Sign in to follow this
JockMcPlock
* Aprons & Pans - Egg Banjo anyone? * DIORAMA INFO NEEDED
Dioramas!
Never made one but I've seen a couple of short videos on YouTube about them, and the seem quite involved to say the least.
I'm going to be looking for a few, and specifically a circular RAF dispersal pan from WW2 for a Heavy Bomber in 1/72 and 1/48 scales.
I was wondering, what is available out there, made and ready to go?
I have seen the sort of flat rectangular cardboard types (not really a fan of these), but what do people know about others with texture, foliage and a little bit of undulation etc?
I was also wondering if there are companies, or people on here that will commission and create dioramas to  a clients request?
What experience do people here have with either of these avenues and the cost implications?
Would be great to see some images from anyone that has made or bought some of these dioramas!
For a base see Coastal Kits; www.coastalkits.co.uk
You can add your own grass to the Coastal Kit bases to make them more 3D
Amera does vac bases for you start making your own;  http://www.amera.co.uk/
I kept well clear of dioramas for a long time because I thought they were too difficult, but now I find that they are one of the most enjoyable parts of modelling, so why not give it a try? This is my second dio – which cost only about £50 (excluding the aircraft and other vehicles):
It doesn't have to be expensive. This base I made for virtually nothing (I said £0 but the milliput for the sandbags probably 20p and the PVA probably 10p):
I'm never really very impressed with the realism of the commercially available dio bases, and the cost is usually quite high. Give it a go yourself, you might enjoy it.
It may have to be those CoastalKits, though at £25.00 each for a flat dispersal pan, plus whatever extra, this could turn out to be quite expensive.
I really like how you've used fine grit sand paper for concrete!
The dioramas I need will not be so overwhelming with so many intricacies, but I wonder if there's a diy way to produce many from bulk material.
I would suggest the answer to this is down to your skills, how realistic you want the result to be and how much time you are willing to give to building the base(s).
My check and cheerful solution is to purchase suitably sized pictures from charity shops, where the frame is what I want. Put a formboard insert into it and then use printed tarmac etc and static grass.
There are a number of free, and paying, sites on the internet where you can download surfaces
I have used both:
Scalemodels
 and
Scalescenes
For static grass there are a number of suppliers  and I would suggest using a search engine for worked examples and recommendations. My testing was carried out using Gaugemaster  but I also have experience of other more realistic systems including Peco
Good luck with whatever route you take and perhaps you will post some builds on Britmodeller.
My check and cheerful solution is to purchase suitably sized pictures from charity shops, where the frame is what I want. Put a formboard insert into it and then useptinted tarmac etc and static grass.
I have used both:
https://www.scalemodelscenery.com/
 and
I would say that I've never made dioramas before, but "how hard can it be".
That site is much cheaper than the Coastalkits boards you can buy, the only thing I would say is that it's a little limited on types of surface and for me, since accuracy is important for me, I couldn't use the generic stuff they have on there.
I will have a look around for some of those other sites you mention to see if they have the surface type that I need.
On ‎8‎/‎16‎/‎2019 at 4:00 AM, JockMcPlock said:
I would say that I've never made dioramas before, but "how hard can it be". ...
truly spoken as any home handyman who has watched a youtube video!
point being, a lot of people can build crap and boast with confidence. what are your performance standards? what is your audience? what is your goal?
once you minimize someone's contribution, you may be alienating someone who could have helped you.
Well this is the problem with reading text, you read it in the manner that you choose, and not the manner in which it was written.
I'm not sure who you think is likely to be alienated by Jock's comment, certainly not me. In fact I think it's the correct way to look at it – most of it isn't as difficult as it looks.
s.e. charles sounds like a good bet.
Edited by spaddad
Let me clear this up...
Truly if it was a case of "how hard can it be" then I don't presume I would have had a need to ask for advice or assistance initially and create this thread.
The poor insult of "truly spoken as a home handy man who has watched a youtube video" was pretty uncalled for given that you know nothing about me and degrading to those who produce their youtube video guides to assist others, of which you will find many with suitable step by step guides producing very impressive works of art, and they are works of art. You may find that you're inadvertently causing offence to many others yourself.
Just be friendly and a little less on the negative.
Edited by JockMcPlock
Some people can't be anything else. There are people who lurk around on this site just waiting & hoping to be upset, best to ignore them for to get into it with them is a waste of time, unless of course it's just to wind them even tighter.
I was somewhat disappointed by the Egg Banjo in this thread......
I was hoping for something a bit more like this
Preferably at stupid o'clock in the morning, liberally covered in Gun Oil, Hydraulic fluid, Blood snot and various other unhealthy products.
Yoke still runny, ideally dripping down the front of your Noddy Suit.
From a time when Men were Men, sheep were scared and we all went to war with a Hereforder Handbag in our hands.
Meanwhile, back on thread...
Chill out guys, we're only playing with models here.....
'Ere, I see's yer banjo and raises you a 'baby's 'ead'!!
Another delicacy that only reached the dining tables of a privileged few.
Although the annual cook up of Lifex Compo Sausages in the cookhouse was another of Lifes great pleasures.
