Ripaman
1921 Canadian Fishing Schooner Bluenose 1/64 scale
Now that I have retired, move to Vancouver Island, built a new hobby room, I have decided to start finishing some of my models which seem to get put aside :think: and this plank on bulkhead hull famous Canadian Schooner will be the first to get finished due to now being so close to the sea.
I started this model back in 2006 (did say in my Churchill WIP that I started in 2010 but then I looked in the first picture properties and it says 2006 and was working on it until 2009 and then stopped) so it has been waiting a long time for me to get back to it.
To start I glued the three piece center keel together and then added the sternpost which needed to be tapered as per plans,  after that was complete I laid out the rabbet, then marked out and cut the bevel on each bulkhead and set up in a jig to hold all straight and square.
At this time I decided to machine/drilled two blocks of wood (purple hard wood) to fit into space where the mainmast/foremast were going to go so that mast would be perpendicular from side to side
Once that was done took everything apart and cut the rabbet into each side of center keel and formed all bulwark stanchions, then glued each bulkheads to center keel, to keep everything nice a straight I added permanent strut between bulkheads.
Next up was to shape the stern blocks out of solid wood and glue into place, add transom framing and horn timbers.
Once all the items above where nice and glued I had to feather each bulkhead to the bearding line every bulkhead had to have a smooth flow into the rabbet
Hope you all will enjoy
Regards
Richard
I’m in! 👍
Please keep posting plenty of pictures so I can learn how to best build something similar (not Bluenose) that I’ve been contemplating for some time.
Great subject by the way. This will look fabulous when complete!
I was lucky and had a ride on it in PictouN.S. a couple years ago. I have a wood model of the Bluenose two. Have yet to build it but will watch this one to learn it.
Edited by busnproplinerfan
That's for sure
Looking forward to seeing this develop . . .
Kev
Now this looks like it is going to be very interesting and informative :popcorn:
beefy
What kit are you using? I have built the Artisania Latina kit and I have the Billing Boats kit in progress.
Please ignore - I just noticed the Model Shipways at the head of this thread.
Edited by GrantGoodale
The current one is referred as the 2 1/2 or 3 because it just had another rebuild done just before I rode it. I was told as long you keep the keel and something else, you can keep the name.
14 hours ago, Bandsaw Steve said:
I’m in! 👍
Welcome aboard Steve do have a few pictures of the build so will show you all I have and hope it helps, it is a great subject
Luck you would love to take a ride one day, what make of Bluenose do you have.
11 hours ago, longshanks said:
That's for sure
Kev
I'm looking forward to see this develop as well I have the time and space so no more excuses :fingerscrossed:
It was seeing your unbelievable small boats you make and looking at the sea each day  that made me decide to finish this build thanks for that.
beefy
I do hope it will be interesting Beefy boats were what I was into before starting the odessa of the Hurricane
Hi Grant do you have any pictures of your Bluenose would love to see them
You are correct in the instruction manual and plans Model Shipways used were by Ben Lankford and assisted by Erik A.R. Ronnberg Jr, he had his own personal research papers and photographs which revealed differences in  virtually every detail from how the woodwork was finished to rigging leads,  so this Bluenose will be different as well.
Thanks everyone for likes
Regards
Richard
Next up was to lay the fore deck waterway planks this consist of three planks the innermost one had to have a bevel on its inboard edge to meet deck planks, to represent sealant I used a 2B pencil on edges also at this stage I added the Great Beam and Deck beam
Then added the waterway planks on aft deck, there was only one and the next one innermost is the nibbing strakes
Once this was completed I added the knighthead & hawse timbers
Next part was to add all the fake bulwark stanchions this was very time consuming because each stanchion had different angles
Until next time
Regards
Richard
Mine is the Artensenia Latina 1/75. I rear around it's not bad, not great either. It also represents the original version. I also would like to update it to current status. For anyone who doesn't know, it does have a diesel in it now. Every sailing ship like this requires one I'm told. It's well hidden and quite quiet. I was sitting just above the exhaust and it wasn't bad.
Same with this model not sure how accurate it is but do like the shape.
13 hours ago, Courageous said:
Fantastic work to watch.
Stuart
Thanks Stuart hope it will help anyone who wants to build a plank on frame wooded ship, it is a lot of fun.
After all the stanchion were good and had dried next pieces to add were the top rails, these were glued and pinned
Then the Buffalo Rail, Monkey Board & Monkey Rail were added
Then I made this jig so that I could install planking, could have the model upright or turn it upside down
Next pictures show it in the jig and as you see did add some wood to bulkheads were deck structures will go
Do like the shape of this boat
Next up planking the hull
Regards
Richard
Goes together pretty quick by the looks of it. I'm not super picky on the shape as long as when it's done it's recognized as the Bluenose. i don't have much space for ships so I just have three unbuilts.
With buffalo rails and monkey boards are you sure you're not building an ark 😉
Enjoyable inspirational work
Kev
Where do they get these names from.
Stuart
On my first post did say I started this model in 2006 then stopped in 2009, from the the first picture to the last one took 10 months, not sure why I stopped do like building wooden ships.
Kev
:rofl:The Brits did love there words for things
Stuart
Not to sure Stuart I should try and find out, just wondering if anyone can shine a light on this :hmmm:
Regards
Richard
Planking the hull was a lot of fun, very time consuming took me 12 months not working on it each day but I.m a bit slow anyway
I put a batten down both sides as equal as you can get so that I could measure from last planked laid to batten then each plank was tapered to fit, planks were 1/8 wide and I cut them to around 7" long which in scale feet is 37' which I know is to long but you have to at least cover four bulkheads.
Once tapered I could bend them a little bit add glue and set them in place with no need for clamps
You can see from this pic the dimensions I tapered these planks
So you just keep laying and laying up to batten once you get there you move the batten up so that you can start adding more planks
Then finally you get to end :yahoo: think it came out not to bad
sanded the hull down and then started the deck planking made all parts trial fitted before gluing then also made some coamings for deck structures
Last pic with deck covered
Until next time
Regards
Richard
Let's go boating, it's done enough.😋
:wow:Speedy Gonzales does not have a look in
fantastic whichcraft I mean woodcraft  you’re making it look to easy
beefy
I feel unworthy to even comment here but that is spectacular and incredibly neat work!
:clap2:
Fantastic stuff.
Sometimes I wish that I didn't have so many plastic kits...
Stuart
:shrug: With no masts, sails or engine
beefy
No speedy Gonzales here mate from first picture to last picture took 2 yrs, 11 months :weep: but thanks it was alot of fun just very time consuming
On 7/25/2019 at 4:54 AM, longshanks said:
Beautiful !
Kev
Same as what I think Kev just beautiful smooth lines, here are couple of pictures with the bottom of hull  painted
:clap2:
Don't ever think that Murdo comment all you like just took patience and time that is all mate
10 hours ago, Courageous said:
Fantastic stuff.
Stuart
Thanks Stuart have both wood and plastic, its alot of fun.
Regards
Richard
Thought I would start at the bow and make the Bowsprit and I started with machining a piece of cherry to 15/64" and from there it was all filing because the bottom was straight and the top curved
Then made up the Windlass & Counter shaft, Winch Gears & Friction Clutch from kits supplied white metal and wood
Didn't take to many pic's of this progress but here it is painted
Made some Quarter bitts
Then last thing back in 2009 I machined the two masts out of cherry and not sure why but did not take any pic's
So every think going forward is time spent here on the Island and I do hope I will finally finish her.
Until next time
Regards
Richard
