Fishbone
1/48 AMK USN VF-31 F-14D Super Tomcat "Tomcatters"
Wow this looks incredible, I will be buying one, one question what did you use for the screens in the cockpit? Are those kit supplied decals or did you paint it and if so what paint did you use?
Continue dealing with fitting problems LOL but they are easy to get rid if you take your time. I am using water-based putty and Madworks CG-001 Black CA Glue as putty to patch up those seam-lines. Can't avoid re-scribing and riveting after countless sanding. After everything is patched-up, I primed the whole thing with SF289 Mr. Finishing Surfacer 1500 Grey primer micro filler.
Spent 3 hours just to prime the fuselage, wings, slats, flaps, tailplanes and tail fins...ahhh I hate 1/48.
After the primer surfacer dried, I wet-sand everything with 3M™ MicroFine Softback Sanding Sponge - I do this because there will be some rough surfaces caused by the primer particles due to humidity, angles of spraying or air-pressure. Thinner is one of the main reason - it's recommend to use Mr. Colour Levelling thinner instead of Mr. Colour Thinner.
After wet-sand, I will brush the whole thing again with a toothbrush which make the surface real smooth.
71184826_10220833195083685_1891803265616
70247118_10220833195963707_7533910203880
71590021_10220833194963682_1292056300145
71185520_10220833193883655_7651906622087
70887575_10220833197323741_4398538877564
71685782_10220833195443694_7507082270486
70761711_10220833199043784_8667416154207
71263751_10220833197763752_2112394271997
70974660_10220833194563672_7952492794516
71079908_10220832929277040_3925897208611
70926505_10220832926676975_2177217199784
70727461_10220832926556972_8508770945740
70764560_10220832932237114_4265466449838
71059675_10220832949677550_8551305497225
71120397_10220832950397568_2274124465279
As the tail fin of this F-14D is fully black so I decided to try the decals which produced by Furball Aero Design. I sprayed SF288 Mr. Finishing Surfacer 1500 Black onto both tail fins - I love the finishing so much, it's fully flat black! I begin the decal work after few layers of clear coat which will make the decals much more easier to slide.
Decals are very good, thin and tough but please remember to put a little more water on the surface otherwise it'll very hard to slide it around. The decals are perfectly settled on the tail fins after 2-3 layers of Softener.
70629454_10220833576733226_3341524748591
71474407_10220833572253114_7584902404965
71029547_10220833576053209_1891267803453
71709458_10220833575133186_1345150213412
70618588_10220833579253289_3672196814741
70587176_10220833584413418_8481016390331
71708083_10220833579853304_5480552529404
70538224_10220833586213463_8662511507713
70917382_10220833585653449_5282599784538
71230815_10220833589053534_1756978474054
71467115_10220833588613523_8190804045686
Looks great. I looked up the price of this kit and expecting around £100 GBP, but it was £66. Very reasonable seeing as you need virtually no aftermarket.
Looking good, those tail fins look resplendent in their finished scheme.
Wow!
Tail looks nice!
Probably one of the first Tomcat schemes I wanted to do.. but decals in 48th only became available recently....
:thumbsup:
AMK 1/48 F-14D updates:
Pre-shaded with SF288 & Gunze 40, this Felix is too big...my thumb is pain and tired, so that's all for the night.
71765997_2330215930573902_61263134466118
68664077_2330216270573868_60506769551104
70776439_2330216147240547_60470529561953
69872585_2330216297240532_68763392862500
71835271_2330216387240523_48904345842582
70849090_2330216467240515_49013588894102
71803099_2330216753907153_36798052247525
70828631_2330216930573802_26717228378441
70870915_2330216963907132_41952869891650
70899379_2330217000573795_38819273263001
FINALLY, I've done all decals and stencil data, produced by Furball Aero-Design. The decals are one of the highest quality decals I have ever used - thin but tough with very minimum carrier films which you don't even have to worry about silvering problems.
  • Resin wheel from Def.Model, Korea.
  • Pitot & AoA from Master, pl.
  • Figures: ZLPLA 즐프라 & Reedoak (Not in photos)
  • Deck: HobbyWorld ESP / Phoenix Model (Not in photos)
71268839_2334361630159332_33474173664126
71268839_2334361630159332_3347417366412671181429_2334963506765811_11038670381467
71894993_2334964433432385_75423274721974
71146582_2334963706765791_68952598756143
70897542_2334964580099037_51537813114663
71341326_2334964610099034_20424082137011
71170616_2334964833432345_20629808192862
71823437_2334965130098982_21821094810668
71549607_2334965240098971_75254092996657
71835053_2334965260098969_18773642598772
71216693_2334965360098959_80565316857028
71084391_2334965483432280_64411618095661
71637870_2334964353432393_72424523015399
71487457_2334361766825985_51231642505497
71531905_2334361963492632_13524589764400
71769817_2334361926825969_29081214799482
71017312_2334362116825950_24596265509249
71654376_2334362303492598_47236635596601
71286117_2334362276825934_12517942201512
71037015_2334362653492563_48777535988275
71321581_2334362726825889_78793266006998
71087617_2334362750159220_59856334463938
71254531_2334362950159200_14896874893994
72274610_2334363200159175_25635637501708
71968719_2334363150159180_60740855061261
71153727_2334363190159176_65471613318484
71026730_2334363333492495_51481170699417
71592973_2334363683492460_43826975435286
71703775_2334363860159109_26341362905466
71101701_2334363910159104_38289632241249
71572699_2334363986825763_12312869667885
70905321_2334364240159071_68799456500294
71077091_2334364263492402_76726503391698
71205824_2334364380159057_47002842487817
71499621_2334364686825693_19696111465539
71922591_2334364756825686_55662141402943
71092910_2334364783492350_82475054523094
71880230_2334364933492335_71808848988345
Edited by Fishbone
fantastic build thread!
like it a lot! :)
On 10/3/2019 at 7:53 AM, Sarawakia said:
Great build… any reason for the aftermarket wheels?
Nope it's just for fun. The owner of Def Model is my friend, he sent me the resin wheel when he know I am building a 1/48 F-14.
W.I.P. 50%.
E.T.A. 16 days to the AMK F-14D Build-off Malaysia, wrap it up boys!
71711926_2336599339935561_64925086589858
71471725_2336599506602211_88755922526766
71781811_2336599619935533_53070160336665
71399030_2336599646602197_54403780366775
72200708_2336599759935519_60907441767338
71902438_2336599983268830_84888046435083
71373750_2336600013268827_24367532645034
71950672_2336600223268806_57081114673880
71333396_2336691993259629_41056265575637
71185035_2336694143259414_57674474198348
71494398_2336694163259412_87259498110580
71494519_2336692866592875_32980349061850
71234636_2336692936592868_75996775004860
71499193_2336692859926209_54635284730436
71479949_2336693233259505_57438723958867
71498888_2336693309926164_17736789948230
71221105_2336693336592828_36402553534147
71496932_2336693493259479_31550240959349
71381586_2336693739926121_53079920091500
71511215_2336693773259451_73788285125992
71382022_2336693919926103_56287786797870
72328058_2336694333259395_63976940218162
71212920_2336694426592719_67118458913989
71276507_2336694816592680_87183350402006
72362440_2336695096592652_32823033686927
71334798_2336695123259316_23104080827079
71866088_2336695273259301_46466327242059
71844453_2336695726592589_82520165380647
71237125_2336695946592567_37813311005094
71965773_2336695979925897_42114465459181
71345236_2336696146592547_61602204095275
71015327_2336696306592531_84695302562130
That's all, thanks for viewing.
You caught the comment elsewhere about the GPS dome on the spine correct? It should not be there for this aircraft in VF-31 as they did not have LANTIRN capability until 2000's.
Edited by whiskey
Is it possible that the date stated in the instructions might be incorrect?  The decal markings DO depict when the timeframe VF-31 had LANTIRN and the GPS incorporated on their F-14Ds.
Yes! It's entirely possible, but it's not incorrect. I highly doubt that decals made by Furball would've been wrong as Geoff highly researches his subjects. I did some double checking and the markings are correct. VF-31 DID have LANTIRN capability in '97. I found a photo of said aircraft with the label of being at Fallon in October of that year and if you look closely you can see the pod hanging off the pylon.
grumman-f-14d-164600-vf-31-cvw-14-fallon
Edited by whiskey
