Dave Swindell Posted September 18, 2019 Share Posted September 18, 2019 23 minutes ago, bootneck said: mmm, that doesn't seem to work for me. Mike, if it's an older aircraft and you're getting no hits, enter the letters, click on the advanced search drop down and check the search de-registered aircraft box. If you're still not getting there the registry entries for the two aircraft you quoted are located here:- https://cwsprduksumbraco.blob.core.windows.net/g-info/HistoricalLedger/G-AOXL-1.pdf https://cwsprduksumbraco.blob.core.windows.net/g-info/HistoricalLedger/G-AOXL-2.pdf https://cwsprduksumbraco.blob.core.windows.net/g-info/HistoricalLedger/G-ASPB.pdf Link to comment Share on other sites More sharing options...
dbay133 Posted September 18, 2019 Share Posted September 18, 2019 In response to the AXOL enquiry I get the following screen. If you scroll down there is more detail. If you click on the "View Registration History" link it will open up the history section and show as You can then select the links under the "Pre-1986" section to view the original CAA paper records. This is Register Entry 2. Link to comment Share on other sites More sharing options...
