AVRO Shackleton MR.3 (03873) 1:72
Mike
1:72 Revell
The Avro Shackleton was a long-range maritime patrol, Anti-Submarine Warfare (ASW) and Airborne Early Warning (AEW) aircraft developed by Avro from the Lincoln (with a few elements borrowed from the Tudor), which in turn was developed from the wartime Lancaster bomber. Powered by four Rolls Royce Griffon engines driving contra-rotating propellers, the Shackleton possessed far greater range than its forebears, enabling it to stay airborne for over 14 hours, despite its higher gross weight. In the Maritime Reconnaissance role it began life as a tail-dragger that bore more of a resemblance to the old Lanc, which morphed from versions 1 to 2 with a longer nose and relocated radome, into the MR.3 that added a nose-wheel that brought it more in-line with the tricycle undercarriage sported by the rest of the fleet as it modernised.  The MR.3 was further modified with additional equipment inside both to improve its abilities and enhance crew comfort (a little) on those long sorties, which were further extended by the fitting of wingtip fuel tanks.  The twin 20mm cannon in the nose and the complement of stores in the bomb bay were key, and the Phase 3 had two viper turbojet engines added to the rear of the outboard nacelles to improve take-off performance when heavily loaded.
The Kit
Revell's new tool in 2016 was eagerly awaited by many, as modellers had waited over 40 years for a new kit of the Old Grey Lady, with the AEW.2 the first out of the gate.  Now we have an MR.3 with changed parts to depict this quite different version of the much-loved Shack.  Inside the large end-opening box are 209 parts spread over twelve sprues in grey styrene, two of clear parts, a decal sheet and instruction booklet with colour painting guide to the rear.  The mouldings look excellent, with fine, engraved panel lines, recessed rivets and plenty of crisply rendered detail. A great deal of effort has gone into the tooling of this kit.
As usual, construction starts with the cockpit. Whilst it doesn't feature a full interior, Revell have done a good job of representing the inside of the Shackleton. The cockpit itself features nicely detailed seats with separately moulded armrests, decal seatbelts, and control yokes, while the detail on parts such as the instrument panel is exquisite as you can see from the detail photo above. The rear crew stations aft of the bomb bay are also nicely represented. Crew seats are moulded separately and there is plenty of moulded-in detail. You can even finish the model with the rear door open in order to show off a little more of the inside. The fuselage itself is broken down into front and rear sections that we rightly assumed were hinting at further releases, and features a double wing spar fixed to the roof of the bomb bay which, just like the real thing lends a lot of structural strength to the model. Before sealing the fuselage halves together, don't forget to fix the small side windows in the fuselage from the inside beforehand. While we're on the subject of clear parts, those provided with the kit are excellent, being both very clear and nicely moulded. The bomb bay doors are split and can be finished in the open position if required, but Revell provide no stores to put in there.  The canopy and top hatch glazing are installed after the seams are dealt with, and here you'll need to be careful to get a good join to minimise clean up, although you have a much better chance of retaining all the rivets as they're recessed.  If sanding starts to make them faint, you can always stop and deepen them with a bradawl or pin.  The big nose cannon are fitted to the pivot from the inside and attached to the hole in the nose along with the curved canopy on top and a trapezoid bomb-aimer's window below.  At the rear there is a clear stinger for observation purposes.
The huge wings are split into upper and lower halves, with separately moulded ailerons and landing flaps which once assembled simply slide onto the wing spars to form a nice strong join. The rudders and elevators are all moulded separately too, so bonus marks go to Revell for including this useful extra feature, and the tip-tanks are separate with a clear lens added to the front of each one. The engine nacelles are very finely represented with superb moulded-in detail and separate cooling flaps, with the main landing gear bays sandwiched inside the inner engine pods. The landing gear is absolutely fine, but on the other hand you want to hang your Shackleton from the ceiling, you can close the landing gear bays up completely and save yourself the trouble of painting the wheels. There are also alternative outer nacelles with the exhaust for the Viper turbojets if you choose to model the Phase 3 example, which is good to see.
Aside from adding a host of aerials and other small details such as the belly-mounted radome, all that remains to do is assemble and paint the propellers. This is no mean feat due to their sheer numbers – 24 tips in all.  That's the bonus of contra-prop models, twice the props, twice the fun! Tackling this sub-assembly first might be wise as it is bound to be quite time consuming and could seem more of a chore if you're approaching burn-out at the end of the project.
Markings
There are two decal options supplied on the sheet, each one taking up two pages of the booklet, but you'll need to flip pages whilst decaling as they aren't pages that face each other even though there is a blank page at the back.  Both options wear the same high demarcation white fuselage over dark grey scheme, and from the box you can build one of the following:
  • Shackleton MR.3 (Phase 2) No.206 Squadron, Royal Air Force, Kinloss, Scotland, 1965
  • Shackleton MR.3 (Phase 3) No.42 Squadron, Royal Air Force, St Mawgan, Cornwall, 1970
Decals are printed for Revell by Zanetti, which is a guarantee of good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas.  You can have a look at our Walkarounds by clicking on the buttons below for a bit more incitement if the pictures of crisp plastic detail aren't yet loosening your wallet.
MR.3 (Phase 3) WR977 @ Newark Air Museum
MR.3 (Phase 3) WR982 @ Gatwick Aviation Museum
Conclusion
It's hard to believe we've been blessed with two modern toolings of the Shackleton and now four variants are covered, with the Revell kit appearing to be free from what most would consider to be major potential oopsies. surface detail is superb, with its beautifully rendered panel line and rivet detail, making the competitors look a little soft by comparison. Overall a very pleasing effort for this variant from Revell that has tempted this 1:48 modeller.
Very highly recommended.
Revell model kits are available from all good toy and model retailers. For further information visit
  • Thanks 5
Nice review and it is indeed a lovely kit.
I cannot reiterate this enough, and hopefully to the benefit of other modellers, Phase III mods and the addition of Vipers were quite separate, indeed WR975 portrayed in the kit is actually an MR.3 Phase III and XF703 is a Phase III (Viper).
On your review sample the red in decals look almost like the wartime brick red, however in the hand they look like the proper bright red.
6 hours ago, old_tonto said:
Could this kit be used to build a South African Air Force MR.3?
Yes. But you’ll need after market decals. Dutch Decal are going to re-release their beautiful set for the SAAF Shacks.
For what it's worth, this old Shackleton-lover (in both senses - I'm old, and I love old Shackletons), this is a lovely kit. I've done quite a bit of work on mine and only have one real complaint. On my example, two of the twenty-four prop blades were short-shot. My AEW.2, which apparently used the same moulds for these two sprues, doesn't have the short-shot parts, but I guess it was Friday afternoon and they were running short of polystyrene when they moulded my kit. Oh well, if they hadn't done this, I'd have precious little to complain about on the kit. This is one kit I do actually believe I'll complete. I completed the Frog kit over forty years ago, so I suppose it's time to complete another one. With the AlleyCat MR.1 conversion kit, which I'll combine with my Airfix AEW.2 (I'm building the Revell AEW.2), I'll have all four major versions of the Shackleton. But then I suppose I also need the T.4, and a SAAF MR.3, maybe an early and a late version...
Regards,
Jason
Edited by Learstang
Mine has arrived. So how much of the already available aftermarket stuff (Wheels from Barracuda, etch from Eduard etc.) can be  used with the Mk.3? Or is the beast so different we have to wait for specific releases?
Mine arrived today as well, however the box was heavily crushed but thankfully all parts seem intact.
Now don't Barracuda just make resin replacements for the earlier and much larger MR.2 / AEW.2 wheels? The wheels on the MR.3 are much smaller in comparison, You might be able to use some etch, however one would think that AM canopy masks, wheels, decals and a dedicated etch set for the MR.3 won't be too far away. I'll probably just buy some canopy masks as that looks to be an essential item to get things nice and crisp.
Cheers.. Dave
Glad to hear the parts are okay with your kit, Dave, despite the crushed box. Now this is one reason why I like tray and lid boxes. A lot of modellers seem to think it's no big deal, but one of the very nice things about tray and lid boxes as opposed to those wretched end-opening ones is they are much stronger. I can stack a bunch of tray and lid boxes several feet high with no crushing. Try that with those end-opening boxes. Stack two good-sized examples of those and they start deforming. Back to the MR.3, I'm certain the folks at Eduard and other AM companies are busy creating aftermarket goodies for this kit, not that it really needs many. The canopy mask you mention would be nice to have, though. That clear-view canopy is very important to the overall look of the MR.3.
Regards,
Jason
Edited by Learstang
Slight change. Really just a trifle. Hardly worth mentioning.
Thanks @Learstang, and after my recent episode with said type of flimsy opening box, I couldn't agree more with what you've written above.
Now back onto the AM stuff, I get the feeling that Revell may have kept this version a little on the quiet as one would have expected both Eduard and Xtradecal to have their products already available to add to your favourite retailers online shopping cart? Hard to think of a recent 'British' subject where Xtradecal didn't have a decal sheet at least as a 'Future item' before the actual kit came out.
Cheers and I look forward to putting this together (after all my GB commitments!)... Dave
This kit did not seem to have the fanfare I would have expected for such a nice, new-mould kit of the MR.3, especially considering that many modellers have been dreaming about such a kit for a long time (yours truly included). An interesting item I noticed was the trademark on the MR.3 wing reads '2015', so it appears that the moulds on this kit, or at least some of them, may have been ready for a long time. It's all a bit strange but I'm just thrilled to have such a nice new-mould kit of the MR.3. On mine, I'm 'going-to-town' on the weathering of the white interior bits, such as the wheel wells and the bomb bay. Since the version I'm doing is from 1970, towards the end of their long career, I'm guessing the bays were all rather tatty. What I start out with is white; what I'm ending up with is a sort of grimy light-grey. Perhaps a bit overdone, but I like the look.
Regards,
Jason
Edited by Learstang
  • 4 weeks later...
Yes, I'm equally mystified by the almost complete absence of reaction: not so much as a "Meh".  Maybe all eyes are on the Buccaneer.
One point to make is that there is a review out there on the internet that shows upper wings with utterly horrible shrinkage on the top surfaces above the flap area.  That is not normal or at least my example was nothing like as bad.  There is a tiny bit of shrinkage right up close to the join with the fuselage but IMHO it's so minor that it probably won't be worth jeopardising the surface detailing by trying to rectify it.
Yes, I remember all the hand-wringing when some of the first releases of the Airfix MR.2 had some shrinkage and short-shots. It seems that got sorted out. I'm well into constructing my Revell MR.3, and I haven't encountered any major problems (other than a couple of the propeller blades, speaking of short shots). My kit has a bit of shrinkage above the flaps, but nothing that I'm going to get worked up about. As far as I'm concerned, this is a lovely kit, and my building of it so far has not changed my mind. I remain mystified at the lack of reaction to its release, as well as the lack of pre-release interest. You'd think by the lack of reaction that this is a second-rate kit, but as I indicated, in my opinion at least, this is a very nice kit. But, then we modellers are a fickle lot, like children who are easily distracted by anything shiny (like another new kit).
Regards,
Jason
Edited by Learstang
Additional comment added.
Well, I've now taken the runners out of the bag and looked at them in good daylight.  That shrinkage is definitely there (where the front of the flaps bay is on the underside and, just perceptibly, fore and aft where the ribs are) and quite visible in certain lights.  It's not enough to worry a bodger like me who'll probably never build the thing anyway but could disappoint anyone planning to build this kit to display standard.  If I ever get round to finishing mine, I'll let you know how obvious it is on the finished model.
I am not a Shackleton expert but, as kits, I still prefer the Revell Shackletons to the Airfix ones.
  • 9 months later...
Hey Mike,
This kit looks awesome, very close to hitting the naughty “buy it now button,” on eBay. Any idea how many paints I can get away with? The thing is I’ve got, a Fort, 109, 190 and Dauntless all at various stages of box sealed openness to half assembled. Any ideas on how to justify  buying another kit?! Seriously any reasonable excuse will do 😀 it’s a sickness. I swear this hobby is addictive, or at least the acquisition of kits, bits, paints etc. Looks like this particular model isn’t going to be discontinued any time soon so I must finish one my current ones! I’ve not published any work either on here, just been enjoying other people’s projects, definitely learned a lot. Thanks to all for that.
Cheers as always for great articles,
Stu
Edited by blanco77
More on topic
An update to post 17.  I did start building the Shackleton (and have still started building it). I quickly decided that the shrinkage would be in fact very visible if not tackled and that remedial work would damage the lovely rivet detail.  I complained to Revell and received 2 new upper wing halves.  A little shrinkage is still just visible if you’re really picky but I’m happy now.
Bottom line: this is a recognised problem with this kit (though may be confined to early issues) so don’t fume in silence.  Otherwise I love the kit.
Message for @blanco77: I think the Revell Shackleton AEW has already been remaindered.  don’t count on the MR,3 being around for long.
Edited by Seahawk
The sinkage is very slight on mine, funny old thing this was a problem with old Frog/Novo/Revell MR.3 and I think it's to do with the amount of plastic needed in the flap bay area.
Mind you, when you see the state of a real Shackleton upper wing after a few years of service I would say that the sinkage adds to the beaten look!!
  • 3 months later...
Are there paint schemes for Phase 3 (Viper) aircraft with Union Jack? Or such a combination  is impossible from the time period point of view ?
3 hours ago, 71chally said:
Good question @Bear.
Generally the Union Jacks were applied to Shackletons involved in long range or World tours, but this seems more unusual in the Viper period.
I will look through some books when I get a chance.
According to the Shackleton Association, "Allocated to Avro Langar 3.63 for Phase III update, completed 1.65 when despatched to 206 Sqn and coded S. To 120 Sqn 3.66 and became A. To HSA for Viper fit 1.67"
Photo of "A" here https://www.airlinefan.com/airline-photos/Royal-Air-Force/Avro/Shakleton/WR975/1664503/ - doesn't like a flag either.
Edited by Broadway
additional comment
Hey @Seahawk, took your advice and purchased the kit. It’s every bit as good as Revels newish Fort, maybe even better. The box art is worth buying alone. If you can get one, it would definitely make a great Christmas present. Thanks again for the advice.
