Night Owl Posted July 15, 2019 Share Posted July 15, 2019 Hi all, I have applied Tamiya's extra thin cement to the light machine gun mount on a Meng M3A3 Bradley securing it to the main gun. After it had set I discovered that the whole gun mount that is supposed to move up and down was locked in a permanent elevated position. I think some glue has seeped out and dried in an unwanted location. If I can locate the culprit what can I use to break the bond? I saw a suggestion on Google for nail polish remover that sounds a bit strong if anyone has a suggestion I would appreciate the help. Thanks Dave Link to comment Share on other sites More sharing options...
modelmaker Posted July 16, 2019 Share Posted July 16, 2019 (edited) I imagine the extra thin will actually have melted the 2 parts together making them effectively one piece. The pin will presumably be the weakest part and will probably break first so maybe you could make a new pin, clean up the other part etc, normal cock up stuff in my world sadly. Do one job make 2 more....... Edited July 16, 2019 by modelmaker spelling Link to comment Share on other sites More sharing options...
bhouse Posted July 16, 2019 Share Posted July 16, 2019 Before you apply any chemicals, I suggest you put the joined parts in a freezer. After 24 hours, take them out and gently manipulate the parts around the plane of the join. At least 6 times out of 10, I have found that the parts separate fairly cleanly. Link to comment Share on other sites More sharing options...
