17 hours ago, opus999 said:
touch it up with polished aluminum
As a novice model builder, but a professional painter in my time, I recommend you wait on the fix for a few days, just to allow the paints to fully harden. That way, when you sand the area, the new tape won't damage the finish. Plus, it might be a nice look if you find the panel lines where the damage is, and repaint the panels just like a repair on the real aircraft. Then it would not matter if the repaint is different, it would actually add to the realism.
That said, the subtle differences do show up in the pictures, just enough to allow everyone to understand what you were going for, and accident or not, you nailed it. She looks great!
Anthony
On 21 August 2019 at 4:22 PM, Andre B said:
The Humbrol "Metal Cote" spray cans is good to...
I'm a Metalcote user. I like them and wont change unless there is an improvement by another manufacturer in enamels. I mix them regularly to get different shades. They buff up very well.
Martin
I must be right 'duffer' then. I used Polished aluminium an my first couple of Sabres and I could never get them to look right, so I moved across to Tamiya AS-12. I'm sure I was doing something wrong. What is your secret Martin?
Stuart
Stuart
Hi Stuart,
No secret. When I first started with it, I applied it too thickly. I ended up with surfaces that looked like sandpaper. Of course you have to buff them but even so I couldn't get it right. Over time I realised that it needs thin layers, particularly the Polished Aluminium. The Steel is great always. Then, of course, you can mix them. I find that using 27002 Polished Aluminium with very very small dots of Steel added in varying amounts you can build up differing tones. It still isnt Alclad or anything like that finish but then I opt to avoid laquers and the resulatant vapours. Having said that I know that others out there will say that Metalcote has a vapour but it isnt to the same level. I'm happy with my finishes. They may not be perfectly realistic but hey ho!
I have Mustang No.1 emerging from the paint shop at the moment. She has mixes of Metacote and, I think, she looks great. She should be RFI this week or early next, depending on what time I have.
Martin
Edited by RidgeRunner
Point well taken.  I waited for a couple of days and got started on a P-40M in the meantime. :D
Interesting thing about these paints... I can mask them all day long and I haven't had any problems, but they wear off very easily.  I've already had to touch up the leading/trailing edges where the black undercoat was showing through.  Also, when I was doing some touch-ups, I was using a paper towel to hold the model (to avoid fingerprints) and, even though the paint had cured for 4 or 5 days, there was an indentation in the paint from the paper towel.  A small blemish, luckily, but definitely something to be aware of.
I still really like these paints though.  Both the polished and regular aluminum both fill a void that I needed to fill.  I have a B-25 and a B-17 that are just waiting for a coat of that polished aluminum!
That's good to hear!
you nailed it.
Thanks! I'm really happy with how it looks so far...
On 9/2/2019 at 8:27 AM, RidgeRunner said:
Hi Stuart,
Martin
This has been a pretty interesting discussion for me... but I'm not sure if I can get Metalcote easily in the US.  I've heard of it quite a bit though!
I’ve also noticed wear on leading/trailing edges.
So I touched up some stuff... And did a very, very faint post shading along selected panel lines by masking along the lines and then dusting it with Alclad Magnesium.  Where it came out too dark, I could just dust with the polished aluminum and it came out looking just fine.  The lines I shaded were along the center panels of the wings and the seam where the plane splits in two to access the engine.
Today I am doing decals which is going remarkably well for being older decals (ca. 1990s).  Of course I am finding stuff I forgot to paint (walkways, top of the tail), but luckily I figure it out before I put decals on  the area.  I think what is throwing me off is Airfix using numbers in squares to indicate decals and numbers to indicate paint colors.  I think it would go better if they used letters and numbers, but that's just me.....
Decals done! Did a little subtle weathering and wear using Tamiya pastels and some water color.  A little staining around the filler caps and the odd dirt streak here and there.
Last things to do are clear coat it and paint & glue the exhaust in.  I experimented with clear coats and found that spraying Testors metalizer sealer didn't really change the look of the NMF in a noticeable way, so I'll be going with that.
Hi! If you are content with Alclad and struggle to get Metalcote stick with it. It certainly produces a great finish. :). As an example, my recent Mustang was Metalcoted, as was my YF-104A a short while back. You can see them on RFI.
Martin
Superb :)
Oddly, as you mention this, I tried a black undercote for the first time on my Current Sabre build. When applying the MetaCote 27002 the black persistently appeared here and there. I really dont know why. I wonderEd about a chemical imbalance somewhere and so washed the model but it still happened. I eventually wrestled it in to a good finish but it caught me out. I might not bother with the black again!
Martin
 I actually finished this last Sunday night with a coat of Testors Metalizer sealer, which didn't seem to affect the look of the paint at all.
It was the first full week of school for all 3 of my kids, so weeknights were hectic! What little time I had at the bench wasn't enough for photos, so I did little tasks on my P-40M
But, I have time today, and so, without any further ado, here is the RFI!
8 hours ago, Corsairfoxfouruncle said:
Do you have a next project ? If so let me know so i can follow the build.
Dennis
I'm currently working on the P-40M, which you've seen, and just this morning started a pair of Spitfires that I plan to start posting about tomorrow.  I'll tag you when I do.
