Kylo Ren's Command Shuttle (06746) 1:93
Mike
1:93 Revell
Kylo Ren is Supreme Leader Snokes' young(ish) apprentice and plays a substantial role in both of the episodes of this sequel trilogy so far, with the promise of more in the upcoming Rise of Skywalker that is due (at time of writing) this Christmas, with the hope that it ends the series on a high note.  Ben Solo as he was named at birth gets around in a large black Command Shuttle, which bears a familial resemblance to an Imperial Shuttle in the folded configuration, and with the central fin deleted. In flight the wings fold out into a wide V-shape that defies explanation other than looking malevolent.  It's screen time is fairly fleeting in The Force Awakens, but it acts as his mobile command centre toward the end of The Last Jedi, hovering menacingly over the under-used AT-M6 Gorilla walkers and taking centre stage during the breaching of the Rebel base's huge armoured shield-door on Crait .
The Kit
This is a re-release of the snap-together styrene kit as a true model, and is more detailed and larger most of the other kits in the Star Wars range. It arrives in a large end-opening box, and has six sprues in grey black styrene, plus one containing a single clear part. The details aren't painted at the factory like the previous release, and as such it has been re-branded as a kit with the skill level raised from 2 to 3, and Kylo's helmeted head has been removed from the box art to be replaced by his Grandad wielding his light sabre.  Now the instructions show glue being used and colours are called out on the way using the more usual alphabetic codes that relate to their paint brand.
The first thing of note is how big these wings really are. They're over 30cm long, so when it's built, you're going to need some headroom wherever you want to store/display it. There are detail inserts in the wing edges, and the cannons in the leading wing-root edge are carried over from the old shuttles. The wings fix into the hull at the vertical landing orientation, so if you want to depict it in flight with wings canted to the sides, you'll need to adapt the roots to suit.  The partial retraction of the tips of the wings for landing inside hangar bays would make for a more difficult conversion, but there is bound to be some out there willing to give it a go, and some maniac will probably also motorise it!
The lower hull has a crew compartment and bulkhead added along with an articulated access-ramp, which is covered by a blank bay to block your view of the interior. The canopy and wing root bulkheads are slotted in place along with a few other smaller parts, and the hull is closed up, with a pair of exhaust nozzles added to the rear.  This time around you will need to paint the canopy yourself, which gives you the opportunity to leave it translucent to show the detail in the control room.
The wings slot into the hull's bulkheads on long pins for strength, and you then install the landing gear skids in retracted positions by leaving the gear legs off, or in landing pose by adding the legs beforehand.
Conclusion
This is a now marketed as a model and I feel that it is better suited to this genre as the surface detail is more in line with its new status. It's a big kit and if you take your time to paint and detail it to the best of your ability, the basic detail is strong enough and for the detailers it is a good base on which to go to town, with room inside the hull for a lighting rig if you have that in mind.
Highly recommended.
Revell model kits are available from all good toy and model retailers. For further information visit
