Paul H Posted August 30, 2019 Share Posted August 30, 2019 I've built a few ship models already, but these have been Meng's precoloured snap fit 1:700 scale ones as quick mojo fixers (the first two when recuperating from pneumonia last year), and Revell's recent 1:600 RMS Titanic (which I put together for my daughters as they were studing that topic at school) and which only needed detail painting. Having now caught the bug for ships, I have since bought several other kits, which will be much more involved projects and they will also be my first attempts at painting this type of model. I don't have an airbrush & so am intending to paint them using spray cans instead for the bulk of the colour application. Whilst I've had plenty of success with this for car model kits, and also a Tamiya 1:35 Tiger tank that I am currently working on, selecting the right colours for those was easy. Can anyone recommend which Tamiya* spray can colour(s) would be suitable for the following ships, or alternatively any other brands in a similar price range? I've had a look at the online colour charts, but from past experience, have found that these are often not the best match to the actual finished paint... *Especially keen on Tamiya, as they also do brush paints that match their spray cans, and this has worked really well with the Tiger. HMS Dreadnought (both 1:350 & 1:700) Type 45 destroyer (1:700 HMS Daring kit, but to be built as HMS Diamond) Many thanks in advance! Link to comment Share on other sites More sharing options...
Vlad Posted August 31, 2019 Share Posted August 31, 2019 (edited) Dreadnought in what time period? Pre-war you need a very dark grey. I'm not familiar with Tamiya's paint range but a quick Google brings up XF-24; if I had to I would use that. YMMV if you think this makes the model look too dark, as a personal aesthetic preference I don't subscribe to "scale effect" lightened colours. A dry-brush would really help make edges and details "pop out" on a dark ship like this. Wartime Dreadnought, still a dark grey but not as dark. My go-to for that would be Humbrol 27 Sea Grey, which I know comes in both small pots and rattle cans, and can vouch for as having used it extensively on 1/700 ships (although it does look slightly different brushed on than from the can). Tamiya also seems to have a Dark Sea Grey XF-54, which should be about the same thing. The Type 45 is a light grey, slightly blue-ish, that tends to look different based on light conditions. I personally would approximate this sort of thing with the aircraft colour Light Ghost Grey, which Google tells me Tamiya has as AS-26. The decks are a darker grey, whatever you end up using on Dreadnought would probably be close enough here. Edited August 31, 2019 by Vlad 1 Link to comment Share on other sites More sharing options...
Paul H Posted August 31, 2019 Author Share Posted August 31, 2019 (edited) Fantastic - that is really helpful, thank you! I had no idea about the colour change & I have two eras for HMS Dreadnought (1:350 is the 1907 one, & the 1:700 is the 1918 version as didn't fancy trying to make 1:700 torpedo nets) so very useful info. Just off now to look up those colours! Edited August 31, 2019 by Paul H Link to comment Share on other sites More sharing options...
Courageous Posted August 31, 2019 Share Posted August 31, 2019 Hi Paul, welcome aboard. From my point of view, I think you'll find that with Tamiya paints and Naval colours, you'll have an uphill struggle getting the correct colours. You'll most probably find that @Jamie @ Sovereign Hobbies is going to be source for paints for naval subjects but unfortunately for you, the Colourcoats by Sovereign are not aerosols. Stuart 1 Link to comment Share on other sites More sharing options...
Vlad Posted September 1, 2019 Share Posted September 1, 2019 18 hours ago, Paul H said: Fantastic - that is really helpful, thank you! I had no idea about the colour change & I have two eras for HMS Dreadnought (1:350 is the 1907 one, & the 1:700 is the 1918 version as didn't fancy trying to make 1:700 torpedo nets) so very useful info. Just off now to look up those colours! You don't need to "make" torpedo nets. This is what I use for them in 1/700: https://www.hobbycraft.co.uk/beads-unlimited-black-elastic-1mm-x-8m/561557-1000 it's thin enough and the texture is close enough to a rolled up net for the scale. After faffing with stretched stockings on a couple of projects I got this as a test and never looked back. There are different thicknesses as well which may work for 1/350 too. Naval paint colours are one hell of a rabbit hole if you want real accuracy. With the constraints you specified you're in "close enough" territory. If you want to delve deeper, it's a fascinating world but beware all who enter 😂 1 Link to comment Share on other sites More sharing options...
Chewbacca Posted September 7, 2019 Share Posted September 7, 2019 An entry level airbrush is not expensive and will give far better results than any rattle can. I bought my first airbrush (well, first since I bought the Humbrol aerosol powered one 40 odd years ago which was hopeless) from Machine Mart. They used to do 2 or 3 but now just list the Clarke CAB 3P which looks very similar to the one that I bought which was effectively a copy of the Badger 150. Alternatively, Everything Airbrush offer a range of quite capable airbrushes under £20. Couple that with a compressor like this and you have a very passable set up with change out of £75 (plus a couple of quid for an adaptor if you go the Clarke route as the hose is a different thread to the compressor output) 2 Link to comment Share on other sites More sharing options...
