DEAD
DEAD Design Models - NEW Releases
DEAD Design Models - NEW Releases April-July 2019
www.deaddesignmodels.com
1/48 scale Vacu Canopy & Mask:
CM48004 Yokosuka D4Y2-S/3 Suisei Night Fighter Vacu Canopy & Mask for 1/48 Fine Molds
Vacuum formed opened canopy including spray mask for 1/48 scale Fine Molds D4Y2-S/3 Suisei / Judy Night Fighters.
The canopy is split into sections - wind shield, pilot's sliding hood, centre section, observer's sliding hood with cut out for 20 mm cannon barrel and 2 types of rear part for easier removing from the riser.
The 2 types of the rear canopy part are included since some of the early produced D4Y2-S sported fully glazed rear canopy part.
Includes complete spray mask for this canopy, ventral window, pilots bulkhead, main wheel discs and tail wheel disc.
CM48007 Yokosuka D4Y1/4 Suisei/ Judy Vacu Canopy & Mask for 1/48 Fine Molds
Vacuum formed opened canopy including spray mask for 1/48 scale Fine Molds D4Y1/4 Suisei / Judy kits.
The canopy is split into sections - wind shield, pilot's sliding hood, centre section, observer's sliding hood and 2 types of rear part for easier removing from the riser.
The 2 types of the rear canopy part are included since D4Y1 sported fully glazed rear canopy part while D4Y4 rear part was faired over.
CM48008 Yokosuka D4Y2/3 Suisei/ Judy Vacu Canopy & Mask for 1/48 Fine Molds
Vacuum formed opened canopy including spray mask for 1/48 scale Fine Molds D4Y2/3 Suisei / Judy kits.
The canopy is split into sections - wind shield, pilot's sliding hood, centre section, observer's sliding hood and rear part for easier removing from the riser.
1/48 scale Canopy Mask:
VM48012 Mitsubishi J2M3 Raiden Canopy Mask
Mask designed for the 1/48 scale Tamiya Mitsubishi J2M3 Raiden kit include all the necessary parts to mask off all canopy glazing, bullet proof glass and main wheel discs.
VM48021 Mitsubishi Ki-51 Sonia Canopy Mask
Mask designed for the 1/48 scale Nichimo Mitsubishi Ki-51 Sonia kit include all the necessary parts to mask off all canopy glazing, ventral windows, and main wheel discs.
VM48023 Aichi E13A Jake Canopy Mask
Mask designed for the 1/48 scale Nichimo Aichi E13A kit include all the necessary parts to mask off all canopy glazing and ventral window.
VM48025 Nakajima B5N2 Kate Canopy Mask
Mask designed for the 1/48 scale Nichimo Nakajima B5N2 Kate kit include all the necessary parts to mask off all canopy glazing, side and ventral windows and main wheel discs.
VM48031 Kawasaki Ki-45 KAI Toryu Canopy Mask
Mask designed for the 1/48 scale Nichimo Kawasaki Ki-45 KAI Toryu kit include all the necessary parts to mask off all canopy glazing, landing light and all wheel discs.
VM48043 MXY7 / K 1 Ohka Canopy Mask
Mask designed for the 1/48 scale Kugisho MXY7 / K 1 Ohka (FB15 & FB16) produced by Fine Molds include all the necessary parts to mask off canopy glazing.
VM48044 Nakajima B5N1/2 Kate Canopy Mask
Mask designed for the 1/48 scale Hasegawa Nakajima B5N1/2 Kate kits include all the necessary parts to mask off both opened and closed canopy parts, side and ventral windows, cockpit bulkhead, main wheel discs and tail wheel disc.
VM48045 Nakajima B6N1/2 Tenzan Canopy Mask
Mask designed for the 1/48 scale Hasegawa Nakajima B6N1/2 Tenzan kits include all the necessary parts to mask off all canopy glazing, side and ventral windows, cockpit bulkhead, main wheel discs and tail wheel disc.
VM48048 Mitsubishi Ki-51 Sonia Canopy Mask
Mask designed for the 1/48 scale Wingsy Kits Mitsubishi Ki-51 Sonia kit include all the necessary parts to mask off both types of canopy glazing, side and ventral windows, landing and position lights and main wheel discs.
VM48051 Nakajima Ki-43 I Hayabusa Canopy Mask
Mask designed for the 1/48 scale Nichimo Nakajima Ki-43 I Hayabusa kit include all the necessary parts to mask off all canopy glazing, landing light and and main wheel discs.
1/48 scale Resin:
RM48004 Kawasaki Ki-61 I & Ki-100 Control Surfaces
Flying control surfaces for all 1/48 scale Hasegawa Ki-61 I Hien & Ki-100 kits.
The set contains ailerons, rudder and elevators with tailplanes. Moreover the set contains actuating arms for rudder and elevators. The actuating wires are not included. All flying surfaces feature beautifully recreated fabric covering with decent ports and all hinges and brackets.
1/48 scale Optical Illusion Mask:
SM48001 Ki-15 I/II, Karrigane, C5M2 Babs Control Surfaces
Special control surfaces Optical Illusion Mask for 1/48 scale Fine Molds Babs Family kits.
Set contains mask for both sides of ailerons, elevators and rudder.
SM48002 Kawasaki Ki-61 Id Hien Control Surfaces
Special control surfaces Optical Illusion Mask for 1/48 scale Tamiya Ki-61 Id Hien kit.
1/72 scale Canopy Mask:
VM72006 Ki-61 I Hien Canopy Mask
Mask designed for the 1/72 scale Fine Molds Ki-61 I Otsu/Hei kits includes all the necessary parts to mask off the canopy glazing, wing light and main wheel discs.
VM72009 Ki-61 I Hien Canopy Mask
Mask designed for the 1/72 scale Dragon Ki-61 I Hien kits includes all the necessary parts to mask off the canopy glazing, wing light and main wheel discs.
VM72038 A6M2/3 Reisen/ Zero Canopy Mask
Mask designed for all 1/72 scale Fine Molds A6M2/3 Reisen versions 21, 22 & 32 includes all the necessary parts to mask off both opened and closed canopy glazing and main wheel discs.
VM72039 A6M5 Reisen/ Zero Canopy Mask
Mask designed for 1/72 scale Fine Molds A6M5 Reisen model 52 includes all the necessary parts to mask off both opened and closed canopy glazing and main wheel discs.
VM72042 J2M5 Raiden Canopy Mask
Mask designed for the 1/72 scale Sword J2M5 Raiden kit includes all the necessary parts to mask off canopy glazing and all wheel discs.
VM72047 Ki-46 II Dinah Canopy Mask
Mask designed for the 1/72 scale Hasegawa Mitsubishi Ki-46 II Dinah kits includes all the necessary parts to mask off canopy glazing, side and ventral windows, nose mounted reflector and main wheel discs.
VM72049 Ki-46 III Dinah Canopy Mask
Mask designed for the 1/72 scale Hasegawa Mitsubishi Ki-46 III Dinah kits includes all the necessary parts to mask off canopy glazing, side and ventral windows, nose mounted reflector and main wheel discs.
VM72050 Ki-51 Sonia Canopy Mask
Mask designed for 1/72 scale Hasegawa Ki-51 Sonia kit includes all the necessary parts to mask off canopy glazing, side and ventral windows and main wheel discs.
VM72051 B6N1/2 Tenzan Canopy Mask
Mask designed for all 1/72 scale Fujimi Nakajima B6N1/2 Tenzan kist includes all the necessary parts to mask off canopy glazing, side and ventral windows and main wheel discs.
VM72053 Ki-84 Hayate Canopy Mask
Mask designed for all 1/72 scale Sword Nakajima Ki-84 Hayate kits includes all the necessary parts to mask off both canopy glazing and main wheel disks.
VM72054 C6N1/1-S Saiun Canopy Mask
Mask designed for all 1/72 scale Sword Nakajima C6N Saiun kits includes all the necessary parts to mask off all types of canopy glazing, ventral windows and main wheel discs.
VM72055 C6N1/2 Saiun Canopy Mask
Mask designed for all 1/72 scale Fujimi Nakajima C6N Saiun kits includes all the necessary parts to mask off both types of canopy glazing, ventral windows and main wheel discs.
VM72056 C5M2 Babs Canopy Mask
Mask designed for 1/72 scale LS/ Arii Mitsubishi C5M2 Babs kit includes all the necessary parts to mask off canopy glazing, side and ventral windows, wing light glazing and main wheel discs.
VM72063 A7M1/2 Reppu Canopy Mask
Mask designed for all 1/72 scale Fine Molds Mitsubishi A7M1/2 Reppu kits includes all the necessary parts to mask off canopy glazing, bullet proof glass and main wheel discs.
VM72064 Ki-106 Canopy Mask
Mask designed for 1/72 scale Sword Tachikawa Ki-106 kit includes all the necessary parts to mask off canopy glazing and main wheel discs. For sure this is a completely different canopy to Ki-84 kits.
VM72065 Nakajima Ki-87 Canopy Mask
Mask designed for 1/72 scale Sword Nakajima Ki-87 kit includes all the necessary parts to mask off canopy glazing and all wheel discs.
VM72066 Tachikawa Ki-94 II Canopy Mask
Mask designed for 1/72 scale Sword Tachikawa Ki-94 II kit includes all the necessary parts to mask off canopy glazing and main wheel discs.
VM72067 A5M2b Early Claude Canopy Mask
Mask designed for 1/72 scale Clear Prop! Mitsubishi A5M2b Early Claude kit includes all the necessary parts to mask off canopy glazing and main wheel discs.
VM72068 A5M2b Early National Insignias Mask
Mask designed for 1/72 scale Clear Prop! Mitsubishi A5M2b Early Claude kit includes replaces kits decals National Insignias with mask.
VM72069 Ki-46 III KAI Dinah Interceptor Canopy Mask
Mask designed for the 1/72 scale Hasegawa Mitsubishi Ki-46 III KAI Dinah Interceptor kits includes all the necessary parts to mask off canopy glazing, side and ventral windows, nose mounted reflector, wing landing light and main wheel discs.
VM72070 Ki-46 II Dinah Trainer Canopy Mask
Mask designed for the 1/72 scale Hasegawa Mitsubishi Ki-46 II Dinah Trainer kit includes all the necessary parts to mask off canopy glazing, side and ventral windows, nose mounted reflector and main wheel discs.
1/72 scale Optical Illusion Mask:
SM72004 Mitsubishi A5M Claude Family Control Surfaces
Special control surfaces Optical Illusion Mask for 1/72 scale Fujimi/ AVI Models Mitsubishi A5M Claude Family kits.
Set contains masks for both sides of ailerons, elevators and rudder.
Feel free to contact me with questions
DEAD
Review and some goodies for new Fine Molds Reisens
Mitsubishi A6M1 Prototype & A6M2a Resien 1/72 Fine Molds FP34 REVIEW
VM72073 A6M1 & A6M2a Reisen/ Zero Canopy Mask
Mask designed for 1/72 scale Fine Molds A6M1 & A6M2a Reisen/ Zero includes all the necessary parts to mask off canopy glazing and main wheel discs.
The set contains masks for both kits.
VM72074 A6M1 & A6M2a Reisen/ Zero National Insignias Mask
National Insignias & Markings mask for 1/72 scale Fine Molds A6M1 Prototype & A6M2a Resien kits.
The set contains masks for both types.
SM72005 A6M1 & 2a Reisen/Zero Control Surfaces
A Special set of spray masks to distinguish the fabric covered control surfaces for the Mitsubishi A6M1 Prototype and A6M2a Reisen / Zero in 1/72 scale from Fine Molds (FP34).
The set includes masks for both sides of the ailerons, rudder and elevator.
The set contains masks for both A6M1 & A6M2a.
DEAD Design Models - NEW Releases October/ November 2019
Canopy & other goodies Masks 1/48:
VM 48055 - A6M3/5 Reisen TAM (new kit)
VM 48056 - A6M1/2a Reisen HAS
VM 48057 - A6M2b/3/5 Reisen HAS
VM 48058 - A6M2-K Reisen HAS
VM 48059 - A6M2/3/5c/2-N Reisen TAM (old kit)
VM 48060 - A6M5c/7/8 Reisen HAS
VM 48061 - A6M5 Night Fighter Reisen HAS
VM 48062 - Ki-43 I Hayabusa Nat. Ins. & Marking HAS
VM 48063 - Ki-43 II/III Hayabusa Nat. Ins. & Marking HAS
VM 48064 - Ki-43 II/III Hayabusa Nat. Ins. & Marking FM
VM 48065 - Ki-45 Toryu Nat. Ins. & Marking HAS
VM 48066 - Ki-61 Id Hien Nat. Ins. & Marking HAS
VM 48067 - D4Y Suisei Nat. Ins. w/ white outline FM
VM 48068 - D4Y Suisei Nat. Ins. w/o white outline FM
Canopy & other goodies Masks 1/72:
VM 72060 - E16A Zuiun FUJ
VM 72061 - E11A Laura FUJ
VM 72076 - Ki-15 I/II Babs LS/ARI
VM 72077 - Ki-15 Kamikaze LS/ARI
VM 72078 - A5M2b Late Claudie CP
VM 72079 - Ki-51 Sonia CP
VM 72082 - A6M5 Reisen ACA
VM 72083 - Ki-51 Sonia Nat. Ins. & Marking CP
VM 72084 - N1K1 Kyofu Nat. Ins. & Marking HAS
VM 72085 - D4Y Suisei Nat. Ins. w/ white outline FUJ/AZ
VM 72086 - D4Y Suisei Nat. Ins. w/o white outline FUJ/AZ
VM 72087 - E16A Zuiun Nat. Insignias FUJ
VM 72088 - E11A Laura Nat. Insignias FUJ
Vacu Canopies & Mask 1/72:
VM 72003 - A6M1/2a Vacu Canopy & Mask FM
VM 72004 - A6M2b/3/5 Vacu Canopy & Mask FM
Resin set 1/72:
RM72003 – A5M Claudie Family Kontrol Surfaces FUJ/AVI
Control Surfaces Masks (Optical Illusion) 1/72:
SM 72009 - Ki-51 Sonia Control Surfaces CP
SM 72010 - Ki-51 Sonia Control Surfaces HAS
SM 72011 - A6M2b m.21 Reisen Control Surfaces FM
SM 72012 - A6M3  m.32 Reisen Control Surfaces FM
SM 72013 - A6M3 m.22  Reisen Control Surfaces FM
SM 72014 - A6M5 m.52  Reisen Control Surfaces FM
SM 72015 - Ki-36/55 Ida Control Surfaces FUJ
SM 72016 - A6M2b m.21 Reisen Control Surfaces TAM
SM 72017 - A6M3  m.32 Reisen Control Surfaces TAM
SM 72018 - A6M3 m.22  Reisen Control Surfaces TAM
SM 72019 - A6M5 m.52  Reisen Control Surfaces TAM
SM 72020 - Ki-45 Toryu Control Surfaces HAS
Jan
DEAD
