Grant Mk.I Full Interior Kit (35217) 1:35
Mike
1:35 MiniArt via Creative Models
In the years before WWII America realised that they were lagging behind in respect of armour, a fact that became especially clear when Germany came out from under the Versailles treaty to show off and then use their new tanks and Blitzkrieg tactics.  The M3 Lee was conceived in 1940 as a medium tank carrying a powerful 75mm gun, partly for manning by their own crews, but also because Britain had requested a large number of tanks to make good their losses from Dunkirk.  The Lee was a decent tank but suffered from a high silhouette and limited traverse of the sponson-mounted 75mm gun, but was still widely used.  In British service it was known as the Lee if it was fitted with the original American turret, or the Grant when using the lower-profiled British specification turrets.
The Grant eschewed the mini-turret on the commander's cupola that resulted in a reduction in height and a minor simplification of construction and maintenance for very little loss in flexibility, due to the coaxially mounted Browning machine gun in the turret.  It was used primarily in Africa and the Pacific theatres where the 2nd line equipment seemed to be fielded (for the most part) by the enemy, and against the Japanese who were far behind with their tank designs and tactics.
The Kit
MiniArt began 2019 with a new tooling of the M3 Lee and have expanded their range by adding new parts as they go along.  The primary changes in this boxing are the inclusion of a new cast turret with no machine-gun turret-let on top, and the inclusion of British equipment inside and around the exterior.  We've come to expect great things from miniArt's new kits and of course this one is no different with a ton of detail included both externally and internally, as it is a full-interior kit with the increased part count that comes with that.  The box is standard MiniArt fare with an attractive picture from their usual artist, and inside are a huge number of sprues of varying sizes with 67 sprues in grey styrene, a single sprue in clear, a fret of Photo-Etch (PE) brass, decal sheet and the instruction booklet with painting guide at the rear completing the package.
Construction begins with the vehicle floor onto which the transmission and final drive assemblies are fixed along with a long drive shaft.  The front crew stations are installed around the final drive, and in the centre is the ammo storage with a tread-plated top with the engine firewall behind it.  The ammo bin can be posed open or closed using the same door parts, exposing the striking plates moulded into the assembly, and more shells are added to the firewall in racks.  Just in case the tank isn't quite flammable enough, a spare fuel can is strapped to the firewall, as are a couple of radiators which I'm hoping can be switched off or redirected in the desert!  Moving to the lower sidewalls, these are separate parts and are fitted out with equipment such as fire extinguishers, ammo and a Thompson machine gun with the bow gunner's bench seat added to the starboard side as they are joined and the sponson floor fitted at right-angles using slots and tabs.  Take care here to clamp them firmly against the bottom of the firewall to prevent them from drooping while setting, which would open up a world of pain if they set out of position.  The rolled lower glacis part is also added, and the final drive bell housings that are incorporated into the sidewalls mate with these to complete the shape of that area.
The Lee/Grant and to an extent the Sherman were powered by radial engines that sat vertically in the hull and can be blamed for their slightly tall hull shapes.  This is provided in detail with the kit with all the cylinders, push-rods and exhaust tubing, plus the tin-work that helps cool the engine all mounted to a sturdy lateral mount that goes around the ancillaries at the rear.  Two cheek parts are added into the engine compartment first, and the engine rests on the brackets protruding from the walls.  Various tanks and reservoirs are squeezed into the remaining space along with piping for the twin airboxes and the general "spaghetti" that's seen on this kind of engine.  The supports for the engine cover are fitted to the sides and the aft bulkhead with access hatch and twin exhaust stacks close in much of the hard work, with twin doors (open or closed) at the back and a PE mesh grille completing the top of the area, allowing the rising heat to escape.
The lower hull is finished off with a pair of short arches over the drive wheels and a host of additional equipment filling up the interior with more shell storage, tanks and auxiliary generator.  The big 75mm gun and substantial casemate are built up next for fitting into the hull front and the curved splinter shield that allows 14o of traverse to either side to counter any errors in position from the driver or enemy movement.  The breech is surrounded by a shield and has the manual traverse wheel and other driver controls plus his seat and sighting gear included, as well as another box containing the 75mm shells peculiar to his gun.  Before it can be installed the super-structure must be built up to accommodate it, including the sidewalls, the curved surround and the angled front panels of the glacis.  The various hatches can be posed open or closed, and an instrument panel is fitted to the inside of the glacis.  The bow machine gun is actually a twin mount with two .30 cal M1919s firing through a hatch near the port sponson.  The rest of the hull is then built up in much the same manner as the real thing, but with glue and the rivets only there for show.  Fuel caps and another Thompson are added along the way, and when we reach the engine deck there are two large panels, the smaller of them having PE grilles and more filler caps, with both of them covered in small PE tie-down lugs.  The rear of the deck overhangs the hull and a small armoured "skirt" protects the tops of the exhausts from stray rounds where PE brackets are used to hang the aft lights.  The completed deck is then covered with pioneer tools and their PE tie-downs, plus the towing cables that you need to source yourself to go with the plastic eyes at each end.  A scrap diagram shows their location and how to fix the PE straps to the tie-downs and eyes, with a length of 145mm suggested.
At this stage the majority of the hull is built, but it is likely to fill with rain until the roof is fitted.  Before that the surround to the turret basket is completed with stowage space for six canteens moulded into the parts.  The stiffening plates to the lower glacis are also glued to the hull and then the roof is made up from a large main part that is stiffened with a number of ribs, and an extra section is attached to the side with a small periscope in the middle.  The three square access doors for the crew can all be posed open or closed with latches and small viewing hatches within that can also be posed open.  After fitting the armoured cover to the main gun's periscope and a few grab handles, you get to build up the running gear.  Aren't you lucky?
The Grant's suspension is very similar to the Sherman's with two fat wheels on a bogie with a return wheel at the top, and there are three per side.  The wheels with their moulded-in rubber tyres are attached to the bogies via swing-arms that pivot inside the cast bogie with an additional arm linked to the compressible rubber towers.  Before the front of the bogie is fitted the return roller is installed so it is trapped between its two bearings.  Repeat that six times and then make up the idler wheels, which have PE edges and separate hub caps.  The bogies are attached to the sides of the hull on their mounting plates, and two stiffeners are added to the top of each one, while the idler wheels are attached to their axles on the adjustable tensioners.  At the front the drive sprockets are made up from two parts with an internal collar allowing them to remain mobile if you're sparing with the glue.  A short break has you fitting the driver's hatch and optional clear window with a PE wiper blade, plus a couple of towing eyes with shackles under the glacis and some truly tiny parts in plastic and PE between them.
Tracks.  Love 'em or loathe 'em, they're a necessary part of most tanks and you have to do them eventually.  There are 79 track links per side, and each link is made up from four parts.  The pads are split to accommodate the links between them, and this is a little fiddly.  I built my test section up on a flattened piece of blutak to hold them in place, but if you have a commercial or self-made track-making jig that you've purchased separately you might find it a little quicker.  That said, each link is good looking with fine detail at the ends, and they are flexing nicely as per the real thing.  It'll take some time to complete them, but they will be excellent as long as you're careful with preparation and the glue.
With the tracks in place, the side skirts can be installed and the additional stowage boxes can be fabricated from their parts and attached to the hull with PE brackets, their shape conforming to the surfaces that they are placed on.  The side skirts are finished off with mudguards at the rear by boxing in the tops of the track runs.  The rest of the pioneer tools are bracketed to the hull along with the front headlights and their PE protective cages, the former having PE tie-downs and brackets holding them down.  You will need to find some thin wire to link the headlamps to the gland that takes the cable inside the hull, then the single-part main gun barrel is nipped from the sprues, has its seamlines removed and is joined to the optional two-part blast-bag that has excellent realistic-looking canvas wrinkle and sag moulded in.  We're still not quite ready for the turret though, as there are a number of PE parts stretching the length of the side-skirts which are used to hang additional stowage in the real thing.  These fit onto small depressions on the sides of the hull, and scrap diagrams show the correct way to fold the perpendicular front sections.
Now you can start the turret, most of which is held within the upper part, and that has some very nice casting texture moulded into it that should look great under a few coats of paint.  The frames for the small hatches are first to be added, then the hatches themselves are fitted in the open or closed position with small stays holding them at the correct angle for the former.  The sighting equipment, racks, and fume extraction equipment are then fitted before the breech is built up and fitted, making adding parts after more fiddly.  The breech is started by joining the two main parts together, adding the surround, the coax machine gun, then setting it aside while the mantlet and elevation mechanisms are made up.  This all fits in the back of the riveted mantlet cover and includes a periscope next door to protect the viewer from being injured by direct small arms fire.  The breech is slid into the mantlet and an ammo box is attached to the starboard side then the completed assembly is inserted into the turret from the outside.  More equipment is fitted into the lower areas of the upper turret and into the lower turret part, including the increasingly important radio gear and their aerials once the two halves are joined.  Next up is the reduced height British spec cupola with grab handles and a choice of open or closed hatch with periscope in the port door.  The commander's .30cal weapon is mounted on a curved fitting on the front of the turret and is fitted with a drum magazine that has moulded-in bullets plus a separate short length that feeds into the breech, sandwiched between the two end-caps with built in mounting frame.  The turret basket is bucket-shaped with a cut-out to one side to allow entry and exit, plus stowage space for more ammo for the guns and the machine guns, fire extinguisher and small button-seats for the crew.  Additionally there is an opening door to the basket that widens the aperture and contains a pair of tanks for the electro-hydraulic rotation equipment.  A studded bezel is installed in the top rim and the rest of the traverse equipment is put in place along with a bit more wire that you'll need to provide, then one more seat on a pedestal is put in the centre of the basket which is then dropped into the turret ring in the top of the hull to complete the build.
There are additional parts for British Army specific stowage included in the box, which is good to see as a personalised model often looks better than a basic kit.  Their locations and colour are shown on separate colour diagrams that can be found at the front of the painting diagrams.
Markings
There are a generous eight options provided for the modeller on the decal sheet, split between camouflaged, green and sand coloured vehicles, as the Grant and Lee served mainly in warmer climes.  Considering this is an armour kit the sheet is relatively large due to the number of options, use of roundels and various personalisations of their tank by the crews depicted in the kit.  From the box you can build one of the following:
  • Great Britain Training Unit, 1942
  • Australian 1st Armoured Division, Puckapunyal, Australia, May 1942
  • Senior Regiment Royal Gloucestershire Hussars, 7th Armoured Division, North Africa, 1942
  • Nottinghamshire Yeomanry Regimental Headquarters, El Alamein North Africa, October 1942
  • Eighth Army tank of Bernard Montgomery, North Africa 1942-Jan 1943
  • British 8th Army, North Africa, 1943
  • C Squadron, 3rd Royal Tank Regiment, 4th Armoured Brigade, 7th Armoured Division, Gazala, May 1943
  • Repair base of the Allies in Heliopolis, Egypt, March 1943
Decals are by DecoGraph, and have good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas.
Conclusion
This is a wonderfully detailed kit of the Grant as it was supplied to and used by the British Army.  The detail incorporated in styrene is phenomenal and the addition of the PE parts gives the modeller all the shackles for their pioneer tools, which are usually included in aftermarket PE sets.  A really impressive piece of plastic engineering.
Extremely highly recommended.
Review sample courtesy of
  • Like 11
  • Thanks 3
