Greg Law Posted August 27, 2019 Share Posted August 27, 2019 This will be my second attempt at doing this P 40-N RNZAF Gloria Lyons 1/48 model. Last time I got distracted by some Zero's. This time there is no distraction here. Hopefully I will get it done. It is a Hasegawa kit. I once had a RC plane I painted as it see below. 5 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted August 27, 2019 Share Posted August 27, 2019 Good morning Greg Welcome aboard and enjoy your build Patrice Link to comment Share on other sites More sharing options...
trickyrich Posted August 27, 2019 Share Posted August 27, 2019 very nice! I wonder if this is a scaled down version of the 1/32nd beasty (or it was scaled up to 1/32nd), either way it'll be a really nice model to build. I've only had a couple of very minor issues with mine. One thing I've noticed in the shot of the sprue, there seems to be a faired indentation behind the exhausts on each side. On the N's it shouldn't be present, I think around the P-40K-5 or -10 (it have been the -1's, the K's used a more powerful version of the Allison engine) this was removed and the section behind the exhausts was smooth. This should be a simple thing to fix. I do like the scheme you've chosen, looking forward to seeing this one built. Link to comment Share on other sites More sharing options...
Greg Law Posted August 27, 2019 Author Share Posted August 27, 2019 Thanks for that info Rich. That should only need filling. I think it is a case of Hasegawa using the same moulds for all the versions. I will be picking up the kit today. So I will have a look when I get back. That was an old photo I took for the last GB it was in. Link to comment Share on other sites More sharing options...
Greg Law Posted August 30, 2019 Author Share Posted August 30, 2019 I've just withdrawn from all Group builds other than this one and the Frog one. This should take some of the stress off me that I have been feeling the last few days. Hopefully I will get an old build finished over the weekend giving more time here. I start Gloria's cockpit tomorrow. 3 Link to comment Share on other sites More sharing options...
Greg Law Posted September 3, 2019 Author Share Posted September 3, 2019 Progress so far is most of the cockpit PE is done. Only a few leavers to put on. Once the cockpit it done I will put up a few images. 1 Link to comment Share on other sites More sharing options...
Greg Law Posted September 3, 2019 Author Share Posted September 3, 2019 Anyone Know what is the best colour to paint a RNZAF P-40N. At the moment I have Olive Drab and Neutual Grey. I thought I would check as I have already made the mistake of painting the cockpit straight Tamiya cockpit green. I will have to live with that as all the PE is done. For the rest eg. wheel wells I will add a bit of yellow. Has anyone got any suggestions on what I can do with the cockpit green. I'm thinking maybe a mist of green yellow mix. 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 4, 2019 Share Posted September 4, 2019 (edited) "Anyone Know what is the best colour to paint a RNZAF P-40N. At the moment I have Olive Drab and Neutual Grey." @LDSModeller would be your man. Edited September 4, 2019 by Corsairfoxfouruncle Link to comment Share on other sites More sharing options...
pacificmustang Posted September 4, 2019 Share Posted September 4, 2019 Olive drab and neutral grey are indeed what you want. Can you mask the PE with blobs of maskol and respray in the correct green? Link to comment Share on other sites More sharing options...
trickyrich Posted September 4, 2019 Share Posted September 4, 2019 this is a quote from the IPMS article on interior colours of WWII aircraft, in this case Curtiss; Unlike some other manufacturers (like Boeing), Curtiss painted their aircraft directly at the factory. The cockpit of the P-40 was Curtiss Cockpit Green, which was the Berry Brothers' (a local paint vendor) approximation of Interior Green. Reportedly it was a little browner than Interior Green. The scalloped cutouts inside the fuselage windows aft of the cockpits on P-40D to M models were usually painted the same as the camouflage colour. As the rear windows could be easily detached for re-painting, most field repaints were also performed this way. Earlier P-36 Hawk production practice and some photos of the early P-40D and Es indicate that Curtiss could initially have used a different colour for the cutouts. It could have been the same as the cockpit colour, but the author was not able to find any positive confirmation of this. You need to do either custom mix for this or if you have an airbrush you can do as I did, paint her Interior Green then mist over some Olive Drab. If the Tamiya Int. Green is too bright/Green then OD will work nicely, just super thin it. No one can really say you're wrong with whatever mix/method you end up using as the colour ended up varying so much with age even without exposure as well (not to mention how it changes on everyone monitor!!). Link to comment Share on other sites More sharing options...
Greg Law Posted September 4, 2019 Author Share Posted September 4, 2019 Thanks guys. What I did was spray a thin mix of cockpit green and yellow green. Then quickly went over the PE with thinner on a cotton bud. This has helped a lot. It will darken up when I do the wash. I'm happy now.🙂 Link to comment Share on other sites More sharing options...
Greg Law Posted September 6, 2019 Author Share Posted September 6, 2019 Just a little update. This is a quick photo of the cockpit work I have done. It took a while as it has a lot of PE in it. 7 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted September 6, 2019 Share Posted September 6, 2019 That's looking great Greg... surgeons work! Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
Greg Law Posted September 7, 2019 Author Share Posted September 7, 2019 Ordered some resin exhausts today which should help the final look of the plane. I've ordered a Mk.II Airfix kit plus PE and masks. I might do it as a double build. It will be a desert one to go with my Typhoon. Link to comment Share on other sites More sharing options...
Greg Law Posted September 7, 2019 Author Share Posted September 7, 2019 Well, the Greg Law Hoodoo arrived this morning. I went to look at the top wing halves this morning. No wing halves could be found. In fact sprue B seems to be missing. I know it was there as I can see the rudder in the kit photo I took for the Pacific GB. I'm thinking it might be in my P-40E kit. I think I had both open at the same time at one point. Fortunately I didn't sell it in my kit reduction sale. I will have to wait till Tuesday to visit the farm again. In the mean time does anyone know if the P-40E B sprue is the same as in the P-40N kit. 1 Link to comment Share on other sites More sharing options...
gingerbob Posted September 8, 2019 Share Posted September 8, 2019 Yeah, AFAIK the wing is the same for the whole 1/48 Hasegawa series. And your scenario is exactly what I do- when I'm comparing stuff, wings or fuselages end up together in one box. Makes it a bit confusing sometimes when, for example, I want to just look at the stock Airfix Spit PR XIX - Oops, this one just has a fuselage... and that looks like an ICM wing... 1 Link to comment Share on other sites More sharing options...
stevej60 Posted September 8, 2019 Share Posted September 8, 2019 Cockpit of to a nice start Greg. 1 Link to comment Share on other sites More sharing options...
trickyrich Posted September 8, 2019 Share Posted September 8, 2019 @Greg Law yeah I can confirm they are the same for all P-40 models. All the hasegawa kits use the same A, B, & C sprue sets, it's after that they change per model. I've got a super cool Hasegawa database of all their 1/48th aircraft kits and all the sprue that each should have...... I know I'm sad! 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted September 8, 2019 Share Posted September 8, 2019 42 minutes ago, trickyrich said: I've got a super cool Hasegawa database of all their 1/48th aircraft kits and all the sprue that each should have...... I know I'm sad! there is one online here https://modelingmadness.com/splfeat/kr/researchfeat.htm which is handy for cursing Hasegawa for gating off bits that would be useful if you had the common boxing of a kit and didn't want to use their crappy decals... 1 Link to comment Share on other sites More sharing options...
Greg Law Posted September 9, 2019 Author Share Posted September 9, 2019 Thanks guys. I'm back on the farm today. Had bad and good news on the missing 'B' sprue. The sprue wasn't in my 'E' kit as I had hoped. The good news is I found I had a third P-40 kit which was a 'K' so I grabbed the 'B' sprue out of that. They don't call me two kit Greg for nothing. Link to comment Share on other sites More sharing options...
Greg Law Posted September 10, 2019 Author Share Posted September 10, 2019 Seen it is so quiet here I will do a progress report. I now have the top wings on the bench. I have joined the fuselage halves and putted the joints. Tomorrow is going to be taken up by a site visit to an Island in the harbor. Hoping the weather will be with me. I'm hoping to get to Greg's stage in a couple of days. Link to comment Share on other sites More sharing options...
Troy Smith Posted September 10, 2019 Share Posted September 10, 2019 On 04/09/2019 at 00:53, Greg Law said: Anyone Know what is the best colour to paint a RNZAF P-40N. At the moment I have Olive Drab and Neutual Grey. I thought I would check as I have already made the mistake of painting the cockpit straight Tamiya cockpit green. I will have to live with that as all the PE is done. For the rest eg. wheel wells I will add a bit of yellow. Has anyone got any suggestions on what I can do with the cockpit green. I'm thinking maybe a mist of green yellow mix. HI Greg spotted this in the RNZAF P-40 colours thread On 11/01/2019 at 07:41, Pete M. said: The NZ Sky Grey was not a grey colour, but was a greyer version of SKY Type S. (NZ) Sky Grey: BALM S13-907. 33B/293 (Fs.35352 - RAF/FAA Sky Grey Bs.631). Although called a grey, it has a distinctly blue/green tone to it. Undersides on P-40, Ventura, Hudson, possibly Corsair, and code letters. My notes from my old (and unable to be updated website*). The colour is from a chip removed from P-40N NZ3220 'Gloria Lyons' which was repainted in the Foliage Green/NZ Sky Grey scheme. The Foliage Green to all intents and purposes was the same as the Australian colour. Cheers, Pete M.🤔 Maybe @Pete M. will pitch in, but a look at the Ventura sheet says it's the same NZ3220. HTH T Link to comment Share on other sites More sharing options...
Greg Law Posted September 15, 2019 Author Share Posted September 15, 2019 This is the next progress shot. Also I have shown the painted rear of the cockpit which is supposed to me Olive drab. It looks too brown to me. It is a Mr Hobby Aqueus paint. You will note I have taken care of the exhaust and light issue. 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 15, 2019 Share Posted September 15, 2019 41 minutes ago, Greg Law said: I have shown the painted rear of the cockpit which is supposed to me Olive drab. It looks too brown to me. A lot of Olive drabs have brown tone to them, it looks correct to me. However if it isn't you're expectation you can change the color. Dennis Link to comment Share on other sites More sharing options...
Greg Law Posted September 30, 2019 Author Share Posted September 30, 2019 Here's my next progress shot. Wings and tail glued on. Wing needs a little putty, but not much. I will be cleaning up tomorrow. 2 Link to comment Share on other sites More sharing options...
