ProfSparks
1/72 Airfix Westland Whirlwind fighter with Airwaves cockpit etch, and another one as a spare, because I know what I'm like with etch
Hi All
Todays' Lab multiple choice:- watching paint dry, or fit Airwaves etch to an old Airfix kit..?
:unsure:
Somehow I've ended up with these
While in that big yellow website of temptation looking for Spitfire decals, I was lured into the re release of the cockpit etch set
The other one has issues with the decals, so as I was buying decals anyway, I figured I might as well get these from DK Decals
I've some of the other schemes on here lined up for stash queens.
Anyhoo, the etch is neither coloured nor adhesive, so that's a good start.
Comments and suggestions welcome
Steve
Edited by ProfSparks
Looking forward to seeing how you get on. I don't have a whirlwind in my stash at the moment, but that could change :)
Snap.
Stuart
Hi All
Step 1.
Remove all interior sticky-out things that could interfere with the fit of the PE tub
Step 2.
Realise that Step 1 is EXACTLY NOT what I should have done, as the sticky-out bits are what locates the kit seat in the fuselage
:wall:
Never mind.
Step 3.
Let's do some folding!
Just the external, to get an idea of how it fits.
erm...
You can just make out where I removed one of those locating pegs, the PE fits under it.
However, when I say "fits"...
Kit seat needs some TLC
:banghead:
I'm sure it says on the label that this set is for the 1/72 Airfix Westland Whirlwind.
Perhaps there is another 1/72 Airfix Westland Whirlwind that I may come across in the future.
53 minutes ago, Courageous said:
Snap.
Stuart
Hey @clive_t and @Courageous, I think I know where there's at least one of these kits about to become available at no extra cost...
Comments, suggestions, and that other 1/72 Airfix Westland Whirlwind welcome
Steve
After doing the post, I had a 'light bulb :idea:'. I do have the Airfix offering, it was in 'stash place 2/3' :rofl:.
Looking at that PE cockpit, I think I'd look at another option as it looks too flat...just me. Let's see how it scrubs up.
Stuart
That light blue plastic from the old Airfix box sure is nostalgic though!
A part from fitting a proper sized seat I think you're almost done with the cockpit now.
Good work!
Hi All
I've come to terms with the Airwaves
Just needs a bit filling in round where it doesn't touch (the floor, the wall), and grinding out where it's too big (the IP. Who would have guessed...?) and perhaps the floor moving aft so the driver can reach the pedals.
I'll crack open the canopy too given half a chance.
Steve
Hi All
So I started by thinning out the sidealls where the etch was to sit
It will get squished to the side and filled better than the Gannet
That IP is still too wide, even after being filed down and quite a lot of side wall taken out round it
I have a desperate cunning plan, and if it all goes South, at least I have a near-enough spare from the Spitfire Zoom calamity
Thso, cut here
Then here
And Robert's that awkward relative you try to avoid at Christmas!
There's a plate with six dials to go on the centre blue patch that should disguise the join admirably.
Look, it fits better
Now we're talking.
Hmm, the Pilot still seems a long way from the controls
I'll move the seat part forward to the canopy framing and extend the rear decking.
Steve
Hats of for you perseverance with the Airwaves set.
Martian 👽
Not surprised to see you having problems with the Airwaves etch, I had the set for a Ki-46 that seemed to have no relationship with the fuselage it was meant to fit in.  Took much surgery to get it to fit.  All to no avail in the end as the Dinah went in the bin for other reasons relating to decals.
Now Airfix, how about a new tool Whirlwind?
AW
I've never encountered an Airwaves etch set that fitted or even came close to fitting! Every one I tried I ended up cutting into separate parts, much like you have done. I think I have the Whirlwind set lurking around somewhere, though the chances of it getting used are pretty slim!
Anyway, it's always good to see a Whirlwind getting built.
Mark.
Crikey, that's a lot of work. As said by others it's great to see a Whirlwind bring built. I have one in the stash (and a 48th scale kit on the go ) and will watch with interest.
Great work so far on the cockpit looking forward to seeing this develope.
Keep up the good work
All the best
Chris
Mark.
You may well have hit on a theme there Mark.  I recall the one for the Airfix Mosquito was so far out that it sits in my spares to this day: it was easier to just scratch build it.
I have the Whirlwind and the etch set to do....  Forewarned is forearmed.
Although it was a long time ago, I have vivid memories of the hassle of trying to get the Airwaves set for the Matchbox Beaufighter to fit. I ended up cutting the sides off the sidewall/floor assembly and treating every surface as a separate item, with lots of cutting and filing. It worked (and even looked fairly good once finished) but it's not something I'd want to repeat, though saying that, I subsequently went through exactly the same with their Defiant set! To this day I hate using etch of any kind!
These days I tend to scratchbuild and cockpit detail I might want to add, as I find it far more relaxing than trying to get someone else's product to fit.
Hi All
Thanks for the confirmation that it's not just me having issues with Airwaves etch, makes me wonder why they've re-issued it as it was so badly fitting in the first place?
Anyhoo, I moved the seat to a more comfortable position, and you'll note that the front of the windscreen actually goes under the forward cowling. Had me going there for a little while...
Now just need a way of fixing the floor here
Sides glued in and the IP mangled to fit
The gap at the top is to let the windscreen slip in :whistle:
I put in a couple of spacers for the seat to sit on and the floor to locate up against
And it's not looking too bad so far
I'm pleased with that so far.
I'll alter the seat support and rear decking, then there's a multitude of teeny greebles to scatter in there (there are Airwaves parts still on the etch sprue, but I'm not holding out any hope of any of them fitting where they should).
Steve
Hi All
I've started populating the interior, starting with a control column
And some bits on the Port sidewall
Once it's all painted and hidden it should look at least better than OOB.
Steve
Hi All
A quick session with Airwaves finest...
The floor
And the four pieces to the left of the pilot are the seatbelts
Can't help but think they would be better served elsewhere, perhaps as a couple of switches/ buttons on a centre console?
The pedals also were raised to where he might be able to reach them
The IP cut'n'shut needs to be disguised
And with a flash over of black
A bit of touch up, some dry brush and Krystal Klear for the dials, should be passable.
The rest of the interior got a coat of Vallejo Air 71.305 Int Grey Green
And not forgetting the OOB sidekick
Will give them a final coat, add the bits where applicable, and hope to get them buttoned up next time.
Steve
Ah, but it's Airwaves, and that's NOT a good start!
Good luck!
Ian
Hi All
Gah, thanks Ian, if only I'd known :doh:
Here's the IP with some dry brush and gloop in the dials.
It looks kinda gnarley this close, those holes moved around when I tried to neatly fill them, but should hide well enough.
The rest of the interior had a wash and masking tape seatbelts added
(See, the IP looks better from here already!)
Steve
Looking really good now.  I bet that etch set is feeling sorry it crossed you 😉
Only suggestion would be to try take-away tray foil or wine bottle foil or similar for the belts: IMO they end up looking so much better than tape as they can be made to drape realistically.
Hi All
Nice and cool in The Lab, who wants to be outside anyway?
Side walls assembled
And closed up
I've a feeling that the IP should be closer to the pilot and not out past the pedals, but oddly the front of the canopy locates under the top of the nose cowling and I'd have even more trouble getting anything to fit once that was on.
Anyhoo, seams mostly sanded out
But wait! What is this?
That'll be The Curse Of The Etch pushing the sides out. At least it's not ton the top this time, I'll deal with it once the nose is on.
Nose on
Gaps to be filled and blended in, natch
Does the tail look lopsided, or is it just me?
While I pondered that, I did the wheel wells with Vallejo 71.305 Int. Grey Green
And got the wings glued and set aside to set
Steve
That is quite impressive mate, I have built that kit sometime ago. It is little dated kit but fun to build for sure.
Very nice build. The funny thing with Airfix for me as a small boy at the time (late seventies/early eighties) that they taught me about aircraft types. Many of which I had never seen before such as the Whirlwind and the Halifax.
Without Airfix the Halifax cockpit now at East Kirkby would never have materialized.😊
Cees
Hi All
Hi Cees, that's happening to me even now, fifty or so years later, so many types still to discover too!
I got some time to mount their legs for spraying
Then turned my attention to the engine pods, before and after attention
With the majority of the seams in remission, I glued the wings to the OOB
Yes, I know it's missing the aerial thingie from atop its' tail, silly place to put it anyway.
Anyhoo, back to the Scarewaves Etch, these parts are for the wing root radiator fronts
I was quite prepared to cut, file, swear, bend and lose them before getting them to fit, but as it turns out they just go right in when the wings are attached!
Even to the point of disguising the join between the wing and the body.
Well done Airwaves! (there's a phrase I never thought I'd say...)
So, they'll be painted separately and installed after the main painting.
Wings on that one too
Here we shall languish for a brief time whilst I go and work.
Steve
