Anthony Kesterton
What is Halfords Appliance White?
Hi
Feeling a little foolish, but I have been looking for Halfords Appliance White, and can't find anything called that on the Halfords web site.  Is it the plain white enamel spray, or something else.
thanks
anthony
They sell it in aerosol. I think it's originally intended for spraying washing machines, fridges, cookers etc, the exterior, hence the appliance white title. It's not enamel, it's a form of acrylic, but not like a hobby acrylic ie. water based type product. It's more of an auto acrylic, so a tougher finish than hobby acrylic. The smell is also a lot stronger than hobby paint. However, it's not as tough as something like Zero paints. It dries quickly, but to dry properly takes longer. I find maybe a minimum 1 week drying time is best before handling and polishing. It does remain softish for quite a while and can mark with fingerprints and general handling. I also found that unless the primer coats are properly dry when you apply the Halfords paints, they can crack weeks, even months down the line. Generally I've stopped using them and use Zero, Mr Color, Tamiya TS or Tamiya LP instead...
Thanks for the warnings Steve.  I did try and search for Halfords Appliance White and variation, but nothing comes up on their web site.
I will have a look at the other paints you suggested too.
It depends what you're using it for? I tended to use it mainly for 1/24th rally cars and it worked very nicely as a gloss white that was decal ready. Also with it being in large cans it was pretty good value for money as I got quite a few cars painted from one can..
Appliance White is my tool of choice. Indispensable for Airliners or anywhere you need a high gloss finish. Do let it gas out, or it will mark with masking tape. Nothing a coat of Klear won't fix after decals. It won't yellow over time either.
For something like an Anti-Flash white, use Halfords White Primer, and finish to your liking.
A few of my local Club members used to laugh at first........they are now converts!
i use it by decanting it (spraying) direct from can into an old plastic mug. then pour intop my airbrush cup to spray as already mixed white paint. Need to be quick as it os already starting to dry. Super tough finish, 1 pass with airbrush is solid (not like normal white that takes several layers. And it stays pure, brilliant white for ever.
Use it on ALL my USN jets (gull grey over white)   42432515204_da82acef5a_b.jpgIMG_3165 by Dom GOLDEN, on Flickr
I've come here with exactly the same thoughts as Anthony when trying to find Appliance White in the past (and now for the future).
So it's just Halfords' white car paint then?
Nick
Nick
It is called Appliance Gloss White. You will find it on the car paints rack, usually on the top shelf, along with their primers, as it's a larger can than the auto paints.
Ok, thanks. I’ve looked a few times but never managed to find it - I’ll have to look harder next time! 🧐
Nick
It's great paint, I used it on a yellowing bath panel and it worked really well, and is really tough.
Dennis
It’s great stuff. Put the can in very warm water and let the heat do its thing. It sprays really nicely when warm and you won’t get orange peel. Also over time it doesn’t yellow.
Steve.
On 10/18/2019 at 7:51 PM, Jamie @ Sovereign Hobbies said:
Unless you don't have an airbrush I can't see why anyone would choose this to be honest. There are superior whites that airbrush beautifully from numerous manufacturers.
because spraying direct from the can comes with a whole list of hazaeds (not least of which is the sheer volume of paint coming out on a "hairline trigger") I ALWAYS spray  into a large plastic beaker (holding a paper towel over the back, as it were, to stop overspray). I then decant this liquid white paint into my airbrush cup & away I go. You need to be quick as the stuff very quickly begins to dry - and if you spray from too far away, the stuff will actually "dry" in air (as the spray) before it reaches the model surface.
But once on the kit, it's super tough, almost scratch proof and remains (15+ years so far here) remains a brilliant white.  There is no translucency (big word for me!), so on an RN Buccaneer, I sprayed the white on AFTER the Extra Dark Sea Grey and it goes on, super white, at the 1st pass of the airbrush.
ALL my cans from Halfords are silver in colour with a white cap if that helps you find it. Answering the question from Nick Belbin, as an alternative, I would guess that ANY automobile White spray can would work, but just check as to how "white" the colour is.
