neil5208 Posted August 21, 2019 Author Share Posted August 21, 2019 Stuck the bomb bay doors on today, not a good fit. Looks like this will be another filler session with alot of sanding to look forward to. 2 Link to comment Share on other sites More sharing options...
neil5208 Posted August 25, 2019 Author Share Posted August 25, 2019 Not really an update but I received this for another year of ageing, and plan to use the under wing pylons on the TSR2 1 Link to comment Share on other sites More sharing options...
neil5208 Posted August 25, 2019 Author Share Posted August 25, 2019 Size comparison between the TSR2 and the Vigilante. Nice to see the TSR2 is still larger than its colonial rival. Third layer of filler has been applied to the bomb bay doors. 2 Link to comment Share on other sites More sharing options...
Gondor44 Posted August 29, 2019 Share Posted August 29, 2019 On 8/21/2019 at 8:45 PM, neil5208 said: Stuck the bomb bay doors on today, not a good fit. Looks like this will be another filler session with alot of sanding to look forward to. You will find that the nose wheel bay doors have a simmilar problem. On the only completed TSR2 that I have built so far used under wing pylons from an Airfix Jaguar as I wanted to use to bomb beams. Gondor 2 Link to comment Share on other sites More sharing options...
neil5208 Posted September 11, 2019 Author Share Posted September 11, 2019 (edited) Not much to report really, been to Germany to see the wife's family, new kitchen fitted and almost lost one of our dogs but the grumpy old sod is still here thankfully so modelling has been on hold and I have to go back to work on Monday to boot. Mocked up the Vigilante's pylons on the TSR2 today, their on backwards and upside down but they look better this way. I may have to move them outwards slightly once I get hold off the MER's and Mk82's for undercarriage clearance. Still have more sanding to do on the belly as well. Edited September 11, 2019 by neil5208 4 Link to comment Share on other sites More sharing options...
neil5208 Posted October 18, 2019 Author Share Posted October 18, 2019 Pulled the TSR2 out of its draw tonight and tried fitting the wings but the front has a big step so yet sanding is needed! 3 Link to comment Share on other sites More sharing options...
neil5208 Posted February 2, 2020 Author Share Posted February 2, 2020 I'm trying to get all my on going long term kits finished so I can concentrate on the B58 so a bit more work on the TSR2, Some more fitting of the wings has got the rear wing to fuselage join pretty good but the front is still off by 1/2mm 3 Link to comment Share on other sites More sharing options...
Markh-75 Posted February 2, 2020 Share Posted February 2, 2020 On 01/08/2019 at 15:08, mdauben said: I was just watching a documentary about the TSR2 the other day. Fascinating aircraft, and the behind the scenes shenanigans regarding the development program were just as interesting! Read a few good books about the whole debacle, i have a keen interest in this aircraft; only one ever flew and it was destroyed on the weapons ranges at Shoeburyness before being finally scrapped there. The next two aircraft were XR220 which was close to flying its maiden flight when it was all cancelled, and XR221. Unsure if any others exist other than at Cosford and Duxford but i doubt it because they were all pulled off the assembly line and set on fire. TSR2 was about 10 years ahead of its time technologically but was heavily over-budget however the cost of keeping it going would have been less. It goes into the £ billions. They wanted to keep two operational to do testing for Concorde but the new government said no, and wanted EVERYTHING destroyed so that nobody could ever restart producing them. Great shame. 2 Link to comment Share on other sites More sharing options...
neil5208 Posted February 3, 2020 Author Share Posted February 3, 2020 A bit more work on the wing joint has resulted in this I think this should do it for now, I apply some thin set and start sanding again... 2 Link to comment Share on other sites More sharing options...
Markh-75 Posted February 3, 2020 Share Posted February 3, 2020 On 11/09/2019 at 19:33, neil5208 said: Not much to report really, been to Germany to see the wife's family, new kitchen fitted and almost lost one of our dogs but the grumpy old sod is still here thankfully so modelling has been on hold and I have to go back to work on Monday to boot. Mocked up the Vigilante's pylons on the TSR2 today, their on backwards and upside down but they look better this way. I may have to move them outwards slightly once I get hold off the MER's and Mk82's for undercarriage clearance. Still have more sanding to do on the belly as well. I always check the fitting of doors and if necessary i will shave them down a little where they are ill fitting, then i dont use so much filler! On 11/09/2019 at 19:33, neil5208 said: Link to comment Share on other sites More sharing options...
Doccur Posted February 26, 2020 Share Posted February 26, 2020 I have one of these I plan to build in the future. Nice to see how your one is coming along Neil. Keep up the good work. Ash 1 Link to comment Share on other sites More sharing options...
neil5208 Posted March 22, 2020 Author Share Posted March 22, 2020 Wings vertical tail are on! and I found the kit seats that I thought I lost so I don't have to dremal out half the cockpit floor to fit the resin ones I bought. I realised that the paint scheme I'll be going for is similar to the B58 less the underside colour, white on this one opposed to black on the Hustler so I can paint the SEA camo together. 3 Link to comment Share on other sites More sharing options...
Markh-75 Posted March 22, 2020 Share Posted March 22, 2020 Getting there now! Good work. 1 Link to comment Share on other sites More sharing options...
Markh-75 Posted March 22, 2020 Share Posted March 22, 2020 Is this the Contrail Vac-form kit? I did one years ago, had it looking excellent and then the lacquer i used over the decals spoiled it by turning yellow. Shame because i'd put weeks and weeks into that! Nothing went straightforward, it answered me back at every part of the build. Maybe one day i'll get the Corgi Die-cast of it because its one of my most favourite jets. Link to comment Share on other sites More sharing options...
bar side Posted March 22, 2020 Share Posted March 22, 2020 My Contrail 1/48 with an FB-111 in SEA Camo - yes, it should be an F-111F so the wings are too long, but gives you a good idea of a similar sized jet in your target camo, even if the underside is black 1 Link to comment Share on other sites More sharing options...
Markh-75 Posted March 22, 2020 Share Posted March 22, 2020 Only thing missing there to complete the trilogy is the Blackburn Buccaneer! The TSR 2 brings back memories! Excellent work on both. Thanks. Link to comment Share on other sites More sharing options...
bar side Posted March 22, 2020 Share Posted March 22, 2020 4 minutes ago, Markh-75 said: Only thing missing there to complete the trilogy is the Blackburn Buccaneer! The TSR 2 brings back memories! Excellent work on both. Thanks. 1/48 Buccaneer is a pricey & rare thing. Been after one for a long while. Working on an even bigger beast now - 1/48 Herc! 1 Link to comment Share on other sites More sharing options...
Markh-75 Posted March 22, 2020 Share Posted March 22, 2020 Do you have a hangar to keep them in? lol I model in 1:72 as its a scale i can build many in and keep them in a cabinet, i always made my kits in gentlemanly 1:72 as a boy and later in life, i build in that scale still. The Herc sounds great!😀😎 Link to comment Share on other sites More sharing options...
bar side Posted March 22, 2020 Share Posted March 22, 2020 2 minutes ago, Markh-75 said: Do you have a hangar to keep them in? lol I model in 1:72 as its a scale i can build many in and keep them in a cabinet, i always made my kits in gentlemanly 1:72 as a boy and later in life, i build in that scale still. The Herc sounds great!😀😎 Funny you should say that.... 4 Link to comment Share on other sites More sharing options...
Markh-75 Posted March 22, 2020 Share Posted March 22, 2020 🤣😆 Link to comment Share on other sites More sharing options...
billn53 Posted March 22, 2020 Share Posted March 22, 2020 4 hours ago, neil5208 said: I found the kit seats that I thought I lost so I don't have to dremal out half the cockpit floor to fit the resin ones I bought. Those resin seats do look good, though. Who made them? Link to comment Share on other sites More sharing options...
neil5208 Posted March 23, 2020 Author Share Posted March 23, 2020 6 hours ago, billn53 said: Those resin seats do look good, though. Who made them? They are the Pavla ones. 1 Link to comment Share on other sites More sharing options...
billn53 Posted March 23, 2020 Share Posted March 23, 2020 18 hours ago, neil5208 said: ... the paint scheme I'll be going for is similar to the B58 less the underside colour, white on this one opposed to black on the Hustler so I can paint the SEA camo together. Shouldn’t that be light gray (FS36622), not white? Link to comment Share on other sites More sharing options...
Marklo Posted March 23, 2020 Share Posted March 23, 2020 20 hours ago, bar side said: 20 hours ago, Markh-75 said: 1/48 Buccaneer is a pricey & rare thing. Been after one for a long while. I see there is an Airfix one on eBay at the moment. Airfix 1/48 H.S. Buccaneer Model Kit #09180 New Boxed Kit Can’t paste the link but if you search the above you should find it. It’s at 10.50 gbp so far. Link to comment Share on other sites More sharing options...
bar side Posted March 23, 2020 Share Posted March 23, 2020 1 hour ago, Marklo said: I see there is an Airfix one on eBay at the moment. Airfix 1/48 H.S. Buccaneer Model Kit #09180 New Boxed Kit Can’t paste the link but if you search the above you should find it. It’s at 10.50 gbp so far. I’ll put that one on watch - cheers! They do come up but often go north of £60 Link to comment Share on other sites More sharing options...
