to change the exhaust and that has held me up some too. Hopefully, I can make enough progress this weekend to post over on my thread. I received a question regarding the decals. Somebody said that, they saw where Uli mentions using something like wallpaper paste to put down the decals but, that doesn’t sound right. You put them down like regular decals, correct? Link to post Share on other sites
terrible4130 60 Posted October 25, 2019 Author Share Posted October 25, 2019 (edited) I hope you are able to work everything out with your next steps. I look forward to seeing your progress. Yea the decals are applied as normal. Im not sure what he was saying with the paste. Tips are just cutting them slightly oversized. A small amount of dish soap in the water. Brushing on Microsol and using a hair dryer. Some of the big symmetrical decals I actually cut in half to manage easier. Just as a precautionary measure. Edited October 25, 2019 by terrible4130 Link to post Share on other sites
rjfk2002 189 Posted October 30, 2019 Share Posted October 30, 2019 (edited) I had a question on of our your earlier posts. What did you use for the nuts on the PE parts below? Are those MMC simulated nuts or did you a rod and nut to create? Capture by Car Models, on Flickr Edited October 30, 2019 by rjfk2002 1 Link to post Share on other sites
terrible4130 60 Posted October 30, 2019 Author Share Posted October 30, 2019 Thats correct those are simulated hex nuts. I got a variety from MMC and a variety of sizes from Knupfer as well. Knupfer is a GREAT resource. https://knupfer.info/shop/index.php/deutsch/imitate-und-spezialschrauben/micro-stehbolzen.html Link to post Share on other sites
terrible4130 60 Posted January 20, 2020 Author Share Posted January 20, 2020 I have been slowly making progress on the interior and after a final push It is complete! I had some challenges wrapping the seat fabric. I had to change the type of contact adhesive I used. Also the fabric on the rear of the interior tub had to be upholstered a couple times until I was happy. Luckily I just ordered red and grey women's tights from amazon for like 5 bucks. This fabric was very very similar to what was in the Transkit. Same with the seat belts material. The Transkit didn't come with much extra so I had to start over and purchased red ribbon from Amazon and it worked perfectly. Next is a couple finishing touches to the Dash. Then Its time to roll up the sleeves and tackle the turbos and exhaust... 4 Link to post Share on other sites
JeroenS 6,128 Posted January 21, 2020 Share Posted January 21, 2020 13 hours ago, terrible4130 said: Luckily I just ordered red and grey women's tights Yep, these tights tend to come in handy Seriously, that looks like a job well done. Very neat. Link to post Share on other sites
terrible4130 60 Posted January 24, 2020 Author Share Posted January 24, 2020 Thanks alot. Link to post Share on other sites
larchiefeng 913 Posted January 24, 2020 Share Posted January 24, 2020 I agree, your interior came out beautifully! I'm not sure if I'm going to use the red tights that came with the transkit on mine but, just in case, what did you order from Amazon to replace the transkit material with? Link to post Share on other sites
terrible4130 60 Posted January 25, 2020 Author Share Posted January 25, 2020 These were exactly like the ones in the Autograph transkit. https://www.amazon.com/gp/product/B07Q3W1MH3/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Link to post Share on other sites
Cooper645 684 Posted January 26, 2020 Share Posted January 26, 2020 3 hours ago, terrible4130 said: These were exactly like the ones in the Autograph transkit. https://www.amazon.com/gp/product/B07Q3W1MH3/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 They are extremely well modelled I must say. Link to post Share on other sites
terrible4130 60 Posted March 9, 2020 Author Share Posted March 9, 2020 (edited) Big update today! I have had alot of parts laying around. Everything is finally falling into place. All the piping from the manifolds to the turbos / muffler were tricky. Alot of dry-fitting and adjusting was necessary. I ended up having to scratch build the two lengths from the "Y" to the tips of the manifolds. Now onto wiring... I Cut these two white metal parts in half and sandwiched a scratch-built brass bracket for an easy mounting solution. I also scratch-built a throttle body. Edited March 9, 2020 by terrible4130 8 Link to post Share on other sites
Codger 2,698 Posted March 9, 2020 Share Posted March 9, 2020 Change your name- NONE of this is 'terrible'. 2 1 Link to post Share on other sites
terrible4130 60 Posted March 11, 2020 Author Share Posted March 11, 2020 Fuel lines. Its a shame these will be more or less hidden in the final assembly. Oh well, no short cuts. 2 Link to post Share on other sites
larchiefeng 913 Posted March 11, 2020 Share Posted March 11, 2020 Beautiful work! Thanks for the reference materials on this section of the engine. I did have a question about how the PE part fits on the actual waste gate itself. Once it’s folded it doesn’t look like it fits around the two round waste gate pieces. Maybe I’m just looking at it wrong. I also like the way you molded the MB brass pieces onto the exhaust headers and integrated the waste gate pipes in to make it appear to be part of each header. Keep up the great work! Link to post Share on other sites
terrible4130 60 Posted March 11, 2020 Author Share Posted March 11, 2020 Thanks, The PE parts around the waste gate required alot of adjustments. I actually had to do that area over a couple times. I have 2 extra engine kits and had to scrap one of the waste gate parts in the process of a failed attempt. If you can be more specific I can try and let you know how I solved it. I was able to photograph an F40 a few weeks ago with the rear clamshell off. Also on a lift with the wheels off. I have hundreds of photos. If you need a close-up of anything specific just let me know. Link to post Share on other sites
larchiefeng 913 Posted March 11, 2020 Share Posted March 11, 2020 Ok thanks, I’ll get a couple of part numbers and take a couple of pictures of the exact parts and location Link to post Share on other sites
