exdraken Posted July 11, 2019 Share Posted July 11, 2019 (edited) as if I would not have to do enough elsewhere... but where else should I build one of these? not sure yet on the Squadron, but a grey one I'd like! maybe 3/75 Sdqu at Butterworth to even better fit to the Asian frontline topic? and I'd probably load t for some attack mission using the Kinetic RPK-10 with 2 Snakeeyes each? a 1300l tank on the center (from an AMk Kfir should do well I guess!) and Eduard Magic Missiles on canted Mirage IIIO 3 /75 Squadron, RAAF Butterworth, Malaysia that is what I have found in my stock that could be useful ? what puzzles me a bit is the ejection seat... acording to the above brilliant book , an MK6 should be fitted from 1981 instead of an Mk4.... left Mk4 from SBS, mid Mk4 from Pavla, right Mk4 from HPM they are not all that similar and specific I think.... who can help me out? as I understand it, the MK6 introduced a zero zero capability adding a rocket motor.... and double hand rails in addition to some additional part on the rear rail.... interesting accident story by the way: http://www.3squadron.org.au/subpages/Last_Sacrifice.htm RAAF serials: http://www.adf-serials.com.au/3a3.htm Edited November 3, 2019 by exdraken 7 Link to comment Share on other sites More sharing options...
modelling minion Posted July 11, 2019 Share Posted July 11, 2019 Oh yes Werner! A great choice of subject and one that I'm sure will prove very popular indeed. The book is supposed to be the best there is on the subject so that should answer most of the questions you have on the subject. Can't help you with the seat I'm afraid but I'm sure there are some decent pics online of the mk.6. Very interesting story, and very sad too, one of those where everything that could go wrong did. 1 Link to comment Share on other sites More sharing options...
Hewy Posted July 12, 2019 Share Posted July 12, 2019 A comprehensive set of goodies with this one 1 Link to comment Share on other sites More sharing options...
exdraken Posted July 18, 2019 Author Share Posted July 18, 2019 (edited) some work finally started have to get a bit accustomed to that sprue/ parts layout ... some strange and wobbly things... but I will get along brand new RESKIT resin nozzle set arrived yesterday as well! quick delivery from hobbyeasy that is what looks like to be part of my build finally the SBS cockpit looks much more detailed... not all can be seen nicely in these photos though... nice base! for painting and picking out some details! to be continued Edited July 18, 2019 by exdraken 6 Link to comment Share on other sites More sharing options...
modelling minion Posted July 18, 2019 Share Posted July 18, 2019 That is some nice resin you have there Werner, there really is no comparison between it and the original kit cockpit. This should be another excellent and well detailed build. 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted July 18, 2019 Share Posted July 18, 2019 On 7/12/2019 at 1:37 AM, exdraken said: as if I would not have to do enough elsewhere... but where else should I build one of these? not sure yet on the Squadron, but a grey one I'd like! maybe 3/75 Sdqu at Butterworth to even better fit to the Asian frontline topic? and I'd probably load t for some attack mission using the Kinetic RPK-10 with 2 Snakeeyes each? a 1300l tank on the center (from an AMk Kfir should do well I guess!) and Eduard Magic Missiles on canted Mirage IIIO 3 /75 Squadron, RAAF Butterworth, Malaysia that is what I have found in my stock that could be useful ? ... what puzzles me a bit is the ejection seat... acording to the above brilliant book , an MK6 should be fitted from 1981 instead of an Mk4.... ... left Mk4 from SBS, mid Mk4 from Pavla, right Mk4 from HPM they are not all that similar and specific I think.... who can help me out? as I understand it, the MK6 introduced a zero zero capability adding a rocket motor.... and double hand rails in addition to some additional part on the rear rail.... interesting accident story by the way: http://www.3squadron.org.au/subpages/Last_Sacrifice.htm Werner, the seat on the left looks more like a MK6, and yes it was upgraded with a rocket pack and the twin loop face blind firing handles. The head of the seat was also updated as I recall. High Planes in Singapore does on OM6 seat in 1/48 It was not quite a zero, zero seat. On my preflight brief when I went for a ride, the pilot told me that if we had engine problems on take off the seat would not operate well enough to get you safely back to the ground after ejection. Basically at lower speed and altitude (under 100 feet) you would still be in the seat when it hit the ground. Not a nice place to be! Fortunately that did not happen on my flight(s)! So which SQN will you go with? 3SQN or 75SQN? I worked on these for 4 years with 2OCU and 77SQN in the 80s (Instruments), so if there are any questions you have please ask and I will see if I can dust the cobwebs out of the old brain cells. 4 Link to comment Share on other sites More sharing options...
exdraken Posted July 21, 2019 Author Share Posted July 21, 2019 (edited) On 7/19/2019 at 12:20 AM, Romeo Alpha Yankee said: Werner, the seat on the left looks more like a MK6, and yes it was upgraded with a rocket pack and the twin loop face blind firing handles. The head of the seat was also updated as I recall. High Planes in Singapore does on OM6 seat in 1/48 It was not quite a zero, zero seat. On my preflight brief when I went for a ride, the pilot told me that if we had engine problems on take off the seat would not operate well enough to get you safely back to the ground after ejection. Basically at lower speed and altitude (under 100 feet) you would still be in the seat when it hit the ground. Not a nice place to be! Fortunately that did not happen on my flight(s)! So which SQN will you go with? 3SQN or 75SQN? I worked on these for 4 years with 2OCU and 77SQN in the 80s (Instruments), so if there are any questions you have please ask and I will see if I call dust the cobwebs outof the old brain cells. the seat on the right is from High Planes Models , thanks! the left one is from SBS and suposed to be an Mk4.... some work in the nozzles shop today, that means resin cutting and base painting with Alcad burnt iron: the Atar9C nozzle from RESKIT is in between Phantom and F-1 parts her they are: Edited July 21, 2019 by exdraken 4 Link to comment Share on other sites More sharing options...
aidy Posted July 21, 2019 Share Posted July 21, 2019 Nice subject, Werner. Will be picking up pointers from your build. I plan to have another go at this sometime soon. Link to comment Share on other sites More sharing options...
modelling minion Posted July 22, 2019 Share Posted July 22, 2019 Proper little engine build shop you have there Werner! Link to comment Share on other sites More sharing options...
exdraken Posted July 22, 2019 Author Share Posted July 22, 2019 1 minute ago, modelling minion said: Proper little engine build shop you have there Werner! yeah more a turbine, afterburner and nozzle shop... quite some parts missing for a complete engine! (but I just got a Kh Su-17... with a complete (externally at least) engine ) upload did not work for me yesterday evening, so some more paint work and tedious nozzle actuator mounting : the afterburner flame holder is missing in those photos.... fortunately not in the final assembly worth it imho! 7 Link to comment Share on other sites More sharing options...
modelling minion Posted July 22, 2019 Share Posted July 22, 2019 8 hours ago, exdraken said: worth it imho! Very much worth it! That looks excellent Werner, the colours you have used on the interior look spot on and the detailing really shows. Link to comment Share on other sites More sharing options...
exdraken Posted July 23, 2019 Author Share Posted July 23, 2019 closing in on the nozzle... just need a plane around now with flame holder 5 Link to comment Share on other sites More sharing options...
exdraken Posted July 26, 2019 Author Share Posted July 26, 2019 slow progress, base painted the resin cockpit parts yesterday 4 Link to comment Share on other sites More sharing options...
modelling minion Posted July 26, 2019 Share Posted July 26, 2019 That is a nicely detailed cockpit Werner, the base coat of paint shows up the details nicely. Link to comment Share on other sites More sharing options...
exdraken Posted August 21, 2019 Author Share Posted August 21, 2019 a bit on the backburner unfortunately.... but I started building the Magic 1 missiles! less is definitely nothing a all Eduard Brassin line, the one without notches in the rear fins are the -1s (#2, 4 from above) 2 Link to comment Share on other sites More sharing options...
modelling minion Posted August 21, 2019 Share Posted August 21, 2019 Progress is progress Werner, no matter how seemingly small and those missiles won't build themselves. 1 Link to comment Share on other sites More sharing options...
Nikolay Polyakov Posted August 22, 2019 Share Posted August 22, 2019 Nice start, Werner! The nozzles looks awesome! Link to comment Share on other sites More sharing options...
trickyrich Posted August 22, 2019 Share Posted August 22, 2019 nice choice Werner. On 7/19/2019 at 8:20 AM, Romeo Alpha Yankee said: I worked on these for 4 years with 2OCU and 77SQN in the 80s (Instruments), so if there are any questions you have please ask and I will see if I call dust the cobwebs outof the old brain cells. I didn't know you were a "clock-winder" as well from the 80's..........that explains a lot!! 1 Link to comment Share on other sites More sharing options...
modelling minion Posted September 4, 2019 Share Posted September 4, 2019 Hi Werner, any more progress on your Mirage? Link to comment Share on other sites More sharing options...
exdraken Posted September 4, 2019 Author Share Posted September 4, 2019 2 hours ago, modelling minion said: Hi Werner, any more progress on your Mirage? On this one, no... :( F1, work, F-4, vacation, etc... Will try to move on here as well 1 Link to comment Share on other sites More sharing options...
exdraken Posted September 23, 2019 Author Share Posted September 23, 2019 reporting back to work Magic missiles are also assembled largely (Eduard send replacement fins that were packed wrongly a week ago ) cockpit needs to be finished asap and installed the SBS cockpit is very nice and probably exact. but gosh it is small detail and hard to see anything! black doesn't help either.... drybrushing it will help hopefully! 3 Link to comment Share on other sites More sharing options...
modelling minion Posted September 24, 2019 Share Posted September 24, 2019 Very nice work on the instrument panel Werner, as you say I'm sure a drybrushing will help bring out the details. The missiles look really good, and the replacement fins look great. Link to comment Share on other sites More sharing options...
exdraken Posted September 25, 2019 Author Share Posted September 25, 2019 (edited) On 9/24/2019 at 8:11 PM, modelling minion said: Very nice work on the instrument panel Werner, as you say I'm sure a drybrushing will help bring out the details. The missiles look really good, and the replacement fins look great. thanks,,can be improved--- definitley my tonights take on doing so... now o have to install it somehow... that Kinetic kit on its own and less so with the SBS pit do not fall together! Edited September 25, 2019 by exdraken 5 Link to comment Share on other sites More sharing options...
modelling minion Posted September 26, 2019 Share Posted September 26, 2019 Great job on the cockpit Werner, that really does look very good and makes the details stand out. Good luck getting it to fit. Link to comment Share on other sites More sharing options...
exdraken Posted October 5, 2019 Author Share Posted October 5, 2019 that cockpit does not enter on its own.. but it will enter finally! problem is also the front landing gear bay, that does not fit to the resin cockpit design... 2 Link to comment Share on other sites More sharing options...
