Sign in to follow this
Crane
Star Base
Working on a quick base for my completed Hellcat. I think this is the place to post this?
Getting the dimensions for the star were a tad tricky. This is my second attempt, I tried a water based paint first, which looked great but the shellac ruined it. This time I am using an oil based blue stain and then shellac on top. I gave it a week to dry.
The white is MRP lacquer, I test everything on the back first. It will take a couple of coats of white to cover the blue, and keeping an even airbrush coat is almost impossible. I plan to shellac on top of the white lacquer.
Very happy with results!  Tamiya tape worked well on top of wood. I plan to do 2 light coats of shellac over the top, after a few days dry time.
I need help/suggestions folks. I tested the shellac on the back, over a test spot of Mister Paint Lacquer Insignia White, and it looks a lot lighter afterwards, as if the shellac wiped some away.
I am looking for a clear top coat over the Mister Paint Lacquer Insignia White that will be safe.
Got 'er done. I had to repaint the star after the shellac wiped some of the white lacquer paint off.
Paints used in order -  blue Minwax water based wipe on stain --> clear shellac ----> MRP Insignia White lacquer -----> Minwax Polycrylic (water based) clear
They all seem to be playing nice together (so far). If any peeling/cracking occurs, I will update.
(the white is a lot whiter irl, the picture is a little yellow shifted)
Edited by Crane
Looks really good - now let’s see it with the Hellcat!
I think that the base should be distressed to match the plane. Maybe I will make another and sand some areas of the base down. I just can't do it to this one 😟
