Juan Carlos Duque Arango Posted July 28, 2019 Share Posted July 28, 2019 Greetings this my first post in this forum Juan C. 27 Link to comment Share on other sites More sharing options...
Parabat Posted July 28, 2019 Share Posted July 28, 2019 Very nicely done, the only thing that stands out a bit 'off' is the aerial, but what a realistic finish this is. You can just see it in the disregarded corner of a factory lot or farm somewhere. 1 1 Link to comment Share on other sites More sharing options...
dnl42 Posted July 28, 2019 Share Posted July 28, 2019 Well done! I quite like the many variations of damage and wear you've been able to demonstrate. One of those, in a little better shape, got me through college. It was truly the perfect student vehicle: economical on gas, readily available parts at the junkyard, easy to repair. The one downside was so little heat that I was scraping frost on the inside glass during a particularly bad blizzard. 2 1 Link to comment Share on other sites More sharing options...
ColinH25 Posted July 28, 2019 Share Posted July 28, 2019 I love this! Looks great. What was your technique/do you have a wip thread? I plan to do something the same. I have a 1:32 Revell vw beetle kit primed up and ready to go once I've practiced the effect a bit. 1 Link to comment Share on other sites More sharing options...
R_G Posted July 28, 2019 Share Posted July 28, 2019 Very nicely done! Great job! Reminds me of my Dad's 1967 Beetle. It was also blue. 😎 Ralph 1 Link to comment Share on other sites More sharing options...
Svedberg Posted July 29, 2019 Share Posted July 29, 2019 Very good, I like it a lot! 1 Link to comment Share on other sites More sharing options...
Paul J Posted July 29, 2019 Share Posted July 29, 2019 Smart! Exactly the same colour as the one I had ( less all that rust of course) What did you use for the main body colour? My one was prone to have cr*****y brakes! They used to sieze, particularly the front ones No matter what I tried they never worked right, new cylinders brake lines, bleeding them the lot ... Also the fuel float used to stick and gave me false readings as I often ran out of petrol. The heating duct on one side was missing so it froze on the inside of the windscreen in winter..... basically it was a heap but I liked it. Ended up being carted away to the local breakers yard..... 2 1 Link to comment Share on other sites More sharing options...
Juan Carlos Duque Arango Posted July 29, 2019 Author Share Posted July 29, 2019 34 minutes ago, Paul J said: Smart! Exactly the same colour as the one I had ( less all that rust of course) What did you use for the main body colour? My one was prone to have cr*****y brakes! They used to sieze, particularly the front ones No matter what I tried they never worked right, new cylinders brake lines, bleeding them the lot ... Also the fuel float used to stick and gave me false readings as I often ran out of petrol. The heating duct on one side was missing so it froze on the inside of the windscreen in winter..... basically it was a heap but I liked it. Ended up being carted away to the local breakers yard..... Thanks Paul Vallejo RLM 65. Link to comment Share on other sites More sharing options...
s.e.charles Posted August 7, 2019 Share Posted August 7, 2019 great job on the body. chrome could be toned down a bit, though. 1 Link to comment Share on other sites More sharing options...
