Lorebor
Caudron G.IV 1/48
Hi everybody, this is a Copper State Caudron G.IV, 1/48. Figures come from the Eduard range and some of them were slightly modified; everything else was scratchbuilt...hope you like it...
WOW! That's exceptionally good!
Beautiful. I tried one biplane with the struts etc. and went practically crazy. This project would definitely had done the job 🤪
And that is not even talking about the great scratch work!! Stunning
This is one of the best dios I have seen since some time - love it. I like  especially  the way you weathered the aircraft- well done.
Michael
Very very nice!
Superb model. Particularly like the pictures on the base. Beautiful detailing.
Malcolm
In a word: Ah-May-Zing! What a superb build and fibish, and what a great and believable diorama!
It should be in a museum somewhere.
Kind regards,
Joachim
That is just fantastic! An excellent rendition of an aircraft I did not even know existed prior to opening this thread!
Dear Lord!!!!!!!!!!!!!! Never saw such a  beautiful excellent built model. 👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍
Awestruck question here:  About how many hours do you have in the rigging work? It looks very neat, and I like the use of the tubing, simulating turnbuckles.  And one more question; what are you using for the rigging?    Your work is so inspiring, and I have several models with rigging waiting in the queue,  more info the better!   Thanks in advance!  🍻
Gary,
I didn't count the hours I put in the rigging process but I can tell you it was a big number 🙂
I started with the rigging of the engines struts because it would be almost impossible to reach them once installed between the upper and lower wings.
After gluing the engines and the upper wing, I did the rest of the rigging between the wings. Only then, I glued the tail booms and rigged the rest of the plane (tail, landing gear, tail booms)
I used 0.10 mm fishing line; the turnbuckles were made with 0.5 mm Albion Alloys aluminum tube, painted with Humbrol Gold. The fishing line was painted with Humbrol Flat Black, so that I could easily wipe it off the model in case some paint would drip on the surfaces (the model was painted with Gunze).
Hope it helps…
Edited by Lorebor
Lorebor, yes it did help a lot!  Thanks much for the added info.  Were all the rigging attachment points eyeholes, as it appears?  I assume one threads the line through the eyes and then glues the loose end back to the stretched line?   Or am I completely daft in that assumption (that wouldn't be much of a surprise😉).  It seems I've seen a tutorial for that particular technique somewhere...cheers!  Gary
