1/72 Revell MDD F-4E Kurnass
VG 33
Hello
It's really a long time I haven't entered in a group build here.
This time I have chosen an early F-4E in Israeli Defense Force in 1973.
To build this aircraft I have selected in my stash the Revell F-4F which has nearly everything to make a Kurnass (Sledgehammer).
Actually, I had to take from a Fujimi kit the sloted stabilators as the F-4F did not have those.
Here is the box art and first pictures of the build will follow soon.
Cheers.
Patrick
Edited by VG 33
Here is where I am now with some work around the cockpit :
I added some strips on the ejection seats :
In the kit there are the first stage of the compressor :
To be followed...
Patrick
  • Like 9
Hello
No more pictures today but a question.
I am planning to hang under the centerline of my Kurnass a MER with 5 M-117 bombs. I have the MER from the Hasegawa generic box 72-1 but I wonder how is it hung. Inside much of the Phantom kits there is only a big fuel tank with its dedicated pylon.
Or is it directly attached under the aircraft belly?
Cheers.
Patrick
The MER would definitely be hung off a pylon.  However what I do not know is if the center pylon differed if it was carrying a drop or weapons.  I would think in most cases the pylon would be the same...but I have heard of certain aircraft having to change pylons pending load out.
I asked and got an answer here :
https://www.britmodeller.com/forums/index.php?/topic/235058466-f-4e-phantom-centerline-pylon/
And the pylon is called Centerline MER adaptor, so dedicated.
Patrick
Edited by VG 33
Hello
It is now time to speak about the aircraft I have chosen to build.
I have selected Kurnass N°618 of "The One" squadron at the beginning of the Yom Kippur War.
This one was shot down above Syria by anti-aircraft artillery when operating a bombing run.
Both pilot and backseater ejected safely but were taken POW.
For the decals I ordered Isra decal sheet IAF-98.
For the armament I have chosen a heavy bomber load with 10 or 11 M-117 slick bombs. I know some Kurnass had AIM-7 and/or AIM-9 for self-defense, I have to get more information about their position. I will add an AN/ALQ-87 ECM pod as well in the port front Sparrow position.
To be continued...
Patrick
5 hours ago, VG 33 said:
Hello
To be continued...
Patrick
Judging by the lack of openings for the invoard slat actuators I'm 99% sure you're already aware of this, but since I didn't see it specifically mentioned I felt obliged to note that the subject you've chosen to model is a "hard wing" (i.e. unslatted) F-4E.
Fortunately the Revell F-4F kit includes the unslatted ouboard wings from the earlier RF-4E tooling. Just use the parts from the main wing sprue rather than the ones on the forward fuselage tree, leave off the inboard slat actuators, and *voila* - hard wing Phantom 👻
Following this build with interest!
  • Thanks 2
Yes, she is unslatted and I checked on pictures. Moreover in October 1973 she had a long gun muzzle. I had information on a dedicated Kurnass Facebook page.
Patrick
Hello
Some progress.
I have changed my background but the Revell plastic is still very light. I sanded around the engine air intakes as usual with this type of aircraft.
Next come the inboard wing pylons where I had to take off the flare dispenser which were not present at the time.
To be continued...
Patrick
Edited by VG 33
  • 4 weeks later...
Hello
Some little progress since last month.
I have received the Eduard M117 late type bombs and I am preparing 10 of them.
I have airbrushed Tamiya gloss black for the dielectric radome and a couple of wing leading edge parts. I will use a black-grey colour later for the tip of the radome.
I test-fitted the ejection seats and added some bits above the pilot instrument panel as in this kit this is too much simplified.
Lastly, I covered the transparent parts and airbrushed inside the flat front canopy with Alclad transparent green.
To be continued...
Patrick
  • 3 weeks later...
Hello
Last weekend I spent more than 4 hours painting this camouflage. The paint was thinned by 50% and airbrushed with low pressure. Later I airbrushed some thin layers of gloss coat.
Here is a picture of both ejection seats too.
Next step will be the transfers.
Patrick
  • Like 9
Hello
Her she is. Actually I built her just coming back from another mission during Yom Kippur War. This aircraft #618 was shot down on October 13th, 1973 over the Golan Heights.
So this one is ready for the YKW anniversary on October 6th.
Patrick
Edited by VG 33
  • Like 9
