Habu12 Posted August 31, 2019 Share Posted August 31, 2019 This new Kinetic Kit was a delight to build! Full write up soon. 67 1 Link to comment Share on other sites More sharing options...
Abandoned Project Posted August 31, 2019 Share Posted August 31, 2019 Nice weathering, especially on the underside. The canopy really looks great. 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 31, 2019 Share Posted August 31, 2019 Wow, looks very nice! Any issues? Do you recommend it? Thanks! 1 Link to comment Share on other sites More sharing options...
petetasker Posted August 31, 2019 Share Posted August 31, 2019 That’s lovely 1 Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted August 31, 2019 Share Posted August 31, 2019 Awesome build. It takes me right back to watching "The Vikings" at Greenham Common in 1983. 1 1 Link to comment Share on other sites More sharing options...
Teeradej Posted August 31, 2019 Share Posted August 31, 2019 Nice work! 1 Link to comment Share on other sites More sharing options...
Habu12 Posted August 31, 2019 Author Share Posted August 31, 2019 12 hours ago, exdraken said: Wow, looks very nice! Any issues? Do you recommend it? Thanks! I’ll have a full writ up coming, but short answer, yes! Highly recommended. 1 1 Link to comment Share on other sites More sharing options...
Harold55 Posted September 1, 2019 Share Posted September 1, 2019 Great looking aircraft! I am looking forward to your write-up as I am thinking I need to update my F-104 in my collection. 1 Link to comment Share on other sites More sharing options...
Habu12 Posted September 3, 2019 Author Share Posted September 3, 2019 Kinetic 1/48 F-104G Starfighter Box Packaging/Decals/Pubs: 7 This is the biggest letdown of the whole kit. But I’ll get to that. The decals are cartograph, so they are of perfect register, glossy, and colorful. There aren’t many, as the only options you have are for German Zippers. And all versions are attractive, with two three-tone camouflage and one Marine jet with the two-tone gray/silver scheme. The instruction sheet belies the excellence of the rest of the kit. Kinetic has been told directly, by myself and others, that their instruction sheets are subpar and in dire need of improvement. The printing is outdated, it’s monochrome, and thus the painting profiles are hard to read and follow. The paint callouts are also limited, as the only paint line referred to are MiG colors. Yes, there is conversion table at the front of the sheet, but who wants to constantly refer to that while building? Kinetic has been advised to look at other manufacturer’s instruction sheets for reference and inspiration. That consultation has still not produced an updated instruction sheet. Sprues: 9 Nice, crisp, no flash. Detail is excellent, and the gates are clearly defined. . Although not quite to the quality of the top manufacturers. Shape: 10 Compared to the Hasegawa kit, it’s almost identical. And while some of the detail in that kit is called into question, that’s not the case here. Excellent shape. Subject/Cool Factor: 8 While not a Mustang or Spitfire, the Century Series are still a very popular subject matter. Although the F-104 is arguable not the most coveted of the six aircraft. In any case, we’ve not had a completely new tool Zipper in along time, and this one is most certainly welcome. Engineering: 9 Kinetic has been known to take the basic layout from other already existing kits. If it ain’t broke, why fix it? And such is the case here. It follows the Hasegawa layout and buuld sequence to an extent, and that’s not a bad thing. BOX SCORE: 43 BUILD Fit: 10 I ad absolutely no issues with the fit that I didn’t cause myself (I stupidly put the nose gear well in backwards). The intakes fit perfectly. The only filler used was on the fuselage underside. In one spot. Detail: 9 Detail is excellent. And the much maligned, overdone rivet detail of the Hasegawa isn’t present on this kit. Not that it’s completely devoid of any. But he rivets are added where most needed, such as around the tail/engine section. Effort: 9 Just a tick off for the confusing build sequence at times. The instruction sheet does leave out some thing like the AIM-9 assembly, and it’s exact position on the belly. I had to estimate that myself. Other than that, no issues with the build. Value: 7 While not an exorbitant price, the letdown with the pubs in this kit really make it difficult to be a higher score. Fun Factor: 9 Fun kit, just the aforementioned letdown. BUILD SCORE: 44 Add it all up and the D score is...89 out of 100 Just missed out the Grade A kit. Fix those pubs, Raymond! 7 Link to comment Share on other sites More sharing options...
exdraken Posted September 3, 2019 Share Posted September 3, 2019 Wow! Nice summary! Think I will need one then! 1 Link to comment Share on other sites More sharing options...
guillaume320 Posted September 4, 2019 Share Posted September 4, 2019 Awesome build and write up ! I look forward to adding a few to complement my Hasegawa/Daco kits.... One question though: Are you sure the ailerons drop as well? I thought they would remain in neutral position G 1 Link to comment Share on other sites More sharing options...
Habu12 Posted September 4, 2019 Author Share Posted September 4, 2019 2 hours ago, guillaume320 said: Awesome build and write up ! I look forward to adding a few to complement my Hasegawa/Daco kits.... One question though: Are you sure the ailerons drop as well? I thought they would remain in neutral position G Ref pics show that they droop a little bit. Sometimes they don’t. But I know you can physically make the droop if you walk by one and pull it down. The flaps. Same thing. The flap hinges have the angle molded in, so I just left it be. 1 Link to comment Share on other sites More sharing options...
guillaume320 Posted September 4, 2019 Share Posted September 4, 2019 39 minutes ago, Habu12 said: Ref pics show that they droop a little bit. Sometimes they don’t. But I know you can physically make the droop if you walk by one and pull it down. The flaps. Same thing. The flap hinges have the angle molded in, so I just left it be. Awesome bit of knowledge, thanks a lot!! I hope Kinetic continues to surprise us with new releases of the same standard 1 Link to comment Share on other sites More sharing options...
Habu12 Posted September 5, 2019 Author Share Posted September 5, 2019 23 hours ago, guillaume320 said: Awesome bit of knowledge, thanks a lot!! I hope Kinetic continues to surprise us with new releases of the same standard Yeah I was around a CF-104D many years ago. And I was curious, so I walked around checking it out. And I can say that yes, those leading edges are supremely sharp! Not Xacto blade sharp, but if you swiped your hand or arm quickly on them, You could injure yourself. So I had to be careful, and I was able to manually move the control surfaces. Not easily, but still. 1 Link to comment Share on other sites More sharing options...
Gary Brantley Posted September 5, 2019 Share Posted September 5, 2019 Gotta love "the missile with a man in it"! Great build!! 1 Link to comment Share on other sites More sharing options...
72modeler Posted September 5, 2019 Share Posted September 5, 2019 Jawohl! Outstanding '104! At last, somebody who knows how to paint transparency framework flawlessly! Well done! Mike 1 Link to comment Share on other sites More sharing options...
Jbbusybee Posted September 5, 2019 Share Posted September 5, 2019 Wonderful 1 Link to comment Share on other sites More sharing options...
phildagreek Posted September 6, 2019 Share Posted September 6, 2019 Nice. 1 Link to comment Share on other sites More sharing options...
F-32 Posted September 6, 2019 Share Posted September 6, 2019 1 Link to comment Share on other sites More sharing options...
Harry Callahan Posted September 20, 2019 Share Posted September 20, 2019 Well, it seems to be a great kit, but the hype for this kit is high, so i will still waiting till the price goes down. It was the same with Italeri's F-104 in 1/32, first price was 80 to 120,00 Euros, but later it goes down, so i got mine for 56,00 Euros. So its worth to wait. 1 Link to comment Share on other sites More sharing options...
Thomas from ARC Posted October 1, 2019 Share Posted October 1, 2019 The center part of the windscreen is off. The glass should not extend so far to the corner. This leads to the issue that the frame on the left and right is too straight. Overall shape should be more elliptical. Some panel lines are wrong and the intake trunk should extend a little more to the wing rear. The kit is nice, but no need to replace the Hasegawa kit, if you have one. Link to comment Share on other sites More sharing options...
2Step Posted October 1, 2019 Share Posted October 1, 2019 Go Navy!!!!!!!!! 1 Link to comment Share on other sites More sharing options...
Inshala Posted October 1, 2019 Share Posted October 1, 2019 Lovely and thanks for the write-up, one on order I reckon 1 Link to comment Share on other sites More sharing options...
quangster Posted October 1, 2019 Share Posted October 1, 2019 10 hours ago, Thomas from ARC said: The center part of the windscreen is off. The glass should not extend so far to the corner. This leads to the issue that the frame on the left and right is too straight. Overall shape should be more elliptical. Some panel lines are wrong and the intake trunk should extend a little more to the wing rear. The kit is nice, but no need to replace the Hasegawa kit, if you have one. Thomas from ARC , what is the last kit you have finished? Can you show it to us? Link to comment Share on other sites More sharing options...
Thomas from ARC Posted October 2, 2019 Share Posted October 2, 2019 10 hours ago, quangster said: Thomas from ARC , what is the last kit you have finished? Can you show it to us? Sure I can. But what has it to do with the fact, that the Kinetic kit has some issues, when they promote it as so excellent? I only pointed out some of my findings. Maybe you did not notice, that I did NOT criticize Habu12´s build, which is excellent, but the kit itself? Anyway, here we go, my latest two WIP´s (yes I also build tanks): The T-64A is the Trumpeter kit, the M60A3 is the AFV Club kit, which will receive decals from the Revell kit, which has a Forest Green option included. Thomas Link to comment Share on other sites More sharing options...
