This started life as the Revel Iron Maiden Book of Souls Boeing 747-400 with GE Engines.
I replaced the power plant with Braz resin RB211 Rollers and used some Russian (cant remember the make) decals along with Authentic Airliners Revell cockpit glazing decal,
I did not bother tarting around with the first class fuselage area nose correction on this kit but have done so on another 1/144 747-400 build which I am still working on which shall be wearing BA's Chatham livery (G-CIVI)
A great fun kit, but the decals were a challenge as they all had a white solid lower stencil decal which was not printed in register to the colour decal that overlays it.
Thanks for looking in, this was a nice change from my norm 1/200 civil stuff.
DSCF8640
DSCF8645
DSCF8650
DSCF8651
DSCF8653
DSCF8655
DSCF8657
DSCF8658
DSCF8663
DSCF8664
  • Like 40
Hi John,
A colourful one for your collection!
Beautifully done as usual, if you hadn't mentioned about the mis matched white underlays I wouldn't have noticed. It's amazing the difference just moving the cockpit decal down a little makes to the look of the nose, I think Revell have it a fraction too high.
I like your fans, which colours did you use? Do you paint metallic then run a dark wash around the blades or paint dark then drybrush to highlight the blades?
Looking forward to your BA Chatham -400.
Ian
Very impressive!
I think the decals must have been by PAS Models. The scheme is in their catalogue and they have form for printing white underlays which don't match the actual decals. That said, I agree with Ian that the issues aren't noticeable on the finished model.  The BraZ engines look great.
Well done and thanks for sharing.
Dave G
Nicely done John, yes the decal is from PAS. I have the sheet somewhere in the stash. When I taklc mine I hope it turns out as nice.
Which red did you use for the fuselage? I have a small stash of Xtracolour QANTAS red but have been told one of the Humbrol reds is a good match as well for QANTAS.
:thumbsup:
Terrific jab on that, it all came together well, you could of course used the GE's and changed the rego to VH-OEJ, 2 different aircraft used the same scheme
18 hours ago, Turbofan said:
Hi John,
Ian
Thanks for the words Ian
All the metalics are from the Alcad II range. The fans are Stainless Steel where the other areas are Polished Aluminium. The fans were Alcad Matt black dry budded with the stainless steel on top.
The Qantas bird was a test assembly for the BA -436 which has had a lot more work go into it, along with 3D printed leading and trailing edge fully deployed 25 degree lowered flaps.
cheers - John
:thumbsup:
Hi Ray
Thanks for confirming and reminding me about the decal vendor here. I did some tests on the red but fell in love with the Tamiya small rattle can RED - 2 cans did the trick over a white primer. Below will give you an idea of what the lower decal sheet looks like
WhatsApp Image 2019-05-27 at 00.47.35
WhatsApp Image 2019-05-27 at 00.47.23
17 hours ago, Skodadriver said:
Very impressive!
Dave G
Thanks Dave - I have some of their (PAS) 747-8 Cathay Pacific Cargo decals with a similar white underlay decal set - I will approach that build with extreme caution
Wow, that is colourful! Looks good 'in flight' showing the 'ol 747 in it's natural element.
John
John
thanks John - my next 747 in 1/144 will have all her toes on show!
  • 1 year later...
Brings up some memories, I flew with this aircraft from Singapore to London back in 1996. And I did the same aircraft in 1:200, but had to hand-paint the whole thing as there were no decals available (at least, not that I knew of)
Alex
A real stunner.Beautiful build.
I have the same decals for one of my Revell -400s.
First time I see this in modelform.
Superb
On 3/8/2021 at 2:08 PM, Brodie said:
Just a quick one. Where did you get the window decals or did you just scavenge them off another kit?
Hi Brodie - I think they (i.e. fuselage windows) are from 26Decals from memory, but I mix and match a lot of my civil decal sets are they do vary in quality. The front end flight deck decal was Authentic Airliners spare from their resin dash-400 kit.
Superb
Thanks Alex - I know you and your civil models very well, glad it meets with your approval !
21 hours ago, Eric Mc said:
A lovely model "in the flesh" as well.
Cheers Eric, glad it met with your approval last year
