Ripaman Posted September 17, 2020 Author Share Posted September 17, 2020 Next part of the build was to redo some of the items I had made a long time ago, and it all started by looking at some pictures and then looking at the hoisting engine cover box, jumbo jib boom crutch etc so first pic is the drawing supplied, next two picture show what I made will use some of the pieces the rest will be binned. What caught my eye was the black mounting frame under the white engine hoist box, it looked to me (I could be wrong) that this was sloping so that the engine was seating parallel to the stations. (Pictures are to help with my build if not allowed please delete) So remade the box but this time made it with round corners as per pic's, cut some 1/16" wide planks out of boxwood and made the base to the curvature of the deck, also made it have the pull out to get at engine. Found out what engine went on the Bluenose so found a picture which looked like the drawing and thought why not add (Pictures are to help with my build if not allowed please delete) Here is my take on the engine still have to add parts but did make the sprockets on the flywheels wrong made them with eight spooks instead of six Made the body as per pic and drawing Then added the water tank and exhaust pipe And it fit nice inside the box, will make the top cover with working hinges. Carrying on with the redo parts all gears for the winch gear came in the kit were made of white metal and not very good looking so made my own, this is what came with the kit Started by making the bearings four in total, then made two 12 tooth gears one to go under winch gear and the other to go on counter shaft stand Next was to make the big winch gear, turned on lathe and then cut teeth on milling machine used .030" and .020" ball mills to get what I wanted did cut the right amount of spooks . Then made the end bell shape winches Next were the sprockets for chain drive three in total one was an 8 tooth and the other two were 13 tooth, last two gears were made for the pawl, at the same time this was happening I noticed I had made the Boom crutch to high and also had the gears to low so I made a new boom crutch out of box wood so this is how it came out, all brass was blackened with casy black Did not like the supplied Pawl's so made two of them The last part for this area was the counter shaft stand again sides were made from white metal all sides were box shape but should have been angle so made as per drawing Kit supplied sides Will use a 1:12 motor bike chain for the drive, couldn't find anything else. Until next time Regards Richard 8 1 Link to comment Share on other sites More sharing options...
longshanks Posted September 17, 2020 Share Posted September 17, 2020 1 hour ago, Ripaman said: not very good looking so made my own, Of course you did. If you don't mind me saying you're a Nutter !! Equally disturbing is that I'm enjoying watching you work your magic Stay safe Kev 2 1 Link to comment Share on other sites More sharing options...
JohnWS Posted September 17, 2020 Share Posted September 17, 2020 We should have a 'WOW' icon along with the 'Like', 'Sad', etc. I'd be using it a lot on this build & others. John 1 1 Link to comment Share on other sites More sharing options...
dogsbody Posted September 17, 2020 Share Posted September 17, 2020 Seen a few of those old style engines while growing up on a farm in Nova Scotia, in the 60's. We had one, but it only had one flywheel. It was stored way in the back of a shed. Sometime in the 90's, while back home for a visit, Dad, my older brother and I hauled it out and hooked up a 5-gallon gas can to it. Dad wrapped a rope around the belt pulley on the driveshaft and gave it a pull. On the second try, it started. It chugged away for a few minutes, then we shut off the fuel and put it back in the shed. Chris 1 1 Link to comment Share on other sites More sharing options...
Ripaman Posted January 22, 2021 Author Share Posted January 22, 2021 Happy belated New year to all hope everyone is staying safe been slacking with posting progress on the Bluenose, bit late but thanks Kev (yes a nutter I am ), John and Chris for your posts, have done quite a bit more will post an update in the next couple of days. Regards Richard 4 Link to comment Share on other sites More sharing options...
longshanks Posted January 22, 2021 Share Posted January 22, 2021 Happy New Year to you Richard I'm looking forward to seeing what you've been up to.... Kev 1 Link to comment Share on other sites More sharing options...
JohnWS Posted January 24, 2021 Share Posted January 24, 2021 On 22/01/2021 at 03:37, longshanks said: Happy New Year to you Richard I'm looking forward to seeing what you've been up to.... Kev John 1 Link to comment Share on other sites More sharing options...
Cuppa_joe Posted January 24, 2021 Share Posted January 24, 2021 I just found this via the activity section, this is fantastic! 1 Link to comment Share on other sites More sharing options...
