Julien Posted August 22, 2019 Share Posted August 22, 2019 Ukraine KrAZ-6322 "Solider" Cargo Truck 1/35 HOBBYBOSS via Creative Models KrAZ is a Ukrainian company which produces trucks and other specialist vehicles based in Kremenchuk in the Ukraine. The 6322 is an 6x6 truck designed for off road use and in extreme conditions making it ideal for military use. Like many trucks is comes with a wide variety of body types, the "Solider" version being the general cargo truck type. It is powered by a V8 turbocharged diesel engine giving it a top speed of 75 mph. The Kit This is a new kit from HobbyBoss of the 6322. The kit looks good on the sprues with lots of detail parts. Moulding is first rate. and the kit looks comprehensive, with PE parts, window masks, and rubber tyres.Construction starts with the V8 engine. This has quite a lot of detailed parts, in fact the first 3 pages of the instruction booklet detail mainly with its construction. The gearbox is also built up and then attached to the engine. Transmission boxes are constructed at this stage for later placement in the chassis. The chassis is then built up from two major side rails with some cross components, the engine/gear box is added along with the main transmission box with a shaft linking it to the gearbox. A chassis mounted winch is then built up and added to the chassis along with its PTO shaft. Rear light mounts are added at the rear while at the front the main bumper is assembled and added. The exhaust is also then added. Next up we move to the rest of the transmission and suspension components. The front axle is made up and added (the leaf springs being moulded onto the chassis rails), the transmission shaft then connects this to the main transmission. Shocks are then added and the wheel hubs can then be made up and added. The steering box and connector shafts are then added. The two rear axles share a common mounting to the chassis and leaf springs are added for this. The individual axles are added to this and the transmission components added and connected up with their drive shafts. The fuel tanks, battery box, air tanks, and drivers steps are all then assembled and added onto the chassis. All of the wheels and tyres are then put together and added. This now completes the chassis. We now move onto the vehicle cab, The seats are made up and added to the cab floor and the floor mounted controls added. The dashboard, steering column, and wheel are mounted to the cab front and the front glazing is added. This sub assembly is then mounted to the floor. The back of the cab with its glazing is then added, along with the doors which can be open or shut as required. Lastly the roof is put on with its lights being added. The font wings are added with the grill then going on as well. The bonnet is added and the air cleaner made up and mounted to the side. Last up the mirrors and wipers are added to the cab, The cab is then mounted to the chassis. At the rear of the cab an equipment locker and spare wheel carrier are made up and added along with the spare wheel. Last up for construction is the rear cargo body. The underside stiffeners are added then four sides can be added to the main floor. Seats familiar to every military truck are then added to the sides, these can be raised or lowered as needed, Back on the underside the mounting points and mud flaps are added, The body can then be added to the chassis. If wanted a large one part moulded rear cargo body canvas cover is provide. Your truck is now complete. Decals Decals are provided for for one Ukrainian truck and one Russian one Conclusion This is a great looking kit from HobbyBoss and their attention to detail is to be commended, the only downside is the one part cover for the back, it looks too toy like, and there are no seperate supporting frames for the back to display the kit with the rear cover off. It is thought good to see more military softskin vehicles being kitted. Overall Highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
