Mohammad Bilal Minhas Posted August 7, 2019 Share Posted August 7, 2019 Hi all, What part x-22 to what part thinner should I use to airbrush this clear? Any tips or suggestions on airbrushing this clear? Thanks! Link to comment Share on other sites More sharing options...
Shin Posted August 10, 2019 Share Posted August 10, 2019 Hey Mohammad, I use 40% X-22 gloss to 60% Mr. Color Leveling Thinner with good results. I spray it on wet in an overlapping pattern, but not so heavily that it begins to run. After you finish, spray a mist coat of just Mr. Color Leveling Thinner. I've read you can also use X-20A at the same 40/60 ratio with decent results if that's all you have available. Link to comment Share on other sites More sharing options...
dnl42 Posted August 10, 2019 Share Posted August 10, 2019 I don't use a fixed ratio, I always thin paints to about the thickness of 1% milk. Spray at 1 atm. Paint in thin coats to build coverage, making sure the paint is slightly wet when it hit the surface. You can check this by using a grazing light, so you see the paint hitting the surface. Once you've built up a good coverage in thin coats, make one final heavier--but not too heavy--gloss pass. I don't know what airbrush you have, but I like to use a 0.5mm needle for clear and base coats. HTH -- dnl 1 Link to comment Share on other sites More sharing options...
