PolarisPrime 148 Posted February 18 Share Posted February 18 2 hours ago, Ex-FAAWAFU said: I use Gator Thin, followed up with a tiny amount of CA via capillary action a few days later after cleaning excess Gator I can attest to this. When I am gluing brass (or resin) to plastic with a flush joining surface I always start with Gator Grip or more often now Super Phatic and then flow some thin CA around the part a few days later. Also, if you are able to lightly sand (1200 grit) the back of the brass, and the plastic surface it is being bonded to it will dramatically increase the strength of the bond. Glue will not stick well to a smooth surface, but a little grit adds a ton of strength. To sand tiny parts, like a scuttle I lightly sand the back of them while they are still attached to the brass sprue. Is sprue the right word when talking about the brass sheets? I try and sand in 2 directions if possible. Of course I didn't do the scuttles on my Ark, so what do I know 3 Link to post Share on other sites
dickrd 291 Posted February 19 Share Posted February 19 (edited) Crispin, I don't know if you are a Facebook user, but if you are you might like to have a look at the "Aircraft Carriers of the Royal Navy" group. In a series of posts someone called Geoffrey Delves Broughton has shared the contents of his father's (Lt Cdr Peter DB's) photograph album including many photos of Ark Royal in 1939. I suspect that they will tell you nothing you did not already know but 80 or so nice images mainly of the FAA at work and play. Edited February 19 by dickrd 2 1 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 20 Author Share Posted February 20 Thanks a lot, Dick - I hadn’t seen them & a couple are real gold dust (as so often, something in the background of a shot provides the vital missing evidence of a couple of things). Quite a career, too; from Skuas in Ark early in the war to Sea Furies in Unicorn almost 10 years on... Anyway... speaking of little details revealed as incidentals in photos, today I decided to listen to the football while fettling the stockless anchor (purpose unclear) visible in this photo of Ark’s port side boat deck [posted earlier in this build by @iang, I think] Styrene rod, with the shank (here upside down) tapered by hand filing in a pin vice, then a second section of rod bent round a paint jar and glued in place: Then trimmed and some flukes filed into shape out of spare PE & CA’d in position after some more fettling: Pretty happy with that! 13 Link to post Share on other sites
giemme 20,545 Posted February 20 Share Posted February 20 Nice bit of scratch building, Crisp! Ciao 1 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 20 Author Share Posted February 20 Incidentally, a case in point about evidence in photos. If I post this one again... ...do any of BM’s Ark experts have any idea what the thing on the left edge of the picture is, by the bow of the covered Fast Motor Boat? It looks like a tank on a frame ready for quick jettison. Tetra’s designers actually provide this frame, and until I saw this photo I was almost ready to dismiss it as a figment of imagination , cos I haven't seen evidence in other photos. It’s on the port side, which a) generally has much less coverage in clear pictures and b) isn’t available in the builders’ drawings. I know the RN was extremely wary of petrol stowages in ships - look up HMS Dasher if you want to know why - so I guess that’s a possibility, but it seems unlikely to be honest. Anyone have any ideas? The Peter Delves Broughton photos which @dickrd mentioned yesterday include some crackers, including these two (both used with the permission of his son Geoffrey - indeed his active encouragement; “they shouldn’t be sitting in a box”). First up a wonderfully clear picture of one of Ark’s quad 0.5” Vickers machine guns (note the Ark Royal crest on the gun tampions), which also confirms what the inside of the bulkheads looked like (important if, like me, you plan to build them dropped): ...and second a great picture looking down her stern from the aft catwalk, which has confirmed my suspicion that though the bulkheads of the quarterdeck were white, the metal surrounds of the teak deck were definitely not: You cannot beat contemporary photographs for references, and this stuff is gold dust! 9 Link to post Share on other sites
beefy66 8,956 Posted February 20 Share Posted February 20 15 minutes ago, Ex-FAAWAFU said: Anyone have any ideas? At a wild guess because you can see some conduit coming from it some kind of signal device or maybe a flare launcher for bad weather signals as it is very close to the flight deck. Stay safe beefy 1 Link to post Share on other sites
dickrd 291 Posted February 20 Share Posted February 20 (edited) 51 minutes ago, Ex-FAAWAFU said: Thanks a lot, Dick - I hadn’t seen them & a couple are real gold dust (as so often, something in the background of a shot provides the vital missing evidence of a couple things). Quite a career, too; from Skuas in Ark early in the war to Sea Furies in Unicorn almost 10 years on... Delighted that you found something useful in them. You probably noticed that Geoffrey says he is going to have them properly scanned next week so maybe even more detail will be visible when he reposts them. Edited February 20 by dickrd 1 Link to post Share on other sites
Terry1954 7,512 Posted February 20 Share Posted February 20 I'd agree a tank shape on a frame, looking like an oil drum. Could be fuel, although could it be a life raft canister, like a Carley, but not! Terry 1 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 20 Author Share Posted February 20 15 minutes ago, beefy66 said: At a wild guess because you can see some conduit coming from it some kind of signal device or maybe a flare launcher for bad weather signals as it is very close to the flight deck. Stay safe beefy Thanks, Beefy, but I think you're looking at the wrong thing. The square thing that looks like a waffle iron with a conduit going to it is indeed part of a system for signalling to aircraft; it appears on both sides of the ship and is described in the builders' drawings as the "Carrier recognition Light". I mean this: 2 Link to post Share on other sites
Modelholic 315 Posted February 20 Share Posted February 20 If, your summarising that it's a jettisonable petrol stowage tank (presumably for the boats?) wouldn't it be logical to have one for the starboard side as well? Maybe some sort of mooring fender? Tom Link to post Share on other sites
Deano353 674 Posted February 20 Share Posted February 20 I'm.in awe I struggle to keep focus with 1/48 jets which are pretty big models. I don't know how you do it. Spectacular detail! 1 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 20 Author Share Posted February 20 10 minutes ago, Modelholic said: If, your summarising that it's a jettisonable petrol stowage tank (presumably for the boats?) wouldn't it be logical to have one for the starboard side as well? Maybe some sort of mooring fender? Tom I agree - that's why I said i thought the petrol stowage was unlikely. Not a mooring fender, because she stowed two large wooden mooring cats of her own on the flight deck; the things that look like giant pallets in the foreground here... Besides, it would be such an odd place to stow it, and why the apparent need for rapid jettison? The bottom line is... I don't know! Anyway, my stockless anchor is fitted: It will eventually have a tiny PE loop at the top, but if i fit it now it will have zero chance of survival! More soon Crisp 12 Link to post Share on other sites
Dave Swindell 2,438 Posted February 20 Share Posted February 20 1 hour ago, Ex-FAAWAFU said: I know the RN was extremely wary of petrol stowages in ships - look up HMS Dasher if you want to know why - so I guess that’s a possibility, but it seems unlikely to be honest. I'd say highly likely myself. Jettisonable ready use fuel tank for boats. As you say the RN wasn't too happy keeping fuel above the waterline, and there's a good example of a similar arrangement for fuel in HMS Hood when she had the Fairey IIIF on the quarterdeck, there was a jettisonable ready use avgas tank in a similar arrangement. near the catapult. 3 Link to post Share on other sites
Modelholic 315 Posted February 20 Share Posted February 20 (edited) I was agreeing with you about the petrol (could have worded my last post better I think). With a ship virtually sloshing with aviation grade petrol I'd think this would be a bad place/idea for stowage. There only appears to be one of them on the ship, Any signs of similar on other ships? Perhaps a device for giving the captain an interesting visit to Niagara Falls? Half a giant Wack'A'Mole mallet? Mmm. I see another post while I was typing. Tom Edited February 20 by Modelholic 2 Link to post Share on other sites
PolarisPrime 148 Posted February 20 Share Posted February 20 (edited) It definitely seems like some type of hazardous liquid container. My guess would be fuel for the motor boats. It's not big enough for aviation fuel, and on a carrier you would want a better solution for that anyway. Is there any other hazardous chemical on a carrier that would benefit from that location? Incidentally, what do you think the color of the tarp over the fast motor boat would be? On USN ships in the pacific they were often a really rich Mediterranean blue color (according to some lithographs i have seen). PS. The Vickers picture is fantastic. Thanks for linking to those pictures Dick. Bruce Edited February 20 by PolarisPrime PS Link to post Share on other sites
CedB 65,619 Posted February 20 Share Posted February 20 Nice anchor Crisp (That's it from me, I know nothing…) 3 Link to post Share on other sites
PolarisPrime 148 Posted February 21 Share Posted February 21 (edited) I wanted to see if they had jettisoned the tank when the ship was sinking. These are the only pictures I have that show the area clearly and are not smoke obstructed. There might be some argument that the tank is no longer there, but it definitely is not clear. Edited February 21 by PolarisPrime Link to post Share on other sites
Nick C 1,565 Posted February 21 Share Posted February 21 Looks similar to the one below, on HMS Hood, caption says aviation fuel tank, 1931; Only thing I could thing of other than the ships boats was a 'local' store of fuel for turning aircraft around quickly. Would they usually be taken below for refueling? If not. would you want pumped aviation fuel in pipes from the storage tanks below decks up to the flight deck - a smaller local tank might make sense. Don't know if it helps but interesting picture anyway. Cheers Nick 3 1 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 21 Author Share Posted February 21 Thanks, Nick; that helps a lot - I am now trying to fettle a suitable piece of runner into something similar. Meanwhile, here’s the rack (dry fitted; far too vulnerable position for glue just yet!) As you can see, this area yet to be cleaned up! More soon Crisp P.S. I have the long range tank from a 1/72 Airfix Swordfish - alas, much too big for this; but a plausible pattern. 9 Link to post Share on other sites
PolarisPrime 148 Posted February 21 Share Posted February 21 Maybe the tank is for the ship board rum ration. It's set for an easy eject in case of a mutiny. 2 4 Link to post Share on other sites
TheBaron 28,038 Posted February 21 Share Posted February 21 Your anchor is a pure fluke and you've got a nice rack. I don't say that to every sailor you know... 1 8 Link to post Share on other sites
hendie 17,746 Posted February 21 Share Posted February 21 4 hours ago, Ex-FAAWAFU said: alas, much too big for this; but a plausible pattern. Now of only you had one o' them fancy 3d printer thingies Crisp. 1 2 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 22 Author Share Posted February 22 It will come, Hendie - but not yet! 2 Link to post Share on other sites
Dancona 668 Posted February 22 Share Posted February 22 Looking really good, this thread is one of my guilty pleasures, the amount of extra gribbly bits you are adding is remarkable, just think, if it had been a simpler build like a Battleship it would have been finished months ago !! Cheers David 1 1 Link to post Share on other sites
Ex-FAAWAFU 26,829 Posted February 22 Author Share Posted February 22 23 minutes ago, Dancona said: Looking really good, this thread is one of my guilty pleasures, the amount of extra gribbly bits you are adding is remarkable, just think, if it had been a simpler build like a Battleship it would have been finished months ago !! Though sometimes it feels that progress is slow, we’re actually not that far away from the ship herself being complete in building terms (though painting is going to take a while). However, as fellow carrier-builders, you and I both know that the real fun is yet to come: looming in my mind’s eye are 15 torpedo-armed Swordfish, crewed-up and running on deck, with a lot of aircraft handlers.... 2 Link to post Share on other sites
