Sign in to follow this
Paul A H
Russian Army Tank Transporter MAZ-537G Tractor w/ ChMZAP-5247G Semitrailer - 1:72
1:72 Takom
The MAZ-537, also known as the KZKT-537, is a military tractor unit manufactured by MAZ and KZKT between 1959 and 1990. Combined with a trailer such as the ChMZAP-5247G, it can tow loads of up to 65 tons. The tractor has been widely employed by the USSR, former USSR states and export customers in a diverse range of military and civilian roles, including tank transportation, artillery tractor and in the oil and gas industry. Powered by a 38.8 litre V12 diesel engine (with pre-heating to cope with cold climates) and drive to all eight wheels, the tractor weighs 21,600 kg. The G version is equipped with a 15 ton winch and can self-extract from adverse terrain. The vehicle has largely been superseded by the KZKT-7428 in Russian service.
Takom must have something of an interest in military tractor/trailer combinations. Their range of 1:72 kits is comprised almost entirely of such subjects, including the Hanomag/V2 combo and the M1070/M1000 that we reviewed on this site but a few days ago. This kit continues the trend, but omits any kind of load to put on the trailer. No matter as the likes of Revell and Modelcollect have released lots of Soviet/Russian hardware that would be suitable for the job. Inside the relatively compact top-opening box are four frames of grey plastic, a single small clear frame, a small fret of photo etched parts, decals and a couple of piles of rubber tyres for both the tractor and the trailer. Each item is packed in its own bag for protection. The quality of moulding is clean and crisp and looks good to me. The instruction manual is much smaller than normal (just under A5 size) and although the painting diagrams are in full colour, the size of the illustrations and the decision to use a dark grey background makes them almost impossible to interpret properly. I would probably recommend you give up and find some decent photographs to work from.
Construction starts with chassis and drive train of the MAZ-537. As the tractor is eight-wheel drive, there are drive shafts and differentials running the length of the central chassis. The wheels are single, solid parts which just pop into the massive balloon-like tyres. Each is then attached to a small axle sub-assembly, which in turn fits onto the side of the chassis. The whole thing is richly detailed but not overly complex. One the chassis is complete, attention turns to the cab unit. There are various details that have to be fixed to the underside of the floorpan, after which it can be flipped the right way up and fixed to the chassis. Interior detail is limited to the bench seat and a basic dashboard and steering wheel. As with their M1070 kit, the clear parts are moulded from clear polystyrene and the doors are entirely translucent, meaning some masking will be required prior to painting. I would recommend both inside and outside be painted in order to achieve a good finish. finishing touches include the rear view mirrors and tiny photo etched windscreen wipers.
The ChMZAP-5247G trailer is comparatively straightforward to assemble. The chassis is basic ladder-like structure, with the upper load surface moulded in place. The road wheels fit onto two suspension bogeys, making two pairs of four wheels. As before, the wheels are separate to the rubber tyres, which will speed up painting and weathering. The spare wheels for both tractor and trailer fit onto the trailer, as do the hydraulic stabilisers. Alternative parts are provided so the latter items can be used for building the trailer in the detached configuration if desired. The painting and marking guide shows four different schemes for the tractor and trailer. The Afghan Army, Hungarian Defence Force, Iranian Army and Soviet Army are all provided for. Paint references are provided for the Ammo by Mig range of paints. Unusually, recommendations are also made for Ammo weathering products as well. As mentioned in the preamble, the painting diagrams are infuriatingly small for such a large vehicle (and no, it's not my age), so extra pictorial references will be essential.
Conclusion
It feels as though fans of Soviet bloc/Russian hardware are enjoying something of a golden age at the moment. Ten or so years ago, kits of subjects such as this MAZ were either non-existent or strictly limited run. Now, thanks largely to mainstream manufacturers such as Takom, Modelcollect, Revell, ICM and Zvezda, we seem to have a choice of not just MBTs, but APCs and other vehicles such as this in injected plastic. The utilitarian, almost Tonka-esque look of the big MAZ appeals to me enormously and it will look great with a soviet MBT on the back. Highly recommended.
Review sample courtesy of
